Hi All,
I am using 2.4" TFT Display with drive ILI9341 on ESP32. I am trying to read and write the SD card in TFT Display, but I am getting the same error that "SD Card initialization failed!".
Can you pls suggest how can it be resolved? Below is my pin configuration.
VCC - 5V
GND - GND
CS - G5
Reset - G4
DC - G19
SDI - G23
SCK - G18
LED- 3.3 V
SD_CS - G15
SD_MOSI - G13
SD_MISO - G12
SD_SCK - G14
I also tried connecting jumper J1, but that too is not working.
srnet
February 9, 2025, 11:56am
2
Could be a problem with your code.
See information on posting code etc here;
https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966
horace
February 9, 2025, 12:12pm
3
which specific ESP32 and TFT display are you using ? give a link?
I connected to the SD card on a ESP32 TFT based display so
// TFT pins
// #define TFT_MISO 19 // (leave TFT SDO disconnected if other SPI devices share MISO)
// #define TFT_MOSI 23
// #define TFT_SCLK 18
// #define TFT_CS 15 // Chip select control pin
// #define TFT_DC 2 // Data Command control pin
// #define TFT_RST 4 // Reset pin (could connect to RST pin)
// VCC to 5V if J1 open else 3.3V
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
// SD card pins
#define HSPI_MISO 27 // note 12 causes problems when RST pressed
#define HSPI_MOSI 13
#define HSPI_SCLK 14
#define HSPI_SS 26
hspi = new SPIClass(HSPI); // create SPI class
//hspi->begin();
hspi->begin(HSPI_SCLK, HSPI_MISO, HSPI_MOSI, HSPI_SS); //SCLK, MISO, MOSI, SS
if (!SD.begin(HSPI_SS, *hspi)) { // mount card
Serial.println("Card Mount Failed");
return;
I am using below ESP32. TFT is same as the link you had shared in the comment.
https://robu.in/product/esp32-38pin-development-board-wifibluetooth-ultra-low-power-consumption-dual-core/
I am still facing the same issue. Tried below 2 codes with different libraries. My J1 is closed so using 3.3 as VCC.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <SD.h>
// Pin definitions
#define TFT_CS 15
#define TFT_RST 4
#define TFT_DC 2
#define SD_CS 16 // Changed CS to GPIO 16
// Initialize the TFT display
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_RST);
// Start Serial Monitor
tft.begin();
tft.setRotation(3); // Adjust rotation if needed
tft.fillScreen(ILI9341_WHITE); // Clear the screen with white color
tft.setTextColor(ILI9341_BLACK);
tft.setTextSize(2);
tft.setCursor(10, 10);
tft.println("TFT Display Initialized!");
// Initialize SPI settings for SD card
SPI.begin(18, 19, 23, 16); // SCK, MISO, MOSI, CS
// Initialize the SD card
if (!SD.begin(SD_CS)) {
Serial.println("SD Card initialization failed!");
tft.setCursor(10, 40);
tft.println("SD Card Error");
return;
Serial.println("SD Card initialized successfully.");
tft.println("SD Card Ready!");
// Optional: Add any code to interact with the SD card here, e.g., read/write files
#include <TFT_eSPI.h>
#include <SPI.h>
#include <SD.h>
// Pin definitions
#define TFT_CS 15
#define TFT_RST 4
#define TFT_DC 2
TFT_eSPI tft = TFT_eSPI(); // Create TFT object
tft.begin();
tft.fillScreen(TFT_WHITE); // Clear the screen with white color
tft.setTextColor(TFT_BLACK);
tft.setTextSize(2);
return;
horace
February 9, 2025, 1:28pm
5
never attempted to run the TFT and SD card off the same SPI bus
if the SD card is sharing a SPI bus with other devices there can be problems - see Espressif: Sharing the SPI bus among SD card and other SPI devices
I tend to use a 5V supply (jumper J1 open)
So, for the clarification do you suggest to run the same set of code with 5V - J1 Open?
horace
February 9, 2025, 1:55pm
7
try it! it could be the ESP32 3.3V cannot supply sufficient power for the TFT and SD card
Thank you for the suggestion!
I tried, with 5V. removed the bridge. Ran both the codes, still the same issue. I am not sure where am I going wrong.
VCC
5V
GND
GND
CS
15
RESET
4
DC
2
SDI
23
SCK
18
LED
5V
SD_SCK
14
SD_MISO
27
SD_MOSI
13
SD_CS
26
pratik-19:
VCC - 5V
GND - GND
CS - G5
Reset - G4
DC - G19
SDI - G23
SCK - G18
LED- 3.3 V
SD_CS - G15
SD_MOSI - G13
SD_MISO - G12
SD_SCK - G14
By default, the SD library uses the VSPI bus (not HSPI). Since your SD card is wired to HSPI (GPIO 12, 13, 14, 15), I guess you need to specify this in your code.
ahsrabrifat:
Some issues with the details I shared. Below is the correct pin config I am using.
VCC 5V
GND GND
CS 15
RESET 4
DC 2
SDI 23
SCK 18
LED 5V
SD_SCK 14
SD_MISO 27
SD_MOSI 13
SD_CS 26
Below code worked
#include <SPI.h>
#include <SD.h>
// Pin definitions based on your updated configuration
#define TFT_CS 15
#define TFT_RST 4
#define TFT_DC 2
#define SD_CS 26 // Changed SD card CS to GPIO 26
#define SD_SCK 14 // Changed SD SCK to GPIO 14
#define SD_MISO 27 // Changed SD MISO to GPIO 27
#define SD_MOSI 13 // Changed SD MOSI to GPIO 13
tft.begin();
tft.setTextSize(2);
SPI.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS); // SCK, MISO, MOSI, CS
return;
VCC 5V
GND GND
CS 15
RESET 4
DC 2
SDI 23
SCK 18
LED 5V
SD_SCK 14
SD_MISO 27
SD_MOSI 13
SD_CS 26
Thank you so much everyone for your help!
