Exit status 1 Error compiling for board Arduino MKR WiFi 1010
I'm trying to use arduino explore iot kit. If I use the web editor there is no problem, but if I use the arduino ide on my PC I have that error:
exit status 1
Error compiling for board Arduino MKR WiFi 1010.
Can anyone had and solve that issue?
I have Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino MKR WiFi 1010".
I'm not able to attach the sketch and error file but I can copy paste in case.
Thank you!
Hi @alfonsodalessandro
This is the very generic error message that only tells you that something went wrong. There are a near infinite number of possible causes.
Except for in very rare cases, there will always be detailed error messages above this one that tell you what the specific problem is that caused the error. You have to scroll the black output pane at the bottom of the Arduino IDE window up to see them.
When asking for help on the forum, you should always provide the full and exact text of these error messages, as they will contain information we need to help you.
Please do this:
  1. When you encounter an error, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
  2. Open a forum reply here by clicking the Reply button.
  3. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  4. Press Ctrl+V.
    This will paste the compilation output into the code block.
  5. Move the cursor outside of the code block markup before you add any additional text to your reply.
  6. Click the Reply button to post the output.
Most of the time we're happy that you can't :wink: It saves us from downloading :slight_smile:
Please post your code as well, using the code tags button </> as described by @in0.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project :wink: See About the IDE 1.x category.
This is the error:
Library Arduino_MCHPTouch has been declared precompiled:
Using precompiled library in C:\Users\ad\Documents\Arduino\libraries\Arduino_MCHPTouch\src\cortex-m0plus
In file included from C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_BusIO_Register.h:1:0,
                 from C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp:1:
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:9:36: error: 'TwoWire' has not been declared
   Adafruit_I2CDevice(uint8_t addr, TwoWire *theWire = &Wire);
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:28:3: error: 'TwoWire' does not name a type; did you mean 'TwoWire_h'?
   TwoWire *_wire;
   TwoWire_h
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:9:55: error: could not convert '& Wire' from 'arduino::TwoWire*' to 'int*'
In file included from C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:1:0:
   TwoWire *_wire;
   TwoWire_h
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:11:1: error: prototype for 'Adafruit_I2CDevice::Adafruit_I2CDevice(uint8_t, arduino::TwoWire*)' does not match any in class 'Adafruit_I2CDevice'
 Adafruit_I2CDevice::Adafruit_I2CDevice(uint8_t addr, TwoWire *theWire) {
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:7:7: error: candidates are: constexpr Adafruit_I2CDevice::Adafruit_I2CDevice(Adafruit_I2CDevice&&)
 class Adafruit_I2CDevice {
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:7:7: error:                 constexpr Adafruit_I2CDevice::Adafruit_I2CDevice(const Adafruit_I2CDevice&)
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO/Adafruit_I2CDevice.h:9:3: error:                 Adafruit_I2CDevice::Adafruit_I2CDevice(uint8_t, int*)
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::begin(bool)':
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:30:3: error: '_wire' was not declared in this scope
   _wire->begin();
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:30:3: note: suggested alternative: 'Wire'
   _wire->begin();
   Wire
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::detected()':
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:51:3: error: '_wire' was not declared in this scope
   _wire->beginTransmission(_addr);
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:51:3: note: suggested alternative: 'Wire'
   Wire
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::write(uint8_t*, size_t, bool, uint8_t*, size_t)':
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:81:3: error: '_wire' was not declared in this scope
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:81:3: note: suggested alternative: 'Wire'
   Wire
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::read(uint8_t*, size_t, bool)':
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:160:17: error: '_wire' was not declared in this scope
   size_t recv = _wire->requestFrom((uint8_t)_addr, (uint8_t)len, (uint8_t)stop);
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:160:17: note: suggested alternative: 'Wire'
                 Wire
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp: In member function 'bool Adafruit_I2CDevice::setSpeed(uint32_t)':
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:228:3: error: '_wire' was not declared in this scope
   _wire->setClock(desiredclk);
C:\Users\ad\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:228:3: note: suggested alternative: 'Wire'
   Wire
exit status 1
option enabled in File -> Preferences.
