Using Windows 7 64bit with version 22 and latest drivers for ftdi cable.
However when I uploaded the sketch I get the following error. Used the new boards.txt file from http://arduino.cc/en/uploads/Main/boards.txt I have checked I am using the correct board and port in tools menu.
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I have powered the board over the POE port and connected the ftdi cable. The board lights up with just the ftdi cable or just the poe or with both connected. I don't have anything powering the 2.1mm jack. I assume the board can be powered in several different ways.
Do I need to use a separate power supply to power the board when uploading ? Another post said I need to supply 5v to the Vin pin. How would this be wired ?
I can find very little information on this board (examples etc) I assume because it so new.
Where is that board plugged in (ethernet-wise)?
By default the ethernet connection (where you plugged the board in) does NOT supply power. You have to connect to an ethernet port that DOES supply power.
I am using a 3com poe power supply. This has 2 ports, one back to the switch and the other to the device injecting the power onto the cat5 cable. The board powers up of the poe ethernet connection without anything else connected.
I am assuming this would supply the required 5v without connecting anything to the vin pin.
I have tried it with 9v battery connected to the board with same results.
The hardware spec clearly states I can use a ftdi cable to program the unit.
"Arduino Ethernet - This board contains an ATmega328 microcontroller and the same ethernet IC used on Ethernet Shield. You need a FTDI cable or a USBSerial adapter to program the ATmega328."
