So I had a thread started, but it went dead before all of my questions were answered. It is here, but my remaining problem is all the way at the bottom.
When I go to the displayed IP address, it is said to be unavailable, and the serial monitor doesn't respond.
My code is:
#include <Ethernet.h>
int Svr=1;
byte mac[] = {0xAD, 0xBE, 0xDE};
IPAddress ip(129, 186, 1, 172);
EthernetServer server(80);
while (!Serial)
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server1 is at ");
Serial.println(Ethernet.localIP());
while (!client)
Serial.println("new client");
Svr++;
Serial.print("server");
Serial.print(Svr);
Serial.print(" is at ");
The serial monitor only displays:
server1 is at 129.186.1.172
And the webpage displays:
This site can't be reached
129.186.1.172 took too long to respond.
ERR_CONNECTION_TIMED_OUT
If there's no client connected to your server before the while loop begins (and it's highly unlikely if not impossible for a client to connect to your server by that time), it will loop forever. Nothing inside the while loop changes the condition of the while loop.
... Nothing inside the while loop changes the condition of the while loop.
Good point. I copied that section of code from a example or something, I think, and I expected the example to work, especially since a loop checks the condition before repeating is what I was thinking at the time... Anyways, thanks. I'll change my code to the following:
bool LpCndtn=false
int Svr=1;
byte mac[]={0xAD, 0xBE, 0xDE};
while (!Serial)
server.begin();
while (LpCndtn)
if (client)
LpCndtn=true
Svr++;
Serial.print(Svr);
But wouldn't that do the same thing? Or would that somehow allow for server to become true when the previous version doesn't?
Juraj: So I just have to send, or more than that
PaulS: Ethernet port 4 in the modem. I believe it is called Network 8.
http requires in response at least "HTTP/1.1 200 OK", but you should send other http headers and the body of the response too. see some examples in Arduino IDE Examples menu.
here is my Web server with static files serving and Ajax json responses
KDNXZ:
PieterP: I see. By the second comment do you only mean void loop would not continue until a client is available? If so, I'm good with that.
Yes. In most cases, you don't want that, so I don't see why you would type the extra line here.
KDNXZ:
Juraj: We have two very different types of web servers. I am a newbie and don't know what to say about , but could you please tell me the required lines of code for my page?
There are HTTP libraries available. Why do you want to send raw HTTP yourself?
The only real way to learn HTTP is by opening the network tab in your browser's developer options, and by reading the RFCs (RFC7230-7231), or by reading answers from angry people on Stack Overflow who have read the RFCs
PieterP: For your first comment, encapsulation.OCD, and encapsulation. For your second comment, I don't want to learn and deal with unnecessary libraries, and I should be able to figure out the html functions by looking them up, seeing examples of html servers, and using inspect.
That doesn't improve encapsulation, the only difference is that you have to write the same line twice, and that you block your only thread.
The HTTP library is not at all unnecessary. Parsing HTTP is hard. You won't be able to implement it yourself, unless you spend weeks digging through the specs and reinventing the wheel.
The fact that you don't know the difference between HTML and HTTP says enough, I'm afraid
while (!client)
A problem there is that you have two different variables named 'client'. The one inside the while loop doesn't exist outside the while loop and the one above the while loop doesn't get set. I think what you want is:
EthernetClient client;
do
while (!client);
The do-while statement is what you use if you want the body to execute at least once before the loop test. If you don't like the do-while statement you can avoid calling server.available() in two places with:
Encapsulation is a vague concept, and did I mention OCD?
Blocking the thread until a client is available is completely practical in this case.
I may be completely wrong about this, but last time I checked, Server.print goes straight to the following:...
4.Sometimes this feels like reinventing the wheel
5.I know the difference between HTML and http. Sorry if I put one in the wrong place.
C:\Users\KDNXZ\AppData\Local\Temp\arduino_modified_sketch_671153\Xprmnttn__TempUse.ino: In function 'void loop()':
Xprmnttn__TempUse:44: error: expected unqualified-id before '.' token
Server.println("");
Using library Ethernet at version 1.1.2 in folder: C:\Program Files\Arduino\libraries\Ethernet
Using library SPI at version 1.0 in folder: C:\Users\KDNXZ\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\libraries\SPI
exit status 1
KDNXZ:
3. I may be completely wrong about this, but last time I checked, Server.print goes straight to the following:...
I'm afraid you are: the server is just a TCP server. You can't just send raw HTML over it. You have to first parse the HTTP request headers, then send HTTP response headers, and finally you send the actual HTML.
KDNXZ:
One more thing; Changed my code to the following:
Juraj: Thanks. Is there a face-palm emoji? I just looked back to the reference and it looks like client.println. I must have been tired when I started this. :o
PieterP: I think I found the source of my mistake. I think I want to use client.println, not server . Will this require me to use SPI.h? Oh, and not sure how that happened . That wasn't my code... This is:
