EthernetWebServer_STM32 library
How To Install Using Arduino Library Manager
This library currently supports
- STM32 boards with built-in Ethernet such as :
- Nucleo-144 (F429ZI, F767ZI)
- Discovery (STM32F746G-DISCOVERY)
- All STM32 Boards with Built-in Ethernet, See How To Use Built-in Ethernet
- STM32 boards (with 64+K Flash) running EMC28J60 shields
List of supported STM32 Boards
- Nucleo-144
- Nucleo-64
- Discovery
- STM32MP1
- Generic STM32F1 (with 64+K Flash): C8 and up
- Generic STM32F4
- STM32L0
- LoRa boards
- 3-D printer boards
- Generic Flight Controllers
- Midatronics boards
and these boards are not supported:
- Nucleo-32 (small Flash/memory)
- Eval (no Serial, just need to redefine in sketch, library and UIPEthernet)
- Generic STM32F0 (small Flash/memory)
- Generic STM32F1 (with <64K Flash): C6
- Generic STM32F3 : no HardwareSPI.h
- Electronics Speed Controllers (small Flash/memory)
This is simple yet complete WebServer library for STM32 boards running built-in Ethernet (Nucleo-144, Discovery) or EMC28J60 Ethernet shields. The functions are similar and compatible to ESP8266/ESP32 WebServer libraries to make life much easier to port sketches from ESP8266/ESP32.
The library supports
- HTTP Server and Client
- HTTP GET and POST requests, provides argument parsing, handles one client at a time.
Library is based on and modified from :Ivan Grokhotkov's ESP8266WebServer
The EthernetWebServer class found in EthernetWebServer.h header, is a simple web server that knows how to handle HTTP requests such as GET and POST and can only support one simultaneous client.
Sample Code
* Currently support
* 1) STM32 boards with built-in Ethernet (to use USE_BUILTIN_ETHERNET = true) such as :
* - Nucleo-144 (F429ZI, F767ZI)
* - Discovery (STM32F746G-DISCOVERY)
* 2) STM32 boards (with 64+K Flash) running EMC28J60 shields (to use USE_BUILTIN_ETHERNET = false)
#define USE_BUILTIN_ETHERNET false //true
#include <EthernetWebServer_STM32.h>
// Enter a MAC address and IP address for your controller below.
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 200);
EthernetWebServer server(80);
const int led = 13;
const String postForms =
"<html>\
<head>\
<title>EthernetWebServer POST handling</title>\
<style>\
body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }\
</style>\
</head>\
<body>\
<h1>POST plain text to /postplain/</h1>
<form method=\"post\" enctype=\"text/plain\" action=\"/postplain/\">\
<input type=\"text\" name=\'{\"hello\": \"world\", \"trash\": \"\' value=\'\"}\'>
<input type=\"submit\" value=\"Submit\">\
</form>\
<h1>POST form data to /postform/</h1>
<form method=\"post\" enctype=\"application/x-www-form-urlencoded\" action=\"/postform/\">\
<input type=\"text\" name=\"hello\" value=\"world\">
</form>\
</body>\
</html>";
void handleRoot()
digitalWrite(led, 1);
server.send(200, "text/html", postForms);
digitalWrite(led, 0);
void handlePlain()
if (server.method() != HTTP_POST)
server.send(405, "text/plain", "Method Not Allowed");
} else
server.send(200, "text/plain", "POST body was:\n" + server.arg("plain"));
void handleForm()
String message = "POST form was:\n";
for (uint8_t i = 0; i < server.args(); i++)
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(200, "text/plain", message);
void handleNotFound()
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET) ? "GET" : "POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
server.send(404, "text/plain", message);
void setup(void)
pinMode(led, OUTPUT);
Serial.println("\nStarting POSTServer");
// start the ethernet connection and the server:
Ethernet.begin(mac, ip);
server.on("/", handleRoot);
server.on("/postplain/", handlePlain);
server.on("/postform/", handleForm);
server.onNotFound(handleNotFound);
server.begin();
Serial.print(F("HTTP EthernetWebServer started @ IP : "));
Serial.println(Ethernet.localIP());
void loop(void)
server.handleClient();
