Expanded scale on a LCD bargraph?
Hello all
I am trying to make a 16.4v battery monitor bargraph on 2 lines: one with a full length scale corresponding to an AnalogInput of 0 to 4.4 Volts; the other line is to display the full value of the Battery, diminishing as it is used.
First with the usual R divider I bring back the In value from 16.4 to 5 v. The important part is to monitor precisely the last 4.4V.
I tried to use the map function, but get nowhere.
What is your advice to get it work ?
Thanks !
Please post your best attempt
The easier you make it to read and copy the code the more likely it is that you will get help
Please follow the advice given in the link below when posting code
OK thanks for your help, here is the code to which I added my reasoning:
Robojax is a guy who seems to have m
 // I have set up a divider so the analog input would not exceed 5V.
#include <Wire.h>
#include <LcdBarGraphRobojax.h>
byte lcdNumCols = 16; // -- number of columns in the LCD
byte lcdLine = 2; // -- number of line in the LCD
byte sensorPin = 0; // -- value for this example
float inpuValue;//all sorts of variables I tried to use to decompose what was going on
float voltage;
float affichage;
float bat;
LiquidCrystal_I2C lcd(0x27, lcdNumCols, lcdLine); // -- creating LCD instance
LcdBarGraphRobojax lbg(&lcd, 16, 0, 0);  // -- creating 16 character long bargraph starting at char 0 of line 0 (see video)
  // -- initializing the LCD
  lcd.backlight();      // Make sure backlight is on
  lcd.init();
  // -- do some delay: some time I've got broken visualization, says the guy from whom I took the LCD part
  inpuValue = analogRead(sensorPin);
  affichage = inpuValue * (5.0 / 1023.0);
  float voltage = map(analogRead(sensorPin), 0, 1023, 0, 900); //normally, this should map an analog input which will span :
  // seen from the battery values : 16.4V to 12V, that is a 4.4 V span.
  // so, 0 to 4.4V on the A0 should be mapped as 0 to 1023 in the first variable I called 'affichage'.
  // I want the bargraph to show full at 16.4 and zero at 12V.
  lbg.clearLine(1);// clear line 1 to display fresh voltage value
  // -- draw bar graph from the analog value read
  lbg.drawValue(voltage, 1023);
  // here on the 2nd line I want to find or compute back the value of the total batt from the value at A0. Since it is 4.4, I need to add 12V constant.
  lcd.setCursor (0, 1);
  lcd.print("Bat");
  bat = affichage + 12; //
  lcd.setCursor (3, 1);
  lcd.print(bat);
  // then  I want the actuel value at A0 to be in Volts (from 4.4V to 0V as the battery decreases) and displayed.
  lcd.setCursor (9 , 1); //
  lcd.print("Vr:");
  lcd.print(affichage); //
  delay(200);
What is the range of input of lbg.drawValue()? For now, I will guess 0 to 16.
  float BatteryVoltage = inpuValue * (16.4 / 1023.0);
  // Constrain to range of interest
  if (BatteryVoltage < 12.0)  // Less than 12.0V
    BatteryVoltage = 12.0;
  if (BatteryVoltage > 16.4) // More than 16.4V
    BatteryVoltage = 16.4;
  // Convert range from 12.0-16.4 to 0-16
  int DisplayValue = ((BatteryVoltage - 12.0) / 4.4) * 16;
  lbg.drawValue(DisplayValue, 1023);
Dear John
Thanks a lot. The lbg.drawValue comes from a lib cre
Sorry !
I meant that the lbg.drawValue was some command from the custom lib written by this guy Robojax. I suppose it means the line of the bargraph will have 16 blocks of display.
I will try your sketch.
What I already have learned is ths use of 'constrain', which does answer to a pat of my concern.
I'll keep you posted !
Thanks again
OK, I have made it:
#include <Wire.h>
float voltage;
float affichage;
float bat;
  lcd.init();
  float voltage = map(analogRead(sensorPin), 0, 900, 0, 1023); //normally, this should map an analog input which will span :
  // (seen from the battery values : 16.4V to 12V, that is a 4.4 V span).
  // so, 0 to 4.4V on the A0 is equiv to 0 to 900, should be mapped as 0 to 1023 in the  variable I called 'voltage'.
  lcd.print("Bat");
  lcd.print(bat);
  lcd.print("Vr:");
  delay(200);
This works as I wanted.
Thanks for helping !
Have a good evening
