Example mouse sketch does not provide input
I am trying to use the Nano esp32 as an HID device and was following the tutorial in this video to get started. I am using the example ButtonMouseControl sketch that comes built into the IDE when the board is downloaded. After the code uploads though nothing happens. Is there something I am missing with this board? Code is below
  ButtonMouseControl
  Controls the mouse from five pushbuttons on an Arduino Leonardo, Micro or Due.
  Hardware:
  - five pushbuttons attached to D12, D13, D14, D15, D0
  The mouse movement is always relative. This sketch reads four pushbuttons,
  and uses them to set the movement of the mouse.
  WARNING: When you use the Mouse.move() command, the Arduino takes over your
  mouse! Make sure you have control before you use the mouse commands.
  created 15 Mar 2012
  modified 27 Mar 2012
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/ButtonMouseControl
#if ARDUINO_USB_MODE
#warning This sketch should be used when USB is in OTG mode
void setup(){}
void loop(){}
#else
#include "USB.h"
#include "USBHIDMouse.h"
USBHIDMouse Mouse;
// set pin numbers for the five buttons:
const int upButton = 12;
const int downButton = 11;
const int leftButton = 10;
const int rightButton = 9;
const int mouseButton = 8;
int range = 5;              // output range of X or Y movement; affects movement speed
int responseDelay = 10;     // response delay of the mouse, in ms
  // initialize the buttons' inputs:
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(leftButton, INPUT_PULLUP);
  pinMode(rightButton, INPUT_PULLUP);
  pinMode(mouseButton, INPUT_PULLUP);
  // initialize mouse control:
  Mouse.begin();
  USB.begin();
  // read the buttons:
  int upState = digitalRead(upButton);
  int downState = digitalRead(downButton);
  int rightState = digitalRead(rightButton);
  int leftState = digitalRead(leftButton);
  int clickState = digitalRead(mouseButton);
  // calculate the movement distance based on the button states:
  int  xDistance = (leftState - rightState) * range;
  int  yDistance = (upState - downState) * range;
  // if X or Y is non-zero, move:
  if ((xDistance != 0) || (yDistance != 0)) {
    Mouse.move(xDistance, yDistance, 0);
  // if the mouse button is pressed:
  if (clickState == LOW) {
    // if the mouse is not pressed, press it:
    if (!Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.press(MOUSE_LEFT);
  // else the mouse button is not pressed:
  else {
    // if the mouse is pressed, release it:
    if (Mouse.isPressed(MOUSE_LEFT)) {
      Mouse.release(MOUSE_LEFT);
  // a delay so the mouse doesn't move too fast:
  delay(responseDelay);
#endif /* ARDUINO_USB_MODE */
This is expected. The sketch code causes the mouse pointer to be moved only after you press the button connected between pin 9, 10, 11, or 12 and ground on the board, and the mouse buttons to be pressed only after you press the button connected to pin 8 or 9 and ground on the board.
Please give that a try and then add a reply here to let us know whether it behaved as expected.
I rewired everything and it works as expected now, Thanks!
You are welcome. I'm glad it is working now.
Regards,
Per
