I'm planning to reflash my 3D printer (GT2560 using ATmega 2560 chip like Arduino Mega) with new firmware. It's currently running the default firmware it was programmed with. As such I'd like to make a backup of the default in case something goes wrong, and I can't find enough information online about what exactly it would be running.
Now I'm not expecting to be able to convert it back from Assembly to human readable like C, I just want the data as it is (though if there's a way to convert it to Arduino native that would be great so I can get a better feeling for what settings were used etc etc).
So to sum my question; how do I extract raw program data from the board, how do I reinstall it and if possible, how do I convert it back to Arduino code?
Assuming the 2560 isn't locked, there are avrdude commands you can run to download the flash data from the chip and store it as a hex file.
You will not be able to easily manipulate it.
You can Disassemble it into Assembly code. You may even be able to decompile into something C++ like. If the original code was created in C++ anyway. https://www.onlinedisassembler.com/odaweb/ https://derevenets.com/examples.html
CrossRoads:
Thanks! At this point I'll settle for just having it as a backup. I've taken a look at avrdude commands and have another question: it says I need to address the programmer. I'm assuming that's built into the Arduino, so what would I address it as?
Your avrdude command and options should look somthing like...
avrdude -p atmega2560 -c stk500v2 -P COM10 -b 115200 -U flash:r:flash_backup_file.hex
-c stk500v2 is how the bootloader in MEGA2560 talks
-P is the serial port, that may be the address thing you were seeing (not sure) but you need to know which port
-b 115200 is the baud rate (not sure if it is 57600 or 115200, it should not hurt to try both)
-U flash:r:flash_backup_file.hex is the key to reading ... notice the r ... where the :r: is ... that is for reading.
to backup the eeprom (a good idea)
avrdude -p atmega2560 -c stk500v2 -P COM10 -b 115200 -U eeprom:r:eeprom_backup_file.hex
Specify the programmer to be used. AVRDUDE knows about several common programmers. Use this option to specify which one to use. The programmer-id parameter is the programmer’s id listed in the configuration file. Specify -c ? to list all programmers in the configuration file.
I had the same error trying to read the OSCCAL values from an attiny13a (using linux).
After adding the type of file format, :h for hex, it worked like this:
