Hello Guys While I am programming my Esp8266 for calculating the voltage using LM258.
previously I have used this code
#include <Filters.h>
#define ZMPT101B A0
float testFrequency = 60;
float windowLength = 100 / testFrequency;
int RawValue = 0;
float Volts_TRMS;
float intercept = 0;
float slope = 1.8;
RunningStatistics inputStats;
Serial.println("Serial started");
inputStats.setWindowSecs(windowLength);
ReadVoltage();
void ReadVoltage() {
RawValue = analogRead(ZMPT101B);
inputStats.input(RawValue);
Volts_TRMS = inputStats.sigma() * slope + intercept;
Volts_TRMS = Volts_TRMS*1.25;
if (Volts_TRMS > 30 && Volts_TRMS < 300) {
Serial.println(Volts_TRMS);
Serial.println("0");
When i use this code with void it works well but as soon as I change my code from void to float it is not giving me proper values here is the float code that i have created.
#define ZMPT101B A0
int RawValue = 0;
float Volts_TRMS;
float slope = 1.8;
float voltage = ReadVoltage();
Serial.print("Voltage: ");
Serial.println(voltage);
float ReadVoltage() {
return Volts_TRMS;
return 0;
What is the issue might be here can anybody tell me?
Welcome to the forum
As your topic does not relate to the operation of IDE 1.x it has been moved to the Programming category of the forum
What do you see if you print the value of Volts_TRMS in the "float" version of your function ?
some random values... like when i am printing for void it is showing me voltage around 220-230 which i have calibrated but as soon as i use float it is showing me some random values between 0 to 70.
See I have done some changes in the code
#define ZMPT101B A0
int RawValue = 0;
float Volts_TRMS;
float slope = 1.8;
float voltage;
ReadVoltage(voltage);
void ReadVoltage(float& voltage) {
RawValue = analogRead(ZMPT101B); // read the analog in value:
inputStats.input(RawValue); // log to Stats function
Volts_TRMS = Volts_TRMS * 1.25; // Further calibration if needed
voltage = Volts_TRMS; // Assign the voltage value to the reference variable
voltage = 0; // Assign 0 to the reference variable
This code working fine for me right now but i want to intigrate this code into my main code which is this one
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include "pcloud.h"
const char* ssid = "Password";
const char* password = "Password";
const char* authCode = "pcloud-oU8MKDfAINeIVAkqaHDLB8i";
#define ZMPT101B A0
int RawValue = 0;
float Volts_TRMS;
float slope = 1.8;
pCloud pCloud(ssid, password, authCode);
pCloud.setup();
pCloud.setPinMode(D0, OUTPUT);
pCloud.setPinMode(D1, OUTPUT);
pCloud.setPinMode(D2, OUTPUT);
pCloud.setPinMode(D3, OUTPUT);
pCloud.setPinMode(D4, OUTPUT);
pCloud.setPinMode(D5, OUTPUT);
pCloud.setPinMode(D6, OUTPUT);
pCloud.setPinMode(D7, OUTPUT);
pCloud.setPinMode(D8, OUTPUT);
float voltage;
pCloud.loop();
pCloud.VirtualWrite(V0, voltage);
but in this code it is still not working
b707
April 17, 2024, 11:00am
6
Prince990:
ZMPT101B A0
The problem is not the type of function (void vs float), but the fact that in the second code you add Wi-Fi and cloud (and, most likely, a lot of other code).
The library for the ZMPT sensor is very sensitive to delays. To get the correct values, you must measure the data hundreds of times per second. Obviously, when working with a network, the code may have delays tens of times longer.
Yes, so do I have to change this window size right?
float windowLength = (100 / testFrequency);
b707
April 17, 2024, 11:04am
8
I am not sure.
I highly doubt that working with this sensor is compatible with working in the cloud
ah man is there any library available rather than ZMPT for this?
b707
April 17, 2024, 11:07am
10
If you comment the last two lines in the loop - is it make the sensor output correct?
heyyyy.... bruhh i am geeting the values correctly now but i got the values after soo much time see this Serial monitor output
16:33:08.862 -> ...........
