Expected signature for atmega 8 is 1e 93 07
Hello there, sorry for repeating the same issue. Few months Earlier I was facing issue when uploading bootloader to a bare atmega 8a using arduino nano. It showed expected signature for atmega 8 is 1e 93 07.
I had posted the issue in arduino forum and found out that it was a connection problem and I solved by replacing the slack jumper wire.
But at present, although I am able to boatload my pre-bootloaded atmega 8a ic but when i try brand new one using the same wiring diagram (even I just swap out existing chip with the new one on the same breadboard) it fails and error massage is like signature error. It is the same error I had faced earlier. I have tried 5 ICs results are the same. I have double checked all the connections and all are looking good.
Mysterious thing is I have purchased all the chips at a time.
Don’t know how to solve this please help.
Hi and welcome back!
I think that's good, the solution is likely to be the same for all of them.
If it is a genuine chip from a reliable source, then the default CPU clock is 1 MHz, divided down by a factor of 8 from the internal 8 MHz RC oscillator. The ISP programmer MUST use a clock rate of less than 250 kHz to program the device.
use AVRDUDE for burning code. first make your Arduino code as hex and upload it using Arduino nano as isp programmer in AVRDUDE in your atmega8a.
Sorry i couldn’t get that. What i need to do?
I tried internal 8 mhz clock but it is the same error.
How can I make my arduino code into hex. And what is avrdude? Can you please give me details and sorry I am kind of new comer.
I am using atmega NG or older(atmega 8) and arduino as ISP.
It works fine with the pre-bootloaded atmega 8a but the new one causes problem.
You need to make sure that the ISP programmer clock rate is less than 250 kHz.
For better advice, post the details of your setup, like the code, using code tags, a wiring diagram, etc.
See this excellent tutorial: Gammon Forum : Electronics : Microprocessors : How to make an Arduino-compatible minimal board
go to Arduino ide click on file , then go to preference , a dialogue box pop up , check in compile option and click on it. it will make your code in hex format. u find in your compiling window and in your %temp% file location. avrdude is a programme to burn hex file in avr microcontroller. u can find it in internet as avrdude gui . u don't need to burn bootloader in avrdude.
I have tried Gammon Forum] tutorial.
It shows this with the new chip :
10:19:09.509 -> ⸮⸮⸮⸮
10:19:10.993 -> Atmega chip detector.
And this with the pre-bootloaded chip :
10:19:11.082 -> Entered programming mode OK.
10:19:11.082 -> Signature = 1E 93 07
10:19:11.082 -> Processor = ATmega8A
10:19:11.082 -> Flash memory size = 8192
10:19:11.082 -> LFuse = DF
10:19:11.082 -> HFuse = CA
10:19:11.082 -> EFuse = FF
10:19:11.082 -> Lock byte = FF
10:19:11.082 -> Clock calibration = BA
10:19:11.082 -> Bootloader in use: Yes
10:19:11.125 -> EEPROM preserved through erase: No
10:19:11.125 -> Watchdog timer always on: Yes
10:19:11.125 -> Bootloader is 1024 bytes starting at 1C00
10:19:11.125 ->
10:19:11.125 -> Bootloader:
10:19:11.125 ->
10:19:11.125 -> 1C00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.125 -> 1C60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1C70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1C80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1C90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1CF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.228 -> 1D50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1D60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1D70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1D80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1D90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1DA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1DB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.263 -> 1DC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1DD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1DE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1DF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1E00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1E10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1E20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.298 -> 1E30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1E90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1EA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1EB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1EC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1ED0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1EE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1EF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1F00: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.362 -> 1F10: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.397 -> 1F80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1F90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.431 -> 1FF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
10:19:11.494 ->
