ESP8266 - Unstable upload of sketches from Arduino IDE
I've been struggling with this issue for a while now, so I think it is time to ask for help.
The upload of the sketch is very unstable for me. I use FTDI adapter and even bought a new one to make sure it is not the reason. I also tried to use different settings in the Arduino IDE suspecting that the problem lives in the settings, but nothing changed. See attached file (Arduino.settings2.jpg) for the latest settings I used - I have ESP8266 12E chips.
See also the 3 usual outcome of an upload:
1, see the file attached: Fail1.txt - the first few lines are the output of the upload in the IDE. As you can see: no errors there. But after a restart of the ESP it goes into an infinite loop of errors with the exception you can see the remaining part of that file.
2, see the file attached: Fail2.txt - the upload fails at the very end of the upload.
3, see the file attached: Success.txt - this one was actually successful, the sketch does what it should do, but you can see a warning at the beginning of the upload. Maybe I get this result 1 out of 10 uploads.
These three runs are literally three tries after each other in this order.
Does anyone have any clue what's going on and how can I fix it?
Fail1.txt (5.28 KB)
Fail2.txt (705 Bytes)
Success.txt (584 Bytes)
Just a quick addition to this problem - still unsolved though.
So, I found a few minimum wiring of ESP8266 where the RST and GPIO16 pins have been connected. I checked it and experienced the same symptoms. The other thing I noticed that most of the tutorial pages suggest to use 10k pull down/up resistors while I'm using 2k ones. But based on this article it shouldn't be a problem.
And one other piece of information, maybe it helps. I use this schematic for the tests.
Are you using the FTDI adapter's 3.3V for your ESP-12 ?
The circuit is what you should have
plus 10K resistor from GPIO15 to ground (the ESP-01 pictured does not have GPIO15 that comes out to a pin on the board)
FTDI is only for 50mA at 3.3V. That might be an issue.
By the way, that circuit is from the ESP8266 Arduino Core website.
I'm using separate power source to power up the ESP. So that's not the problem, for sure.
But I'm connecting only the RX+TX+GND pins - nothing else - could it be the problem? I'm using resistors to constantly pull up GPIO0 and RST though.
ivivan:
You need the circuit that I linked above.
Otherwise, you won't be able to upload new firmware to the ESP8266.
I tried your way and it didn't work at all. I couldn't put the ESP into "flash" mode this way. Is there a trick? I normally pull up the IO0 for normal boot and pull it down for flash, but if I connected the IO0 to the FTDI's DTR port it never went to flash mode however I pulled it.
ivivan:
I built my own circuit for flashing the ESP-01 based on the one at https://www.allaboutcircuits.com/projects/flashing-the-ESP-01-firmware-to-SDK-v2.0.0-is-easier-now/
It should work for you.
It does, just not all the time. I checked that page and my circuit looks very similar, so I don't think the circuit itself the problem, but then I have no idea what it is :confused:
