Hello! I'm using LCD 1206A and DHT22 with arrangement that of the picture attached. The screen works well but doesn't display anything. The problem seems to be in the code as upon input (Exit Status 1, error compiling for board Arduino/Genuino UNO).
#include <DHT.h>
#include <LiquidCrystal.h>
// Pin connected to the sensor data pin
#define DHTPIN 7
// Display pins
LiquidCrystal LCD (12, 11, 5, 4, 3, 2);
// Use the line according to the sensor model
// #define DHTTYPE DHT11 // Sensor DHT11
#define DHTTYPE DHT22 DHT Sensor 22 (AM2302)
// #define DHTTYPE DHT21 // DHT Sensor 21 (AM2301)
// Definitions sensor: pin, type
DHT DHT (DHTPIN, DHTTYPE);
// Array symbol degree
byte level [8] = {B00001100,
B00010010,
B00010010,
B00001100,
B00000000,
B00000000,
B00000000,
B00000000,
void setup ()
// Initialize the display
lcd.begin (16, 2);
lcd.clear ();
// Create the custom character with the symbol of the degree
lcd.createChar (0, degree);
// Information on the initial display
lcd.setCursor (0, 0);
lcd.print ("Temp. : ");
lcd.setCursor (13.0);
// Shows the symbol of the degree
lcd.write (byte (0));
lcd.print ("C");
lcd.setCursor (0.1);
lcd.print ("Humid. : ");
lcd.setCursor (14.1);
lcd.print ("%");
Serial.begin (9600);
Serial.println ("Waiting for data ...");
// Starts DHT sensor
dht.begin ();
void loop ()
// Wait 2 seconds between the measurements
delay (2000);
// Moisture reading
dht.readHumidity float h = ();
// Reading of temperature (Celsius)
t = dht.readTemperature float ();
// Check if the sensor is responding
if (isnan (h) || isnan (t))
Serial.println ("Failed to read DHT sensor data !!!");
return;
// Display the temperature in the serial monitor and display
Serial.print ("Temperature: ");
Serial.print (t);
lcd.setCursor (8.0);
lcd.print (t);
Serial.print (" C * ");
// Show the moisture in the serial monitor and display
Serial.print ("humidity: ");
Serial.print (h);
Serial.println (" %");
lcd.setCursor (8.1);
lcd.print (h);
Is there anything I miss?
