expected primary expression before '.' token
I have copied some Sparkfun code for interfacing a IG3200 gyro with my arduino. When I compile I get an error "expected primary expression before '.' token.
The code following code line gets highlited:
static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
Any ideas as to what the error is:
   ITG-3200 Test Code
      April 28, 2010
      by: Jim Lindblom
      License: Creative Commons Attribution Share-Alike 3.0
      http://creativecommons.org/licenses/by-sa/3.0
      ITG-3200 Triple-axis Digital Output Gyroscope test code. Streams the three axis output of the gyro.
      Provides options to average the readings, and modify the sample rate, DLPF, and power management registers.
      Tested on a 3.3V 8MHz Arduino Pro
      10kOhm pull-ups on I2C lines.
      VDD & VIO = 3.3V
      SDA -> A4 (PC4)
      SCL -> A5 (PC5)
      INT -> D2 (PB2) (or no connection, not used here)
      CLK -> GND
#include <stdlib.h>
#include <stdio.h>
#include <avr/io.h>
#include "i2c.h"
#include "itg320.h"
#define FOSC 8000000
#define ITG3200_R 0xD3      // ADD pin is pulled high
#define ITG3200_W 0xD2      // So address is 0x69
#define sbi(var, mask)   ((var) |= (uint8_t)(1 << mask))
#define cbi(var, mask)   ((var) &= (uint8_t)~(1 << mask))
///============Function Prototypes=========/////////////////
char ITG3200Read(unsigned char address);
void ITG3200Write(unsigned char address, unsigned char data);
void ITG3200ViewRegisters(void);
int checkInterrupt(void);
void getITG3200(int average);
void ITG3200BlockRead(unsigned char address);
///============General Use Prototypes=====//////////////////;
void ioinit(void);
void UART_Init(unsigned int ubrr);
static int uart_putchar(char c, FILE *stream);
void put_char(unsigned char byte);
uint8_t uart_getchar(void);
void delay_ms(uint16_t x);
int main(void)
      char temp;
      unsigned int i = 0;
      int average = 1;
      unsigned short sample = 128;
      unsigned short dlpf = 0;
      unsigned char power = 0;
      long int count = 0;
      ioinit();
      i2cInit();
      delay_ms(100);
      ITG3200Write(PWR_M, 0x80);      // Reset to defaults
      ITG3200Write(SMPL, 0x00);      // SMLPRT_DIV = 0
      ITG3200Write(DLPF, 0x18);      // DLPF_CFG = 0, FS_SEL = 3
      ITG3200Write(INT_C, 0x05);      // Generate interrupt when device is ready or raw data ready
      ITG3200Write(PWR_M, 0x00);
      delay_ms(1000);
      while(1)
            printf("\nITG-3200 Configuration Menu\n");
            printf("---------------------------\n");
            printf("1) Stream Values\n");
            printf("2) Change average value (currently %d)\n", average);
            printf("3) Change Sample Rate Divider (currently %d)\n", ITG3200Read(SMPL));
            printf("4) Adjust digital low pass filter (currently %d)\n", (ITG3200Read(DLPF)&0x07));
            printf("5) Adjust Power Management Register (currently 0x%x)\n", ITG3200Read(PWR_M));
            printf("6) View all ITG-3200 Registers\n");
            temp = uart_getchar();
            if (temp == '1')
                  count = 0;
                  printf("\nStreaming, press any key to stop...\n\n");
                  printf("Count       x       y       z\n");
                  printf("-----      ---      ---      ---\n");
                  while(!(UCSR0A & (1<<RXC0)))
                        printf("%ld:", count);
                        getITG3200(average);
                        count++;
                  temp = UDR0;
            else if (temp == '2')
                  i = 0;
                  average = 0;
                  printf("\nType the new average value followed by the enter key...\n");
                  while (1)