This is the code:
#include <Arduino_MKRIoTCarrier.h>
MKRIoTCarrier carrier;
// variables
float temperature = 0;
float humidity = 0;
float pressure = 0;
int light = 0;
int r,g,b;
// gyroscope
float Gx, Gy, Gz;
//accelerometer
float Ax, Ay, Az;
//track how many measurements have been made
int counter = 0;
// file object
File dataFile;
  //Initialize the MKR IoT carrier and output any errors in the serial monitor
  CARRIER_CASE = false;
  carrier.begin();
  // init SD card
  if (!SD.begin(SD_CS)) {
    carrier.display.setTextSize(2);
    carrier.display.setCursor(35, 70);
    carrier.display.print("SD card failed");
    carrier.display.setCursor(45, 110);
    carrier.display.print("to initialise");
    while (1);
  // init the logfile
  dataFile = SD.open("log-0000.csv", FILE_WRITE);
  // init the CSV file with headers
  dataFile.println("temperature,humidity,pressure,light,Ax,Ay,Az,Gx,Gy,Gz");
  // close the file
  dataFile.close();
  delay(100);
  // init the logfile
  // read the sensors values
  temperature = carrier.Env.readTemperature();
  humidity = carrier.Env.readHumidity();
  pressure = carrier.Pressure.readPressure();
  while(!carrier.Light.colorAvailable()){
    delay(5);
  carrier.Light.readColor(r, g, b, light);
  // read the IMU values
  carrier.IMUmodule.readAcceleration(Ax, Ay, Az);
  carrier.IMUmodule.readGyroscope(Gx, Gy, Gz);
    // print each of the sensor values
  dataFile.print(temperature);
  dataFile.print(",");
  dataFile.print(humidity);
  dataFile.print(pressure);
  dataFile.print(light);
  dataFile.print(Ax);
  dataFile.print(Ay);
  dataFile.print(Az);
  dataFile.print(Gx);
  dataFile.print(Gy);
  dataFile.print(Gz);
  dataFile.println(",");
  dataFile.close();
    counter += 1;
  carrier.display.fillScreen(ST77XX_BLACK); //red background
  carrier.display.setTextColor(ST77XX_WHITE); //white text
  carrier.display.setTextSize(4); //medium sized text
  carrier.display.setCursor(100, 70);
  carrier.display.print(counter);
  carrier.display.setCursor(35, 125);
  carrier.display.print("Measures taken");
  // wait 1 second to print again
thank you!
Looks like it cannot find I2C library
Try adding library Wire
I put servera libreries with wire in the name but looks the same
   TwoWire *_wire;
   TwoWire_h
   TwoWire *_wire;
   TwoWire_h
   _wire->begin();
   _wire->begin();
   Wire
   Wire
   Wire
                 Wire
   Wire
exit status 1
Why would you do that? Those are not the droids you are looking for. Wire is Arduino library, you don’t install it, it should already exist with your platform. But to use it in sketch you have to include it. When you “Add Library”, IDE includes it for you.
Sorry I don't understand. What I have to do to solve the issue?
Thank you.
As I said, try adding the library with IDE option. You might need to add SPI library too (or not)
Sorry I try SPI and wire buth nothing...any other idea please?
Thank you.
