MisterMel:
Alright, that should be able to work just fine. Can you post your current sketch here, just so I can see what you already have? From there you should be able to modify it to be able to control 8 GPIOs.
Im not planning to have DHT sensors connected, not yet at least. goal is to have 8 working relays.
my main concern is that according to this article A Beginner's Guide to the ESP8266 certain gpio must be in specific state during boot. in my case all 8 have to be HIGH. if i understood correctly it might cause issues or board will become inaccessible
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include "DHT.h"
#include <Wire.h>
// Uncomment one of the lines bellow for whatever DHT sensor type you're using!
#define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT21 // DHT 21 (AM2301)
//#define DHTTYPE DHT22 // DHT 22 (AM2302), AM2321
// Change the credentials below, so your ESP8266 connects to your router
const char* ssid = "test";
const char* password = "12345678";
// Change the variable to your Raspberry Pi IP address, so it connects to your MQTT broker
const char* mqtt_server = "MQTT";
// Initializes the espClient. You should change the espClient name if you have multiple ESPs running in your home automation system
WiFiClient espClient;
PubSubClient client(espClient);
// DHT Sensor - GPIO 5 = D1 on ESP-12E NodeMCU board
const int DHTPin = 5;
// Lamp - LED - GPIO 4 = D2 on ESP-12E NodeMCU board
const int lamp = 4;
// Initialize DHT sensor.
DHT dht(DHTPin, DHTTYPE);
// Timers auxiliar variables
long now = millis();
long lastMeasure = 0;
// Don't change the function below. This functions connects your ESP8266 to your router
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected - ESP IP address: ");
// This functions is executed when some device publishes a message to a topic that your ESP8266 is subscribed to
// Change the function below to add logic to your program, so when a device publishes a message to a topic that
// your ESP8266 is subscribed you can actually do something
void callback(String topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message*);*
_ messageTemp += (char)message*;_
_ }_
_ Serial.println();_
_ // Feel free to add more if statements to control more GPIOs with MQTT*_
* // If a message is received on the topic room/lamp, you check if the message is either on or off. Turns the lamp GPIO according to the message*
* if(topic=="room/lamp"){*
* Serial.print("Changing Room lamp to ");*
* if(messageTemp == "on"){*
* digitalWrite(lamp, LOW);*
* Serial.print("On");*
* else if(messageTemp == "off"){*
* digitalWrite(lamp, HIGH);*
* Serial.print("Off");*
* Serial.println();*
// This functions reconnects your ESP8266 to your MQTT broker
// Change the function below if you want to subscribe to more topics with your ESP8266
void reconnect() {
* // Loop until we're reconnected*
* while (!client.connected()) {*
* Serial.print("Attempting MQTT connection...");*
* // Attempt to connect*
_ /_
_ YOU MIGHT NEED TO CHANGE THIS LINE, IF YOU'RE HAVING PROBLEMS WITH MQTT MULTIPLE CONNECTIONS*_
* To change the ESP device ID, you will have to give a new name to the ESP8266.*
_ /_
_ if (client.connect("ESP8266Client")) {_
_ Serial.println("connected"); _
_ // Subscribe or resubscribe to a topic*_
* // You can subscribe to more topics (to control more LEDs in this example)*
* client.subscribe("room/lamp");*
* } else {*
* Serial.print("failed, rc=");*
* Serial.print(client.state());*
* Serial.println(" try again in 5 seconds");*
* // Wait 5 seconds before retrying*
* delay(5000);*
// The setup function sets your ESP GPIOs to Outputs, starts the serial communication at a baud rate of 115200
// Sets your mqtt broker and sets the callback function
// The callback function is what receives messages and actually controls the LEDs
* pinMode(lamp, OUTPUT);*
* dht.begin();*
* Serial.begin(115200);*
* setup_wifi();
client.setServer(mqtt_server, 1883);
_ client.setCallback(callback);_
_}_
_// For this project, you don't need to change anything in the loop function. Basically it ensures that you ESP is connected to your broker*_
* if (!client.connected()) {*
* reconnect();*
* if(!client.loop())*
* client.connect("ESP8266Client");*
* now = millis();*
* // Publishes new temperature and humidity every 30 seconds*
* if (now - lastMeasure > 30000) {*
* lastMeasure = now;*
* // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)*
* float h = dht.readHumidity();*
* // Read temperature as Celsius (the default)*
* float t = dht.readTemperature();*
* // Read temperature as Fahrenheit (isFahrenheit = true)*
* float f = dht.readTemperature(true);*
* // Check if any reads failed and exit early (to try again).*
* if (isnan(h) || isnan(t) || isnan(f)) {*
* Serial.println("Failed to read from DHT sensor!");*
* return;*
* // Computes temperature values in Celsius*
* float hic = dht.computeHeatIndex(t, h, false);*
* static char temperatureTemp[7];*
* dtostrf(hic, 6, 2, temperatureTemp);*
* // Uncomment to compute temperature values in Fahrenheit*
* // float hif = dht.computeHeatIndex(f, h);*
* // static char temperatureTemp[7];*
* // dtostrf(hic, 6, 2, temperatureTemp);*
* static char humidityTemp[7];*
* dtostrf(h, 6, 2, humidityTemp);*
* // Publishes Temperature and Humidity values*
* client.publish("room/temperature", temperatureTemp);*
* client.publish("room/humidity", humidityTemp);*
* Serial.print("Humidity: ");*
* Serial.print(h);*
* Serial.print(" %\t Temperature: ");*
* Serial.print(t);*
_ Serial.print(" C ");_
_ Serial.print(f);_
_ Serial.print(" F\t Heat index: ");_
_ Serial.print(hic);_
_ Serial.println(" C ");_
_ // Serial.print(hif);_
_ // Serial.println(" F");_
_ }_
