FastLED Fire 2012 palette color change w/ button press
Hello, i am trying to use FastLED and neopixel strips for the first time. Short version i want the leds to light when one switch is pressed and to change color palettes when a second switch is pressed. I came up with what I though was good code but it seems to be non functional. I have rule out faulty hardware as a potential issue. i have attached the code, I just need another set of eyes to see what I am not because it is most likely painfully obvious.
TIA
#include <FastLED.h>  // led strip library
#include <SoftwareSerial.h> // softsware serial for df player connection
#include <DFRobotDFPlayerMini.h>// DFRobotDFPlayerMini - Version: Latest
#define LED_PIN     3
#define COLOR_ORDER GRB
#define CHIPSET     WS2812B
#define NUM_LEDS    14
#define BRIGHTNESS  200
#define FRAMES_PER_SECOND 60
bool gReverseDirection = false;
CRGB leds[NUM_LEDS];
SoftwareSerial sound_serial (7, 8); // set rx and tx for serial communication
DFRobotDFPlayerMini sound_FX; // defines df player as sound fx
int trigger_switch = 4; // trigger switch for plasma pistol
byte blue_barrel = 11;  // blue rgb led signal for barrel flash
byte red_barrel = 9; // red rgb led signal for barrel flash
byte green_barrel = 10; // green rgb led signal for barrel flash
byte vibe_motor = 6; // viberation motor transistor base signal
byte beaver_switch = 12; // beaver tail saftey switch
byte power_led = 5; // power on led indicator
byte push_count = 0; // set push count for trigger pull, start at zero
byte last_state2; // last status for tigger pull
byte last_state1; // last status for safety switch
unsigned long previousMillis1 = 0; //  set start time zero
unsigned long previousMillis2 = 0; //  set start time zero
unsigned long previousMillis3 = 0; //  set start time zero
unsigned long previousMillis4 = 0; //  set start time zero
unsigned long previousMillis5 = 0; //  set start time zero
byte trigger;
byte safety;
byte trigger_state;
byte safety_state;
byte rando;
CRGBPalette16 gPal;
 FastLED.addLeds<CHIPSET, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
 FastLED.setBrightness( BRIGHTNESS );
 pinMode(trigger_switch, INPUT_PULLUP); // set trigger switch as input with pull up resistor
 pinMode(blue_barrel, OUTPUT); // set blue barrel led pin as output
 pinMode(green_barrel, OUTPUT); // set green barrel led pin as output
 pinMode(red_barrel, OUTPUT); // set red barrel led pin as output
 pinMode(vibe_motor, OUTPUT); // set transitor base pin for vibe motor control as output
 pinMode(beaver_switch, INPUT_PULLUP); // set beaver tail saftey switch as input with ppull up resistor
 pinMode(power_led, OUTPUT); // set pin to output
 analogWrite(power_led, 100);
 sound_serial.begin(9600);
 sound_FX.volume(25);
 sound_FX.play("start up");
 random16_add_entropy( random());
 unsigned long currentMillis = millis();   // set current time  in milliseconds since board turned on
 trigger = digitalRead(trigger_switch); // read trigger switch pull
 safety = digitalRead(beaver_switch); // read beaver tail saftey switch pull
 rando = random(20);
 Serial.println("safe off");
 if (safety == LOW && trigger == HIGH) {
   safety_state = safety;
   if (safety_state != last_state1) {
     if (safety_state == LOW) {
       sound_FX.play("energize"); // play "energize" power up sound FX
       digitalWrite(vibe_motor, HIGH); // turn on vibe motor
       if (currentMillis - previousMillis1 >= 1500) {             //  measure 400 millis
         previousMillis1 = currentMillis;                            //
         digitalWrite(vibe_motor, LOW);  // turn off vibe motor after 400 millis
     last_state1 = safety_state;
   if (push_count <= 4) {
     gPal = CRGBPalette16( CRGB::Blue, CRGB::Aqua,  CRGB::White);
     Fire2012WithPalette(); // run simulation frame, using palette colors
     FastLED.show(); // display this frame
     FastLED.delay(1000 / FRAMES_PER_SECOND);
   if (push_count == 5) {
     gPal = CRGBPalette16( CRGB( 0, 0, 255), CRGB( 80, 150, 255),  CRGB::White);
   if (push_count == 6) {
     gPal = CRGBPalette16( CRGB( 50, 0, 255), CRGB( 0, 150, 255),  CRGB::White);
   if (push_count == 7) {