Why do you need adafruit library? Start again, fresh sketch, include SPI and Wire, post the errors
#include <SPI.h>
#include <Wire.h>
// variables
float humidity = 0;
float pressure = 0;
int light = 0;
int r,g,b;
// gyroscope
float Gx, Gy, Gz;
//accelerometer
float Ax, Ay, Az;
int counter = 0;
// file object
File dataFile;
  carrier.begin();
  // init SD card
    while (1);
  // init the logfile
  // close the file
  dataFile.close();
  delay(100);
  // init the logfile
    delay(5);
  dataFile.print(Ax);
  dataFile.print(Ay);
  dataFile.print(Az);
  dataFile.print(Gx);
  dataFile.print(Gy);
  dataFile.print(Gz);
  dataFile.close();
    counter += 1;
   TwoWire *_wire;
   TwoWire_h
   TwoWire *_wire;
   TwoWire_h
   _wire->begin();
   _wire->begin();
   Wire
   Wire
   Wire
                 Wire
   Wire
exit status 1
Could you temporary rename this into
C:\Users\ad\Documents\Arduino\libraries_old
and create another empty
then restart IDE and recompile
sketch_jan26b:1:10: error: too many decimal points in number
sketch_jan26b:1:32: error: too many decimal points in number
sketch_jan26b:14:32: error: stray '\' in program
sketch_jan26b:14:38: error: stray '\' in program
sketch_jan26b:14:41: error: stray '\' in program
sketch_jan26b:14:51: error: stray '\' in program
sketch_jan26b:14:59: error: stray '\' in program
sketch_jan26b:14:69: error: stray '\' in program
sketch_jan26b:14:87: error: stray '\' in program
sketch_jan26b:14:91: error: stray '\' in program
sketch_jan26b:15:25: error: stray '\' in program
sketch_jan26b:15:31: error: stray '\' in program
sketch_jan26b:15:34: error: stray '\' in program
sketch_jan26b:15:44: error: stray '\' in program
sketch_jan26b:15:52: error: stray '\' in program
sketch_jan26b:15:62: error: stray '\' in program
sketch_jan26b:16:25: error: stray '\' in program
sketch_jan26b:16:31: error: stray '\' in program
sketch_jan26b:16:34: error: stray '\' in program
sketch_jan26b:16:44: error: stray '\' in program
sketch_jan26b:16:52: error: stray '\' in program
sketch_jan26b:16:62: error: stray '\' in program
sketch_jan26b:16:77: error: stray '\' in program
sketch_jan26b:17:3: error: stray '\' in program
sketch_jan26b:17:9: error: stray '\' in program
sketch_jan26b:17:12: error: stray '\' in program
sketch_jan26b:17:22: error: stray '\' in program
sketch_jan26b:17:30: error: stray '\' in program
sketch_jan26b:17:40: error: stray '\' in program
sketch_jan26b:20:25: error: stray '\' in program
sketch_jan26b:20:31: error: stray '\' in program
sketch_jan26b:20:34: error: stray '\' in program
sketch_jan26b:20:44: error: stray '\' in program
sketch_jan26b:20:52: error: stray '\' in program
sketch_jan26b:20:62: error: stray '\' in program
sketch_jan26b:20:77: error: stray '\' in program
sketch_jan26b:21:3: error: stray '\' in program
sketch_jan26b:21:9: error: stray '\' in program
sketch_jan26b:21:12: error: stray '\' in program
sketch_jan26b:21:22: error: stray '\' in program
sketch_jan26b:21:30: error: stray '\' in program
sketch_jan26b:21:40: error: stray '\' in program
sketch_jan26b:24:3: error: stray '\' in program
sketch_jan26b:24:9: error: stray '\' in program
sketch_jan26b:24:12: error: stray '\' in program
sketch_jan26b:24:22: error: stray '\' in program
sketch_jan26b:24:30: error: stray '\' in program
sketch_jan26b:24:40: error: stray '\' in program
sketch_jan26b:28:3: error: stray '\' in program
sketch_jan26b:28:9: error: stray '\' in program
sketch_jan26b:28:12: error: stray '\' in program
sketch_jan26b:28:22: error: stray '\' in program
sketch_jan26b:28:30: error: stray '\' in program
sketch_jan26b:28:40: error: stray '\' in program
sketch_jan26b:31:3: error: stray '\' in program
sketch_jan26b:31:9: error: stray '\' in program
sketch_jan26b:31:12: error: stray '\' in program
sketch_jan26b:31:22: error: stray '\' in program
sketch_jan26b:31:30: error: stray '\' in program
sketch_jan26b:31:40: error: stray '\' in program
sketch_jan26b:35:3: error: stray '\' in program