16:33:14.404 ->
16:33:14.404 -> ____ ____ _ ___ _ _ ____
16:33:14.404 -> | _ \ / | | | / _ \ | | | | | _ \
16:33:14.450 -> | | ) | _____ | | | | | | | | | | | | | | | |
16:33:14.450 -> | / | | | | __ | |___ | || | | | | | | || |
16:33:14.450 -> | | _| | | _ / ___/ |____/
16:33:14.450 ->
16:33:14.450 ->
16:33:14.450 -> SERVER: pcloud.codeestro.com
16:33:14.450 -> WIFI SSID: Password
16:33:14.450 -> IP ADDRESS: 00.00.00.00
16:33:14.450 -> 266.46
16:33:18.252 -> 0.00
16:33:21.372 -> 0.00
16:33:24.722 -> 0.00
16:33:27.996 -> 0.00
16:33:31.275 -> 0.00
16:33:34.705 -> 0.00
16:33:38.293 -> 0.00
16:33:41.679 -> 0.00
16:33:45.637 -> 0.00
16:33:48.861 -> 0.00
16:33:52.310 -> 0.00
16:33:55.619 -> 0.00
16:33:58.976 -> 0.00
16:34:02.453 -> 0.00
16:34:05.944 -> 0.00
16:34:09.614 -> 0.00
16:34:13.339 -> 0.00
16:34:17.027 -> 0.00
16:34:20.671 -> 0.00
16:34:24.018 -> 0.00
16:34:27.306 -> 0.00
16:34:30.522 -> 0.00
16:34:33.851 -> 0.00
16:34:37.071 -> 0.00
16:34:40.217 -> 0.00
16:34:43.356 -> 0.00
16:34:47.209 -> 0.00
16:34:50.604 -> 0.00
16:34:53.769 -> 0.00
16:34:56.936 -> 0.00
16:35:00.237 -> 0.00
16:35:03.389 -> 0.00
16:35:06.694 -> 0.00
16:35:10.204 -> 294.12
16:35:13.486 -> 284.60
16:35:16.950 -> 275.48
16:35:20.181 -> 266.75
16:35:23.643 -> 257.39
16:35:26.974 -> 249.52
16:35:30.215 -> 242.47
16:35:33.427 -> 236.34
16:35:36.531 -> 231.01
16:35:39.636 -> 227.52
16:35:42.786 -> 223.47
16:35:46.105 -> 218.35
16:35:49.300 -> 213.17
16:35:52.746 -> 210.20
b707
April 17, 2024, 11:11am
13
Sorry, I am not experienced with the Cloud... Perhaps you could to pause the Cloud.loop() some way during the sensor reading...
But the best way is to use sensors that do the calculations itself and outputs the processed data.
Ohh okay, let me see what I can do. Thanks though..
Got the solution to this problem by using their library I have resolved my problem.
library link: https://github.com/Abdurraziq/ZMPT101B-arduino/tree/master
Here is the updated code
#include <ZMPT101B.h>
#include "pcloud.h"
const char* ssid = "SSID";
const char* password = "PASSWORD";
const char* authCode = "Token";
#define SENSITIVITY 500.0f
float Frequency = 60.0;
ZMPT101B voltageSensor(A0, Frequency);
voltageSensor.setSensitivity(SENSITIVITY);
pCloud.setup();
float voltage;
pCloud.loop();
float new_voltage = (voltageSensor.getRmsVoltage()*1.35);
if (new_voltage > 30 && new_voltage < 300) {
voltage = new_voltage;
voltage = 0;
Prince990:
I just sped read the thread, thinking you might have made a simple error commonly seen, that is not returning a value with a proper return statement.
You have solved your problem, but in an odd way. Please read this change and see how a function that returns a value is used:
float voltage;
pCloud.loop();
float the_voltage = voltageSensor.getRmsVoltage() * 1.35;
if (the_voltage > 30 && the_voltage < 300) {
// the voltage is OK
else {
// out of range, return 0
the_voltage = 0;
return the_voltage;
It's your code with a few style tweaks (spaces, extra parents removed &c.) my elbows did before my brain would not let them and
changing getting the value back to where you use it from modifying an argument passed by reference (handy sometimes, but not needed and possibly bad elsewhere) to letting the function return a value.
HTH
a7
Thank you so much for spending so much time. Surely i will check this code if it might work then its really good for me..
