#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
//Include Lib for Arduino to Nodemcu
#include <SoftwareSerial.h>
#include <ArduinoJson.h>
//D6 = Rx & D5 = Tx
SoftwareSerial nodemcu(D6, D5);
// Update HOST URL here
int led = D0;
int red_led = D1;
// int val = 1;
// int val2 = 99;
String sendval, sendval2, postData;
pinMode(led, OUTPUT);
pinMode(red_led, OUTPUT);
nodemcu.begin(9600);
while (!Serial) continue;
WiFi.begin("", "");
int connectCounter = 0;
while(WiFi.status() != WL_CONNECTED && connectCounter < 300) // 1 minute timeout (300 * 200ms delay)
Serial.print("..");
digitalWrite(red_led, LOW);
digitalWrite(led, HIGH);
delay(200);
digitalWrite(led, LOW);
digitalWrite(red_led, HIGH);
delay(200);
connectCounter++;
if (WiFi.status() != WL_CONNECTED) {
Serial.println("NodeMCU couldn't connect to WiFi!");
else {
Serial.println("NodeMCU is Connected!");
Serial.print(WiFi.status());
Serial.println("WiFi disconnected! Reconnecting...");
WiFi.reconnect();
Serial.print("..");
delay(200);
delay(200);
connectCounter++;
Serial.println("NodeMCU couldn't reconnect to WiFi!");
else {
Serial.println("NodeMCU is reconnected to WiFi!");
if (nodemcu.available()) {
StaticJsonDocument<1000> jsonBuffer;
DeserializationError error = deserializeJson(jsonBuffer, nodemcu);
if (error) {
Serial.print("deserializeJson() failed: ");
Serial.println(error.c_str());
return;
JsonObject data = jsonBuffer.as<JsonObject>();
Serial.println("JSON Object Recieved");
Serial.print("Recieved Soil Moisture: ");
for(int i=1; i<=4; i++) {
String sendval = "Sensor " + String(i);
int value = data["Sensor" + String(i)];
String sendval2 = String(value);
String moisturecat = data["Sensor" + String(i)+"Read"];
postData = "sendval=" + sendval + "&sendval2=" + sendval2 + "&moisturecat=" + moisturecat;
HTTPClient http; // http object of clas HTTPClient
WiFiClient wclient; // wclient object of clas HTTPClient
// // Convert integer variables to string
// sendval = "Sensor 1";
// sendval2 = String(sensor1);
// postData = "sendval=" + sendval + "&sendval2=" + sendval2;
// We can post values to PHP files as example.com/dbwrite.php?name1=val1&name2=val2&name3=val3
// Hence created variable postDAta and stored our variables in it in desired format
// For more detials, refer:- https://www.tutorialspoint.com/php/php_get_post.htm
// Update Host URL here:-
http.begin(wclient, "http:///try/dbwrite.php"); // Connect to host where MySQL databse is hosted
http.addHeader("Content-Type", "application/x-www-form-urlencoded"); //Specify content-type header
int httpCode = http.POST(postData); // Send POST request to php file and store server response code in variable named httpCode
Serial.println("Values are, sendval = " + sendval + " and sendval2 = "+sendval2 + "moisture category = " + moisturecat );
Serial.println("Server Response: " + String(httpCode) + " - " + http.errorToString(httpCode).c_str());
Serial.println(postData);
// if connection eatablished then do this
if (httpCode == 200) {
Serial.println("Values uploaded successfully.");
Serial.println(httpCode);
String webpage = http.getString(); // Get html webpage output and store it in a string
Serial.println(webpage + "\n");
// if failed to connect then return and restart
else {
Serial.println("Failed to upload values. \n");
http.end();
return;
delay(3000);
digitalWrite(LED_BUILTIN, LOW);
delay(3000);
digitalWrite(LED_BUILTIN, HIGH);
delay(60000);
// put your other code here
