Eye Blink Detection Project Code problem
You can see the code we prepared for our project below.
The purpose of this code is to classify the input from IRsensorPin as 'blink (high)' or 'not blink (low)' according to the specified threshold;
only when blink is detected (high) outputs square pulse from Pin 9 from PWM mode.
I think the code should work and I can't see any errors but we are not getting the output we want.
We would be very happy if you could help.
#include <PWM.h>
int IRsensorPin = 0;// IR Sensor
int LedPin = 13; // Visualization
int latestLevel = 0; // Previous IR level
int latestChange = 0;// Change in IR level
int changeThreshold = 5;// How hard a rising edge do we need?
//stimulation
int led_pin_pwm= 9;
int frequency = 150;
bool blinkCheckingFlag = true; //blink checking
//visualization
int duration = 100;  // Length of visualization
float startPoint = 0;// Last start of visualization
  Serial.begin(9600); // Debug constructor
  pinMode(13,OUTPUT);  // Visualizatio constructor
//stimulation functions
  InitTimersSafe();
  SetPinFrequencySafe(led_pin_pwm, frequency);
   // Read Data
  int IRsensorValue = analogRead(IRsensorPin);
  Serial.println(IRsensorValue);
     // look for rising edges
  latestChange = IRsensorValue - latestLevel;
  latestLevel = IRsensorValue;
  if (blinkCheckingFlag == true && latestChange >= changeThreshold)
    digitalWrite( LedPin, HIGH ); //detection
    startPoint = millis(); //start point value
    pwmWrite(led_pin_pwm, 127);// stimulation
  else if ( blinkCheckingFlag = false &&  millis() >= startPoint + duration )
    digitalWrite( LedPin, LOW ); //no detection
    pwmWrite(led_pin_pwm, 0); //no stimulation
Have you forgotten something about blinkCheckingFlag?
NO, the unsigned subtraction is needed to always work.
(millis() - (unsigned long)startPoint >= (unsigned long)duration)
Correct except WHY is startPoint a float and duration an int?
That is an assignment '=' not a comparision '=='
I tried that way it didnt work
Yea maybe thats why i will also try that
