Ethernet_Generic library
How To Install Using Arduino Library Manager
Features
This Ethernet_Generic library is a port and modification to merge, as many as possible, the features of the following libraries
- Ethernet
- EthernetLarge
- Ethernet2
- Ethernet3
for AVR, Portenta_H7, Teensy, SAM DUE, Arduino SAMD21, Adafruit SAMD21/SAMD51, Adafruit nRF52, ESP32/ESP8266, STM32, RP2040-based, etc. boards using Ethernet W5x00 shields.
The h-only library now supports SPI2, most of EthernetLarge, Ethernet2 and Ethernet3 features by simply changing definitions in the sketch.
Currently supported Boards
This Ethernet_Generic library currently supports these following boards:
- nRF52 boards, such as AdaFruit Feather nRF52832, nRF52840 Express, BlueFruit Sense, Itsy-Bitsy nRF52840 Express, Metro nRF52840 Express, NINA_B302_ublox, NINA_B112_ublox, etc.
- SAM DUE
- SAMD21
- Arduino SAMD21: ZERO, MKRs, NANO_33_IOT, etc.
- Adafruit SAMD21 (M0): ItsyBitsy M0, Feather M0, Feather M0 Express, Metro M0 Express, Circuit Playground Express, Trinket M0, PIRkey, Hallowing M0, Crickit M0, etc.
- Seeeduino: LoRaWAN, Zero, Femto M0, XIAO M0, Wio GPS Board, etc.
- SAMD51
- Adafruit SAMD51 (M4): Metro M4, Grand Central M4, ItsyBitsy M4, Feather M4 Express, Trellis M4, Metro M4 AirLift Lite, MONSTER M4SK Express, Hallowing M4, etc.
- Seeeduino: Wio Terminal, Grove UI Wireless
Teensy (4.1, 4.0, 3.6, 3.5, 3,2, 3.1, 3.0, LC)
AVR Mega1280, 2560, ADK.
ESP32, using SPI or SPI2
ESP8266
RP2040-based boards, such as RASPBERRY_PI_PICO, ADAFRUIT_FEATHER_RP2040 and GENERIC_RP2040, using Arduino-mbed RP2040 core or Earle Philhower's arduino-pico core.
Portenta_H7
Arduino UNO WiFi Rev2, AVR_NANO_EVERY, etc.
Currently supported Ethernet shields/modules
- W5x00 shield /module
Changelog
Releases v2.0.0
Initial porting and coding to merge, as many as possible, the features of the following libraries :
Add support to ESP32 SPI2
Convert to h-only library
Add debug feature
Optimize code to reduce compiled binary size
Add
Packages' Patches
Examples
- multiFileProject
- TelnetClient
- UdpNTPClient
- UdpSendReceive
- WebClient
- WebClient_ESP
- WebClient_ESP_SPI2
- WebClientRepeating
- WebClientRepeating_ESP
- WebClientRepeating_ESP_SPI2
- WebServer
Debug Terminal Output Samples
1. WebClientRepeating_ESP_SPI2 on ESP32_DEV
The following are debug terminal output when running example WebClientRepeating_ESP_SPI2 on ESP32_DEV with W5500 using Ethernet_Generic Library on SPI2
Starting WebClientRepeating_ESP_SPI2 on ESP32_DEV with W5x00 using Ethernet_Generic Library on SPI2
Ethernet_Generic v2.0.0
Currently Used SPI pinout:
MOSI:13
MISO:12
SCK:14
SS:5
Using mac index = 19
Connected! IP address: 192.168.2.95
Speed: 100 MB, Duplex: FULL DUPLEX, Link status: LINK
Starting connection to server...
Connecting...
HTTP/1.1 200 OK
Server: nginx/1.4.2
Date: Fri, 01 Apr 2022 19:00:28 GMT
Content-Type: text/plain
Content-Length: 2318
Last-Modified: Thu, 24 Feb 2022 11:33:35 GMT
Connection: close
Vary: Accept-Encoding
ETag: "62176d0f-90e"
Accept-Ranges: bytes
Please use http://arduino.tips/asciilogo.txt via HTTP
.;;;;;;;;;;;` :;;;;;;;;;;: TM
2. WebClient on MBED RASPBERRY_PI_PICO with Large Buffer
The following are debug terminal output when running example WebClient on MBED RASPBERRY_PI_PICO with W5500 using Ethernet_Generic Library and ArduinoCore-mbed mbed_rp2040 core
Starting WebClient on MBED RASPBERRY_PI_PICO with W5x00 using Ethernet_Generic Library with Large Buffer
MOSI:19
MISO:16
SCK:18
SS:17
Using mac index = 16
Connected! IP address: 192.168.2.80
Connected to server
HTTP/1.1 200 OK
Server: nginx/1.4.2
Date: Sun, 03 Apr 2022 02:19:29 GMT
Content-Length: 2317
Last-Modified: Thu, 24 Feb 2022 11:33:32 GMT
Connection: close
ETag: "62176d0c-90d"
Disconnecting from server...