                        if (temp == 0x0D)
                        else if ((temp>=0x30)&&(temp<=0x39))
                              temp -= 0x30;
                              printf("%d", temp);
                              average *= 10;
                              average += temp;
                              i++;
                  printf("\n");
                  if (average == 0) average = 1;
            else if (temp == '3')
                  i = 0;
                  sample = 0;
                  printf("\nType the new sample rate divider (0-255) followed by the enter key...\n");
                  printf("Sample Rate = (8KHz or 1KHz [determined by DLPF])/(divider +1)\n");
                  while (1)
                        if (temp == 0x0D)
                              temp -= 0x30;
                              printf("%d", temp);
                              sample *= 10;
                              sample += temp;
                              i++;
                  ITG3200Write(SMPL, sample);
                  printf("\n");
            else if (temp == '4')
                  printf("\nType the new DLPF value (0-6)...\n");
                  printf("DLPF      LPF-BW      Sample Rate\n");
                  printf("0      256Hz      8kHz\n");
                  printf("1      188Hz      1kHz\n");
                  printf("2      98Hz      1kHz\n");
                  printf("3      42Hz      1kHz\n");
                  printf("4      20Hz      1kHz\n");
                  printf("5      10Hz      1kHz\n");
                  printf("6      5Hz      1kHz\n");
                  while (1)
                        if ((temp>=0x30)&&(temp<=0x36))
                              dlpf = temp - 0x30;
                              printf("Invalid\n");
                  temp = 0b00011000 | dlpf;
                  ITG3200Write(DLPF, temp);
            else if (temp == '5')
                  printf("\nEnter a 8-bit hex value...\n");
                  printf("0x");
                        temp -= 0x30;
                        printf("%x", temp);
                  else if ((temp>=0x41)&&(temp<=0x46))
                        temp -= 55;
                        printf("%x", temp);
                  else if ((temp>=0x61)&&(temp<=0x66))
                        temp -= 87;
                        printf("%x", temp);
                        temp = 0;
                  power = temp << 4;
                        temp -= 0x30;
                        printf("%x", temp);
                        temp -= 55;
                        printf("%x", temp);
                        temp -= 87;
                        printf("%x", temp);
                        temp = 0;
                  temp &= 0x0F;
                  power |= temp;
                  printf("\n");
                  ITG3200Write(PWR_M, power);
            else if (temp == '6')
                  ITG3200ViewRegisters();
      char data;
      cbi(TWCR, TWEN);      // Disable TWI
      sbi(TWCR, TWEN);      // Enable TWI
      i2cSendStart();
      i2cWaitForComplete();
      i2cSendByte(ITG3200_W);      // write 0xD2
      i2cSendByte(address);      // write register address
      i2cSendStart();
      i2cSendByte(ITG3200_R);      // write 0xD3
      i2cReceiveByte(FALSE);
      data = i2cGetReceivedByte();      // Get MSB result
      i2cSendStop();
      return data;
      i2cSendStart();
      i2cSendByte(ITG3200_W);      // write 0xB4
      i2cSendByte(data);
      i2cSendStop();
      printf("\nWHO_AM_I (0x00): 0x%x\n", ITG3200Read(WHO));
      delay_ms(1000);
      printf("SMPLRT_DIV (0x15): 0x%x\n", ITG3200Read(SMPL));
      printf("DLPF_FS (0x16): 0x%x\n", ITG3200Read(DLPF));
      printf("INT_CFG (0x17): 0x%x\n", ITG3200Read(INT_C));
