We are recreating the majority of the project from this website http://robowarner.com/portfolio/radio-homing-robot-diy/. We have connected the arduino uno to a mac computer. I understand the code is for a arduino micro but I dont think that is the issue. See code below.
//Code written by Warner K. of www.robowarner.com
//Made for the Radio Direction Finding Robot at www.robowarner.com/robot/rdfbot
//You are free to modify, distribute and store this code.
//USE THIS CODE AT YOUR OWN RISK!
//I am NOT liable for any harm that results from the use of this code.
// Code is based off of the original BASIC for the robot, so it has room for improvement. ![]()
//Defines (Constants)
#define buffering 25 //what counts as straight ahead? If too small, the robot will jitter. If too large the robot will drive away from the transmitter
//pinout
#define ANT_WAVEFORM_OUT 8 // set output pin
#define SPEAKER_FROM_WALKIETALKIE A1 //set input pin
#define CALIBRATE_IN 11
#define SERVO1pin 9
#define SERVO2pin 10
//Variables
uint16_t caliset = 0;
uint16_t voltage = 0;
//includes
#include <EEPROM.h>
#include <Servo.h>
Servo servo1; // create servo object to control a servo
Servo servo2; // create servo object to control a servo
// a maximum of eight servo objects can be created
//start program
analogReference(DEFAULT);
servo1.attach(SERVO1pin); // attaches the servos
servo2.attach(SERVO2pin);
Serial.begin(9600); //begin serial monitor output, remove if you don't want it
delay(6000); // I put this delay here so the robot won't move until the walkie talkie has had time to turn on.
pinMode(ANT_WAVEFORM_OUT, OUTPUT);
pinMode(SPEAKER_FROM_WALKIETALKIE, INPUT);
pinMode(CALIBRATE_IN, INPUT);
digitalWrite(CALIBRATE_IN, HIGH); // enable internal pullup resistor
//read calibration word from EEPROM
byte HByte = EEPROM.read(1);
byte LByte = EEPROM.read(2);
caliset = word(HByte, LByte);
Serial.print("EEPROM Calibration number: ");
Serial.print(caliset);
Serial.println(" If you haven't calibrated yet, you need to for it to work");
if (digitalRead(CALIBRATE_IN) == LOW){ // used for calibrating
delay(9000); // a wait so you can back away from the robot while it is calibrating
void loop(){
digitalWrite(ANT_WAVEFORM_OUT, HIGH); //output antenna switching waveform
delay(1);
digitalWrite(ANT_WAVEFORM_OUT, LOW);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
delay(1);
voltage = analogRead(SPEAKER_FROM_WALKIETALKIE); //read voltage from radio
if (digitalRead(CALIBRATE_IN) == LOW){ //if in calibrate mode, store voltage in EEPROM
caliset = voltage;
byte HByte = highByte(caliset);
byte LByte = lowByte(caliset);
EEPROM.write(1, HByte);
EEPROM.write(2, LByte);
delay(5000);
endprogram();
if (voltage > (caliset - buffering) && voltage < (caliset + buffering)) { //drive forward
//motor control code for FORWARD here
//code for a continuous roating servo is included below
servo1.write(180);
servo2.write(0);
if (voltage > (caliset + buffering)){ //turn
//motor control code for TURNING here (right or left depends on antenna config.)
servo1.write(180);
servo2.write(180);
if (voltage < (caliset - buffering)){ //turn the other way
//motor control code for TURNING the OTHER DIRECTION here (right or left depends on antenna config.)
servo1.write(0);
servo2.write(0);
delay(5); //just a simple wait
Serial.print("In, Cal\t");
Serial.print(voltage);
Serial.print("\t");
Serial.println(caliset);
void endprogram(){
Serial.print("Calibrated to: ");
loopy:
goto loopy;
SEE ERROR MESSAGE BELOW
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:avr:uno -build-cache /tmp -build-path /tmp/643865547/build -verbose -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.7.0 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -libraries /tmp/643865547/custom -libraries /tmp/643865547/pinned /tmp/643865547/homingbot_robowarnerV1
Sketch uses 4274 bytes (13%) of program storage space. Maximum is 32256 bytes.
Global variables use 348 bytes (16%) of dynamic memory, leaving 1700 bytes for local variables. Maximum is 2048 bytes.
Programming with: Serial
Flashing with command:/Users/andrewdurant/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude -C/Users/andrewdurant/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem1411 -b115200 -D -Uflash:w:/var/folders/j3/80whw0_j2ts6lqk_1fcxx8fr0000gn/T/arduino-create-agent720604024/homingbot_robowarnerV1.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/andrewdurant/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf"
User configuration file is "/Users/andrewdurant/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1411
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
