Since the new IDE I'm having trouble opening a project I've saved.
I have already saved the saved with a different name but get an error message that does not exist.
There is no file with this name, so why the error. Have already deleted the entire library, but keep getting the error
Sorry, the file was in the library TFT_eSPI, but why did I never have any problems with this before with the other IDE. I've been using this library for more than 2 years.
I have all the USER_SETUP files here that I use with different displays
Why did you post this in the Hardware forum section? It's clearly not a hardware problem. It sounds like you think it's a problem with the newer 2.x version of the IDE. So why did you not post it in that section?
If you want, I can move it for you. But I'm curious why you posted it here.
Sorry, but I think I already found the problem by chance. I put the folder library in the folder of the project to make sure that I only use the correct files for this project. This was the problem. Would you be so kind as to remove everything.
Please mark it as solved.