sketch_jan26b:35:9: error: stray '\' in program
sketch_jan26b:35:12: error: stray '\' in program
sketch_jan26b:35:22: error: stray '\' in program
sketch_jan26b:35:30: error: stray '\' in program
sketch_jan26b:35:40: error: stray '\' in program
sketch_jan26b:38:3: error: stray '\' in program
sketch_jan26b:38:9: error: stray '\' in program
sketch_jan26b:38:12: error: stray '\' in program
sketch_jan26b:38:22: error: stray '\' in program
sketch_jan26b:38:30: error: stray '\' in program
sketch_jan26b:38:40: error: stray '\' in program
sketch_jan26b:38:55: error: stray '\' in program
sketch_jan26b:41:25: error: stray '\' in program
sketch_jan26b:41:31: error: stray '\' in program
sketch_jan26b:41:34: error: stray '\' in program
sketch_jan26b:41:44: error: stray '\' in program
sketch_jan26b:41:52: error: stray '\' in program
sketch_jan26b:41:62: error: stray '\' in program
sketch_jan26b:41:77: error: stray '\' in program
sketch_jan26b:42:3: error: stray '\' in program
sketch_jan26b:42:9: error: stray '\' in program
sketch_jan26b:42:12: error: stray '\' in program
sketch_jan26b:42:22: error: stray '\' in program
sketch_jan26b:42:30: error: stray '\' in program
sketch_jan26b:42:40: error: stray '\' in program
sketch_jan26b:45:3: error: stray '\' in program
sketch_jan26b:45:9: error: stray '\' in program
sketch_jan26b:45:12: error: stray '\' in program
sketch_jan26b:45:22: error: stray '\' in program
sketch_jan26b:45:30: error: stray '\' in program
sketch_jan26b:45:40: error: stray '\' in program
sketch_jan26b:46:3: error: stray '\' in program
sketch_jan26b:46:9: error: stray '\' in program
sketch_jan26b:46:12: error: stray '\' in program
sketch_jan26b:46:22: error: stray '\' in program
sketch_jan26b:46:30: error: stray '\' in program
sketch_jan26b:46:40: error: stray '\' in program
sketch_jan26b:49:3: error: stray '\' in program
sketch_jan26b:49:9: error: stray '\' in program
sketch_jan26b:49:12: error: stray '\' in program
sketch_jan26b:49:22: error: stray '\' in program
sketch_jan26b:49:30: error: stray '\' in program
sketch_jan26b:49:40: error: stray '\' in program
sketch_jan26b:49:55: error: stray '\' in program
sketch_jan26b:50:3: error: stray '\' in program
sketch_jan26b:50:9: error: stray '\' in program
sketch_jan26b:50:12: error: stray '\' in program
sketch_jan26b:50:22: error: stray '\' in program
sketch_jan26b:50:30: error: stray '\' in program
sketch_jan26b:50:40: error: stray '\' in program
sketch_jan26b:50:55: error: stray '\' in program
sketch_jan26b:53:3: error: stray '\' in program
sketch_jan26b:53:9: error: stray '\' in program
sketch_jan26b:53:12: error: stray '\' in program
sketch_jan26b:53:22: error: stray '\' in program
sketch_jan26b:53:30: error: stray '\' in program
sketch_jan26b:53:40: error: stray '\' in program
sketch_jan26b:53:55: error: stray '\' in program
sketch_jan26b:57:3: error: stray '\' in program
sketch_jan26b:57:9: error: stray '\' in program
sketch_jan26b:57:12: error: stray '\' in program
sketch_jan26b:57:22: error: stray '\' in program
sketch_jan26b:57:30: error: stray '\' in program
sketch_jan26b:57:40: error: stray '\' in program
sketch_jan26b:57:55: error: stray '\' in program
sketch_jan26b:58:3: error: stray '\' in program
sketch_jan26b:58:9: error: stray '\' in program
sketch_jan26b:58:12: error: stray '\' in program
sketch_jan26b:58:22: error: stray '\' in program
sketch_jan26b:58:30: error: stray '\' in program
sketch_jan26b:58:40: error: stray '\' in program
sketch_jan26b:58:55: error: stray '\' in program
sketch_jan26b:61:3: error: stray '\' in program
sketch_jan26b:61:9: error: stray '\' in program
sketch_jan26b:61:12: error: stray '\' in program
sketch_jan26b:61:22: error: stray '\' in program
sketch_jan26b:61:30: error: stray '\' in program
sketch_jan26b:61:40: error: stray '\' in program
sketch_jan26b:61:55: error: stray '\' in program
sketch_jan26b:65:3: error: stray '\' in program
sketch_jan26b:65:9: error: stray '\' in program
sketch_jan26b:65:12: error: stray '\' in program
