const int button1 = 2;
const int button2 = 3;
const int button3 = 4;
const int led1 = 8;
const int M1 = 9;
const int M2 = 10;
bool isPin1,isPin2;
int buttonState1 =0;
int buttonState2 =0;
int buttonState3 =0;
pinMode(led1,OUTPUT);
pinMode(M1,OUTPUT);
pinMode(M2,OUTPUT);
pinMode(button1,INPUT);
pinMode(button2,INPUT);
pinMode(button3,INPUT);
isPin1 = false;
isPin2 = false;
buttonState1 = digitalRead(button1);
buttonState2 = digitalRead(button2);
buttonState3 = digitalRead(button3);
if(buttonState1==HIGH && isPin1 && !isPin2 )
digitalWrite(led1,HIGH);
isPin2 =true;
if(buttonState2==HIGH && isPin2)
digitalWrite(M1,HIGH);
isPin2=false;
delay(5000);
digitalWrite(M1,LOW);
isPin1=true;
if(buttonState3==HIGH)
digitalWrite(M2,HIGH);
delay(5000);
digitalWrite(M2,LOW);
isPin2=true;
When I'm using this code everything is working bt when I connect 24 volt power supply to motor after that sometime its reset auto and some time its not cut off on delay time. please see attached file also
You need a separate power supply for the relay coils, remove the JD-VCC jumper on the relay board AND the ground wire from relay board to Arduino, you're prob'ly getting interference through the ground wire. Connect the separate PS to JD-VCC and GND on relay board.
