FQBN: DxCore:megaavr:avrdd
Using board 'avrdd' from platform in folder: C:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11
Using core 'dxcore' from platform in folder: C:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11
Detecting libraries used...
C:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++ -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=avr64dd32 -DF_CPU=24000000L -DCLOCK_SOURCE=0 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB2 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION1 -DARDUINO=10607 -DARDUINO_avrdd -DARDUINO_ARCH_MEGAAVR -DDXCORE="$" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DMVIO_ENABLED -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\variants\32pin-ddseries C:\Users\saifu\AppData\Local\arduino\sketches\B5440F6C1501322F739C0D9E8D9D82ED\sketch\Autoscroll.ino.cpp -o nul
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal@1.0.7]
C:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++ -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=avr64dd32 -DF_CPU=24000000L -DCLOCK_SOURCE=0 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB2 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION1 -DARDUINO=10607 -DARDUINO_avrdd -DARDUINO_ARCH_MEGAAVR -DDXCORE="$" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DMVIO_ENABLED -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\variants\32pin-ddseries -IC:\Users\saifu\AppData\Local\Arduino15\libraries\LiquidCrystal\src C:\Users\saifu\AppData\Local\arduino\sketches\B5440F6C1501322F739C0D9E8D9D82ED\sketch\Autoscroll.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\saifu\AppData\Local\Arduino15\libraries\LiquidCrystal\src\LiquidCrystal.cpp
Generating function prototypes...
C:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\tools\avr-gcc\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++ -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=avr64dd32 -DF_CPU=24000000L -DCLOCK_SOURCE=0 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB2 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION1 -DARDUINO=10607 -DARDUINO_avrdd -DARDUINO_ARCH_MEGAAVR -DDXCORE="$" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DMVIO_ENABLED -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore/api/deprecated -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\cores\dxcore -IC:\Users\saifu\AppData\Local\Arduino15\packages\DxCore\hardware\megaavr\1.5.11\variants\32pin-ddseries -IC:\Users\saifu\AppData\Local\Arduino15\libraries\LiquidCrystal\src C:\Users\saifu\AppData\Local\arduino\sketches\B5440F6C1501322F739C0D9E8D9D82ED\sketch\Autoscroll.ino.cpp -o C:\Users\saifu\AppData\Local\Temp\4222913540\sketch_merged.cpp
C:\Users\saifu\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\saifu\AppData\Local\Temp\4222913540\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=avr64dd32 -DF_CPU=24000000L -DCLOCK_SOURCE=0 -DTWI_MORS_SINGLE -DMILLIS_USE_TIMERB2 -DCORE_ATTACH_ALL -DLOCK_FLMAP -DFLMAPSECTION1 -DARDUINO=10607 -DARDUINO_avrdd -DARDUINO_ARCH_MEGAAVR "-DDXCORE=\"${DOWNLOADED_FILE#\"v\"}\"" -DDXCORE_MAJOR=1UL -DDXCORE_MINOR=5UL -DDXCORE_PATCH=11UL -DDXCORE_RELEASED=1 -DMVIO_ENABLED "-IC:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore/api/deprecated" "-IC:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\cores\\dxcore" "-IC:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\hardware\\megaavr\\1.5.11\\variants\\32pin-ddseries" "-IC:\\Users\\saifu\\AppData\\Local\\Arduino15\\libraries\\LiquidCrystal\\src" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED\\sketch\\Autoscroll.ino.cpp" -o "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED\\sketch\\Autoscroll.ino.cpp.o"
Compiling libraries...
Compiling library "LiquidCrystal"
Using previously compiled file: C:\Users\saifu\AppData\Local\arduino\sketches\B5440F6C1501322F739C0D9E8D9D82ED\libraries\LiquidCrystal\LiquidCrystal.cpp.o
Compiling core...
Using precompiled core: C:\Users\saifu\AppData\Local\arduino\cores\e3cbe7c6d06c873bc18caf5c895ecb9b\core.a
Linking everything together...
"C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-gcc" -Wall -Os -g -flto -fuse-linker-plugin -mrelax -Wl,--gc-sections,--section-start=.text=0x0,--section-start=.FLMAP_SECTION1=0x8000,--section-start=.FLMAP_SECTION2=0x10000,--section-start=.FLMAP_SECTION3=0x18000 -mmcu=avr64dd32 -o "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.elf" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED\\sketch\\Autoscroll.ino.cpp.o" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED\\libraries\\LiquidCrystal\\LiquidCrystal.cpp.o" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/..\\..\\cores\\e3cbe7c6d06c873bc18caf5c895ecb9b\\core.a" "-LC:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED" -lm
"C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O binary -R .eeprom "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.elf" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.bin"
"C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.elf" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.eep"
"C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.elf" "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.hex"
cmd /C echo. && "C:\\Users\\saifu\\AppData\\Local\\Arduino15\\packages\\DxCore\\tools\\avr-gcc\\7.3.0-atmel3.6.1-azduino7b1/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.elf" > "C:\\Users\\saifu\\AppData\\Local\\arduino\\sketches\\B5440F6C1501322F739C0D9E8D9D82ED/Autoscroll.ino.lst"
Using library LiquidCrystal at version 1.0.7 in folder: C:\Users\saifu\AppData\Local\Arduino15\libraries\LiquidCrystal
exec: "cmd": executable file not found in %PATH%
Compilation error: exec: "cmd": executable file not found in %PATH%
If you read and follow the pinned post re how to get the best from this forum, then maybe someone can help you.
Hi @saifullah8560. I'm going to ask you to provide the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
- Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open. - Check the box next to "Show verbose output during: ☐ compile" in the "Preferences" dialog.
- Click the "OK" button.
The "Preferences" dialog will close. - Select Sketch > Verify/Compile from the Arduino IDE menus.
- Wait for the compilation to fail.
- You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
- Open a forum reply here by clicking the "Reply" button.
- Click the
<CODE/>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the compilation output into the code block. - Move the cursor outside of the code block markup before you add any additional text to your reply.
- Click the "Reply" button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
- Open any text editor program.
- Paste the copied output into the text editor.
- Save the file in
.txtformat. - Open a forum reply here by clicking the "Reply" button.
- Click the "Upload" icon (
) on the post composer toolbar:
The "Open" dialog will open. - Select the
.txtfile you saved from the "Open" dialog. - Click the "Open" button.
The dialog will close. - Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Compiling sketch...
Compiling core...