sketch_jan26b:65:22: error: stray '\' in program
sketch_jan26b:65:30: error: stray '\' in program
sketch_jan26b:65:40: error: stray '\' in program
sketch_jan26b:65:55: error: stray '\' in program
sketch_jan26b:66:3: error: stray '\' in program
sketch_jan26b:66:9: error: stray '\' in program
sketch_jan26b:66:12: error: stray '\' in program
sketch_jan26b:66:22: error: stray '\' in program
sketch_jan26b:66:30: error: stray '\' in program
sketch_jan26b:66:40: error: stray '\' in program
sketch_jan26b:66:55: error: stray '\' in program
sketch_jan26b:69:3: error: stray '\' in program
sketch_jan26b:69:9: error: stray '\' in program
sketch_jan26b:69:12: error: stray '\' in program
sketch_jan26b:69:22: error: stray '\' in program
sketch_jan26b:69:30: error: stray '\' in program
sketch_jan26b:69:40: error: stray '\' in program
sketch_jan26b:69:55: error: stray '\' in program
sketch_jan26b:73:3: error: stray '\' in program
sketch_jan26b:73:9: error: stray '\' in program
sketch_jan26b:73:12: error: stray '\' in program
sketch_jan26b:73:22: error: stray '\' in program
sketch_jan26b:73:30: error: stray '\' in program
sketch_jan26b:73:40: error: stray '\' in program
sketch_jan26b:73:55: error: stray '\' in program
sketch_jan26b:74:3: error: stray '\' in program
sketch_jan26b:74:9: error: stray '\' in program
sketch_jan26b:74:12: error: stray '\' in program
sketch_jan26b:74:22: error: stray '\' in program
sketch_jan26b:74:30: error: stray '\' in program
sketch_jan26b:74:40: error: stray '\' in program
sketch_jan26b:74:55: error: stray '\' in program
sketch_jan26b:77:3: error: stray '\' in program
sketch_jan26b:77:9: error: stray '\' in program
sketch_jan26b:77:12: error: stray '\' in program
sketch_jan26b:77:22: error: stray '\' in program
sketch_jan26b:77:30: error: stray '\' in program
sketch_jan26b:77:40: error: stray '\' in program
sketch_jan26b:77:55: error: stray '\' in program
sketch_jan26b:81:3: error: stray '\' in program
sketch_jan26b:81:9: error: stray '\' in program
sketch_jan26b:81:12: error: stray '\' in program
sketch_jan26b:81:22: error: stray '\' in program
sketch_jan26b:81:30: error: stray '\' in program
sketch_jan26b:81:40: error: stray '\' in program
sketch_jan26b:81:55: error: stray '\' in program
sketch_jan26b:82:3: error: stray '\' in program
sketch_jan26b:82:9: error: stray '\' in program
sketch_jan26b:82:12: error: stray '\' in program
sketch_jan26b:82:22: error: stray '\' in program
sketch_jan26b:82:30: error: stray '\' in program
sketch_jan26b:82:40: error: stray '\' in program
sketch_jan26b:82:55: error: stray '\' in program
sketch_jan26b:85:3: error: stray '\' in program
sketch_jan26b:85:9: error: stray '\' in program
sketch_jan26b:85:12: error: stray '\' in program
sketch_jan26b:85:22: error: stray '\' in program
sketch_jan26b:85:30: error: stray '\' in program
sketch_jan26b:85:40: error: stray '\' in program
sketch_jan26b:85:55: error: stray '\' in program
sketch_jan26b:1:1: error: 'Arduino' does not name a type; did you mean 'Arduino_h'?
 Arduino_h
sketch_jan26b:19:37: error: expected unqualified-id before '^' token
sketch_jan26b:23:37: error: expected unqualified-id before '^' token
sketch_jan26b:24:122: error: 'did' does not name a type; did you mean 'div'?
        div
sketch_jan26b:26:4: error: expected unqualified-id before '^' token
sketch_jan26b:30:56: error: expected unqualified-id before '^' token
sketch_jan26b:31:122: error: 'did' does not name a type; did you mean 'div'?
        div
sketch_jan26b:33:4: error: expected unqualified-id before '^' token
sketch_jan26b:37:56: error: expected unqualified-id before '^' token
exit status 1
sketch you are trying to compile is not C++. I’m sorry but helping you at this point is beyond my capabilities
sorry I put the wrong code:
sketch_jan26b:3:10: fatal error: Arduino_MKRIoTCarrier.h: No such file or directory
compilation terminated.
exit status 1
Sorry now works! Thank you!
But why this strange behavior? Why I have to delete the folder?
Thank you.
