I have been trying to figure out how to put my sensor data i get off of my arduino onto a webpage. I have the ethernet shield but i seem to be stuck.
I have tried just using a piece of given code of of the arduino website to test if it works at all.
Here it is:
Chat Server
A simple server that distributes any incoming messages to all
connected clients. To use, telnet to your device's IP address and type.
You can see the client's input in the serial monitor as well.
Using an Arduino Wiznet Ethernet shield.
Circuit:
- Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 1, 9);
IPAddress myDns(192,168,1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
// telnet defaults to port 23
EthernetServer server(23);
boolean alreadyConnected = false; // whether or not the client was connected previously
// initialize the ethernet device
Ethernet.begin(mac, ip, myDns, gateway, subnet);
// start listening for clients
server.begin();
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Chat server address:");
Serial.println(Ethernet.localIP());
// wait for a new client:
// when the client sends the first byte, say hello:
if (client) {
if (!alreadyConnected) {
// clear out the input buffer:
client.flush();
Serial.println("We have a new client");
client.println("Hello, client!");
alreadyConnected = true;
if (client.available() > 0) {
// read the bytes incoming from the client:
char thisChar = client.read();
// echo the bytes back to the client:
server.write(thisChar);
// echo the bytes to the server as well:
Serial.write(thisChar);
When is go to 192.168.1.9 on my browser it just simply doesn't work. It says "This Webpage is not available". And the arduino is plugged into a LAN cable that i use for my computer otherwise so that shouldn't be the problem.
If anyone knows why it doesn't seem to be working, please help me out.