10:19:11.494 -> MD5 sum of bootloader = 9A 89 18 B1 18 78 DA 50 6F 76 1B C1 C9 C4 CE 17
10:19:11.629 ->
10:19:11.629 -> First 256 bytes of program memory:
10:19:11.629 ->
10:19:11.629 -> 0: 41 C0 65 C0 64 C0 63 C0 62 C0 61 C0 4E C3 5F C0
10:19:11.629 -> 10: 5E C0 01 C3 5C C0 CD C2 A7 C2 59 C0 58 C0 57 C0
10:19:11.629 -> 20: 56 C0 55 C0 54 C0 00 00 00 00 00 00 00 00 00 03
10:19:11.629 -> 30: 04 06 00 00 00 00 00 00 00 00 0A 0B 0C 0D 0E 0F
10:19:11.629 -> 40: 00 01 02 03 04 05 00 00 00 00 38 00 35 00 32 00
10:19:11.629 -> 50: 00 00 00 00 37 00 34 00 31 00 04 04 04 04 04 04
10:19:11.629 -> 60: 04 04 02 02 02 02 02 02 03 03 03 03 03 03 01 02
10:19:11.629 -> 70: 04 08 10 20 40 80 01 02 04 08 10 20 01 02 04 08
10:19:11.691 -> 80: 10 20 03 04 11 24 1F BE CF E5 D4 E0 DE BF CD BF
10:19:11.691 -> 90: 10 E0 A0 E6 B0 E0 EA EC F4 E1 02 C0 05 90 0D 92
10:19:11.691 -> A0: AC 38 B1 07 D9 F7 21 E0 AC E8 B0 E0 01 C0 1D 92
10:19:11.691 -> B0: AF 37 B2 07 E1 F7 10 E0 C2 E4 D0 E0 03 C0 21 97
10:19:11.691 -> C0: FE 01 D2 D9 C1 34 D1 07 D1 F7 2B D4 FC C9 98 CF
10:19:11.691 -> D0: 90 E0 FC 01 E2 59 FF 4F 24 91 86 5A 9F 4F FC 01
10:19:11.691 -> E0: 84 91 88 23 99 F0 90 E0 88 0F 99 1F FC 01 E0 5B
10:19:11.691 -> F0: FF 4F A5 91 B4 91 FC 01 EA 5B FF 4F 85 91 94 91
10:19:11.691 ->
I have tried both the circuit diagram (with and without crystal) results are the same.
For further clarity I am sharing the circuit diagram with 16mhz crystal
This is my error code :
Arduino: 1.8.18 (Windows 10), Board: "Arduino NG or older, ATmega8"
C:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega8 -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w::m -Uhfuse:w:0xca:m -Ulfuse:w:0xdf:m
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           efuse          0     0     0    0 no          0    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
Error while burning bootloader.
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
This is my Arduino IDE settings :
Today I have replaced the chip (All my chips are brought together from the same store) and I got this new error massage :
Arduino: 1.8.18 (Windows 10), Board: "ATmega8, Yes (UART0), EEPROM retained, BOD 2.7V, LTO enabled, External 16 MHz"
C:\Users\prana\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\7.2-arduino.1/bin/avrdude -CC:\Users\prana\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.0/avrdude.conf -v -patmega8 -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0xff:m -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:0b11000111:m -Ulfuse:w:0b10111111:m
avrdude: Version 7.2-arduino.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is C:\Users\prana\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\3.0.0\avrdude.conf
         Using Port                    : COM3
avrdude stk500_getsync() warning: attempt 1 of 10: not in sync: resp=0x15
avrdude stk500_getsync() warning: attempt 2 of 10: not in sync: resp=0x15
         AVR Part                      : ATmega8
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           lfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           hfuse                   0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           lock                    0     0     0    0 no          1    1      0  4500  4500 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           calibration             0     0     0    0 no          4    1      0     0     0 0x00 0x00
         Description     : Atmel STK500 version 1.x firmware
avrdude stk500_getparm() error: protocol expects OK byte 0x10 but got 0x14
avrdude stk500_getparm() error: protocol expects sync byte 0x14 but got 0x02
avrdude stk500_getparm() error: protocol expects sync byte 0x14 but got 0x10
         Hardware Version: 48164504
         Firmware Version: 0.2
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude stk500_initialize() error: protocol expects OK byte 0x10 but got 0x01
avrdude main() error: initialization failed, rc=-1
        - double check the connections and try again
        - use -B to set lower the bit clock frequency, e.g. -B 125kHz
        - use -F to override this check
avrdude stk500_disable() error: protocol expects sync byte 0x14 but got 0x10
This error code is shown only one time then the previous error code is shown as mentioned.
Another thing appears today is that after failed to burning boot loader the 'L' Led on arduino nano blinks three times continuously until I remove the external 16 mhz crystal. again If I insert the crystal the blinking issue appears. And If I reconnect the usb port then the blinking stops until another failed attempt to burning bootloader.
look at this YouTube tutorial . it may help u... https://www.youtube.com/watch?v=IYi815scN2A&ab_channel=LearnItAllAcademy®
Minicore has variant for atmega 328p/atmega328 p pu/ atmega 328 pb but it Doesn't have chip variant for atmega 8a microcontroller. It shows only atmega 8 not atmega 8a
this problem of signature mismatch may be occurred as this microcontrollers are use fuse bit lock by its previous owner. try to use avrdude software. check out this video also https://www.youtube.com/watch?v=QN0pKymphRA&ab_channel=GantengPermanen
