Esp8266 When trying to run code it gives boot error
When trying to run my code on my esp8266 it first prints a lot of memory address then prints this
code:
  static byte x = 0;
  Serial.println(x);
Error:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00041e00
~ld
anyone know how to solve this?
did you have the serial monitor baudrate set to 115200?
Yes the output only comes on 115200 on any lower one it just outputs garbage
if I load the code of post 1 into a NodeMCU_V1_ ESP-12E ESP8266 the serial monitor displays
sdlܟ<�l�<�l�c|����r�#�c��gn�dog���c8�lrd;lx�o��$��#g�|���#��ng�l��l �eo'l`ao;Ǜ�'cl�al8�o�;��ܜ��b'�|�c��o'�l �eo'l`ao;Ǜ�'c��`a{ۓo#��`��8el`��o�al����g��s��'|�d�l c��|;�l�o��g�l`��{�d�le��0
0
0
0
0
0
the serial monitor baudrate is set to 115200baud the first line is boot information output at 74880baud (hence appears as garbage) the 0's are the program output at 115200baud
what Tools>Board have you selected? I use Generic ESP8266 Module
the program output in post 1 looks as though the serial monitor baudrate is set to 74880 and you are displaying the boot information
this is what i see when i run on 115200baud