      printf("INT_STATUS (0x1A): 0x%x\n", ITG3200Read(INT_S));
      printf("TEMP_OUT_H (0x1B): 0x%x\n", ITG3200Read(TMP_H));
      printf("TEMP_OUT_L (0x1C): 0x%x\n", ITG3200Read(TMP_L));
      printf("GYRO_XOUT_H (0x1D): 0x%x\n", ITG3200Read(GX_H));
      printf("GYRO_XOUT_L (0x1E): 0x%x\n", ITG3200Read(GX_L));
      printf("GYRO_YOUT_H (0x1F): 0x%x\n", ITG3200Read(GY_H));
      printf("GYRO_YOUT_L (0x20): 0x%x\n", ITG3200Read(GY_L));
      printf("GYRO_ZOUT_H (0x21): 0x%x\n", ITG3200Read(GZ_H));
      printf("GYRO_ZOUT_L (0x22): 0x%x\n", ITG3200Read(GZ_L));
      printf("PWR_MGM (0x3E): 0x%x\n", ITG3200Read(PWR_M));
      if ((PIND & (1<<2)) == 0)
            return 0;
            return 1;
      char temp;
      signed int gx[average], gy[average], gz[average];
      signed int gyrox = 0;
      signed int gyroy = 0;
      signed int gyroz = 0;
      unsigned int i;
      for (i = 0; i<average; i++)
            while (!(ITG3200Read(INT_S) & 0x01))
            temp = 0;
            temp = ITG3200Read(GY_H);
            gy[i] = temp << 8;
            gy[i] |= ITG3200Read(GY_L);
            //while (!(ITG3200Read(INT_S) & 0x01))
            temp = 0;
            temp = ITG3200Read(GZ_H);
            gz[i] = temp << 8;
            gz[i] |= ITG3200Read(GZ_L);
            temp = 0;
            temp = ITG3200Read(GX_H);
            gx[i] = temp << 8;
            gx[i] |= ITG3200Read(GX_L);
            gyrox += gx[i];
            gyroy += gy[i];
            gyroz += gz[i];
      gyrox = gyrox/average;
      gyroy = gyroy/average;
      gyroz = gyroz/average;
      printf("      %d      %d      %d\n", gyrox, gyroy, gyroz);
 ****Initialize****
void ioinit (void)
    //1 = output, 0 = input
      DDRB = 0b01100000; //PORTB4, B5 output
    DDRC = 0b00010011; //PORTC4 (SDA), PORTC5 (SCL)
    DDRD = 0b11111010; //PORTD (RX on PD0)
      PORTC = 0b00110000; //pullups on the I2C bus
      //sbi(PORTD, 2);
      UART_Init(8);      // U2X0 is set! - 115200bps @ 8MHz
      // Set baud rate
      UBRR0H = ubrr>>8;
      UBRR0L = ubrr;
      // Enable receiver and transmitter
      UCSR0A = (1<<U2X0);
      UCSR0B = (1<<RXEN0)|(1<<TXEN0);
      // Set frame format: 8 bit, no parity, 1 stop bit,
      UCSR0C = (1<<UCSZ00)|(1<<UCSZ01);
      stdout = &mystdout; //Required for printf init
    if (c == '\n') uart_putchar('\r', stream);
    loop_until_bit_is_set(UCSR0
Sure. There is no file system on the Arduino, so you can't create a FILE object.
Where did you copy this code from? It certainly doesn't look like Arduino code.
I copied it from the sparkfun.com site. I guess the code is writing the gyro output to a file. Is there a way around this?
It's a pretty big site, with lots of code...
Yes. Don't write the data to a file.
Yes, ok thanks. Learning the obvious is not immediately apparent :slight_smile:
That whole page seems screwed up. That code contains a main() function. Arduino sketches do not.
The comments talk about how to get correct temperature readings from it. WTF?
There is mention of using it in the AeroQuad project, so it just might be time to hit up google.
That code should compile with 0 errors on AvrStudio, if you dont use it you need to port it to arduino c/c++.
With the proper coding you can use the FILE to stream data to printf over the serial port to a computer.
Thanks for the help. I am using the gyro in the aeroquad project but wanted to understand how the gyro communicated with the arduino and also to understand the data coming from it - thus my attempt at using the code from sparkfun. A steep learning curve when you are trying to also figure out the programming language - but fun none-the-less. Dont know about avrstudio (yet).
