Ethernet Shield Connectivity Problems (Mac)
Hi everyone.
I have a Duemilanove with an ethernet shield on top. I have a Mac Mini and have bridged my Airport (WiFi) connection to the Ethernet.
My router IP is 192.168.2.1
The Airport connects via the router and has a static IP of 192.168.2.6
My sketch sets the Arduino mac, IP (192.168.2.20) and gateway (which I think is what's wrong)
When I plug the ethernet cable into the Mac, it assigns an IP address of 169.254.70.44 (Using DHCP).
I have 2 problems now:
Firstly, when I run the "WebServer" ethernet example sketch, I can connect to the Arduino using my Mac browser (192.168.2.20) and I can see the HTML output) - BUT, I have to disconnect my Wifi/Airport first (is there a way around this?)
Secondly, when I run the "WebClient" I can't seem to get the Arduino to connect.
1, In my sketch - what should the IP and gateway be set to (Is the gateway the mac IP or the router IP?)
2, Does it matter if I use a straight network cable (patch) or a crossover cable? I have tried both but neither seems to work. I think the Mac is supposed to be able to use a patch cable as a crossover if needed...
I'm normally fine with network configuration on PC/Mac/Linux - but I just cant seem to crack this one.
My ifconfig et0 output is as follows (disconnected, then connected):
Mac:~ alex$ ifconfig en0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
      ether 00:16:cb:ac:2f:aa
      inet 192.168.2.1 netmask 0xffffff00 broadcast 192.168.2.255
      media: autoselect
      status: inactive
      inet6 fe80::216:cbff:feac:2faa%en0 prefixlen 64 scopeid 0x4
      inet 169.254.70.44 netmask 0xffff0000 broadcast 169.254.255.255
      media: autoselect (100baseTX <full-duplex>)
      status: active
Thanks,
Alex
OK, I tried connecting the Arduino (with my GLCD library running a graphics LCD KS0801 - data pins on digital 0-7 as to not interfere with the ethernet pins) and it works when connected directly to my router.
I've also tried to get my laptop (Ubuntu) to share the connection via my mac without much luck - perhaps it's the actually connection sharing that's the issue?
