Expected signature for ATmega8 is 1E 93 07
Hello there, I was trying to bootload atemga 8a pu using arduino nano but it fails ans shows the below massage :
Arduino: 1.8.18 (Windows 10), Board: "Arduino NG or older, ATmega8"
avrdude: Expected signature for ATmega8 is 1E 93 07
     Double check chip, or use -F to override this check.
Error while burning bootloader.
Hi @aaqib_saad. I'm going to ask you to post some additional information that might help us to identify the problem.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to gather more information about the problem.
Please do this:
  1. Select File > Preferences... from the Arduino IDE menus.
    The "Preferences" dialog will open.
  2. Check the box next to "☐ Show verbose output during: upload" in the "Preferences" dialog.
  3. Click the OK button.
  4. Select Tools > Burn Bootloader from the Arduino IDE menus.
  5. After the "Burn Bootloader" process fails, you'll see a button on the right side of the orange bar: Copy error messages. Click that button.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the <CODE/> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  8. Press Ctrl+V. This will paste the compilation output into the code block.
  9. Move the cursor outside of the code block markup before you add any additional text to your reply.
  10. Click the Reply button to post the output.
Thank You for acknowledgement. I have tried all the YouTube solutions and Arduino forum solutions like changing the arvdude.conf file, downloading minicore etc etc. But it all didn't work.
here is the verbose error massage :
it shows two different massage
first One :
Sketch uses 3640 bytes (50%) of program storage space. Maximum is 7168 bytes.
Global variables use 200 bytes (19%) of dynamic memory, leaving 824 bytes for local variables. Maximum is 1024 bytes.
C:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega8 -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users\prana\AppData\Local\Temp\arduino_build_312449/L293d_dc_motor_speed_control.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\prana\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
         AVR Part                      : ATmega8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           efuse          0     0     0    0 no          0    0      0     0     0 0x00 0x00
An error occurred while uploading the sketch
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
         Hardware Version: 4744608
         Firmware Version: 0.4611299
         Topcard         : STK502
         Vtarget         : 1.8 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done.  Thank you.
**second one :**
     Using Port                    : COM3
     AVR Part                      : ATmega8
     PAGEL                         : PD7
     BS2                           : PC2
     RETRY pulse                   : SCK
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xff00ff
All this won't help with such signature:
As said in the programmator output, it is a connection problem or your MCU is dead.
Good news here, today I have bootloaded and uploaded the blink sketch successfully without any change to previous wiring or software. But it only worked one time the minute after it shows the same error as mentioned earlier.
What to do next?
Can you share the wiring diagram?
I'm glad you were able to complete a "Burn Bootloader" and upload operations.
The fact it worked once indicates that your wiring is already correct. The problem with it not working the second time might be caused by an intermittent connection in the wiring. I recommend carefully checking all the wires to make sure they have good connections. It is even possible that there is an internal break in a jumper wire. If you have a multimeter with a continuity tester setting (usually marked with a diode symbol), you can easily check that there is continuity on all the wiring segments of your circuit.
If you post a clear picture of your wiring in a forum reply here, the forum helpers might be able to spot a problem.
Yeah SIR, you were right. I have checked the continuity using multimeter. there was a slight slack in one of the wires. It connect in one angle but disconnect in other angle.
By replacing that wire it worked.
Such a respite !! Thank You brother.
You are welcome. I'm glad it is working now.
Regards,
Per
