I'm trying to configure OTA on an ESP8266 but I can't. I've tried several tutorials on the net and none works.
The sketch I'm using is as follows:
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <ESP8266WebServer.h>
#ifndef STASSID
#define STASSID "xxx"
#define STAPSK "xxx"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
ESP8266WebServer server;
bool ota_flag = true;
uint16_t time_elapsed = 0;
pinMode(2, OUTPUT);
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("A conexão falhou! Reiniciando...");
delay(5000);
ESP.restart();
// Hostname defaults to esp8266-[ChipID]
ArduinoOTA.setHostname("ControleGeladeira");
// No authentication by default
// ArduinoOTA.setPassword("admin");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_FS
type = "filesystem";
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) {
Serial.println("Auth Failed");
} else if (error == OTA_BEGIN_ERROR) {
Serial.println("Begin Failed");
} else if (error == OTA_CONNECT_ERROR) {
Serial.println("Connect Failed");
} else if (error == OTA_RECEIVE_ERROR) {
Serial.println("Receive Failed");
} else if (error == OTA_END_ERROR) {
Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
server.on("/restart",[](){
server.send(200,"text/plain", "Restarting...");
ESP.restart();
server.on("/setFlag",[](){
server.send(200,"text/plain", "Setting flag...");
ota_flag = true;
time_elapsed = 0;
server.begin();
if(ota_flag)
uint16_t time_start = millis();
while(time_elapsed < 15000)
ArduinoOTA.handle();
time_elapsed = millis()-time_start;
delay(10);
ota_flag = false;
server.handleClient();
digitalWrite(2, !digitalRead(2));
delay(100);
The error message is not very helpful:
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 299756 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27900 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1508 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1480 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 26328 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 330644 bytes (31%) of program storage space. Maximum is 1044464 bytes.
Global variables use 29316 bytes (35%) of dynamic memory, leaving 52604 bytes for local variables. Maximum is 81920 bytes.
"C:\Users\mvrin\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3" -I "C:\Users\mvrin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/espota.py" -i "192.168.68.105" -p "8266" "--auth=controleeladeira" -f "C:\Users\mvrin\AppData\Local\Temp\arduino-sketch-530AD6D38B059906AB54EE36C0795F3A/simpleOTA.ino.bin"
14:31:57 [ERROR]: No Answer
Failed uploading: uploading error: exit status 1
Can anyone help me?