     gPal = CRGBPalette16( CRGB( 100, 0, 255), CRGB( 0, 200, 255),  CRGB::White);
   if (push_count == 8) {
     gPal = CRGBPalette16( CRGB( 150, 0, 255), CRGB( 0, 150, 255),  CRGB::White);
   if (push_count == 9) {
     gPal = CRGBPalette16( CRGB( 200, 0, 255), CRGB( 0, 100, 255),  CRGB::White);
   if (push_count == 10) {
     gPal = CRGBPalette16( CRGB( 255, 0, 255), CRGB( 0, 0, 255),  CRGB::White);
   if (push_count == 11) {
     gPal = CRGBPalette16( CRGB( 255, 0, 200), CRGB( 100, 0, 255),  CRGB::White);
   if (push_count == 12) {
     gPal = CRGBPalette16( CRGB( 255, 0, 150), CRGB( 150, 0, 255),  CRGB::White);
   if (push_count == 13) {
     gPal = CRGBPalette16( CRGB( 255, 0, 100), CRGB( 200, 0, 255),  CRGB::White);
   if (push_count == 14) {
     gPal = CRGBPalette16( CRGB( 255, 0, 0), CRGB( 255, 0, 255),  CRGB::White);
 if (safety == LOW && trigger == LOW) {
   trigger_state = trigger;                   // registers each time the trigger button is pressed
   if (trigger_state != last_state2 && currentMillis - previousMillis2 >= 2000) {                        // alternates between on/off states to deploy/retract blade
     if (trigger_state == LOW) {
       push_count++;
     last_state2 = trigger_state;
     previousMillis2 = currentMillis;
   if (trigger_state != last_state2) {
       if (push_count <= 4 && rando != 1) {
         sound_FX.play("fire"); // play fire sound fx
         gPal = CRGBPalette16( CRGB( 200, 255, 255));
         digitalWrite(vibe_motor, HIGH); // turn on vibration
         analogWrite(blue_barrel, 255); // max blue led
         analogWrite(red_barrel, 200); // red led on
         analogWrite(green_barrel, 255); // max green led
         delay(700);
         analogWrite(blue_barrel, 0);
         analogWrite(green_barrel, 0);
         analogWrite(red_barrel, 0);
         Serial.println(push_count);
       if (push_count == 5 && rando != 1) {
         gPal = CRGBPalette16( CRGB( 210, 240, 255));
         analogWrite(red_barrel, 210); // red led on
         analogWrite(green_barrel, 240); // max green led
         delay(700);
       if (push_count == 6 && rando != 1) {
         delay(700);
       if (push_count == 7 && rando != 1) {
         gPal = CRGBPalette16( CRGB( 220, 230, 255));
         analogWrite(red_barrel, 220); // red led on
         analogWrite(green_barrel, 230); // max green led
         delay(700);
       if (push_count == 8 && rando != 1) {
         delay(700);
       if (push_count == 9 && rando != 1) {
         gPal = CRGBPalette16( CRGB( 230, 220, 255));
         analogWrite(red_barrel, 230); // red led on
         analogWrite(green_barrel, 220); // max green led
         delay(700);
       if (push_count == 10 && rando != 1) {
         delay(700);
       if (push_count == 11 && rando != 1) {
         gPal = CRGBPalette16( CRGB( 240, 210, 255));
         analogWrite(red_barrel, 240); // red led on
         analogWrite(green_barrel, 210); // max green led
         delay(700);
       if (push_count == 12 && rando != 1) {
         delay(700);
       if (push_count == 13 && rando != 1) {
         gPal = CRGBPalette16( CRGB( 255, 200, 255));
         analogWrite(red_barrel, 255); // red led on
         analogWrite(green_barrel, 200); // max green led
         delay(700);
       if (push_count == 14 && rando != 1) {
         delay(700);
     if (push_count >= 15) {
       sound_FX.play("overheat");
       gPal = CRGBPalette16( CRGB::Red, CRGB::DarkRed,  CRGB::White);
       if (currentMillis - previousMillis3 >= 88000) {
         previousMillis3 = currentMillis;
         push_count = 0;
 if (safety == LOW && trigger == LOW && rando == 1) {
   sound_FX.play("Nat1");
   gPal = CRGBPalette16( CRGB::White);
   analogWrite(blue_barrel, 250); // max blue led
   analogWrite(red_barrel, 250); // red led on
   analogWrite(green_barrel, 250); // max green led
   delay(6000);
   analogWrite(blue_barrel, 0); // max blue led
   analogWrite(red_barrel, 0); // red led on
   analogWrite(green_barrel, 0); // max green led
 if ( currentMillis - previousMillis4 >= 3000 && trigger_state == last_state2) {
   if ( currentMillis - previousMillis5 >= 600 && trigger_state == last_state2) {
     push_count--;
     previousMillis5 = currentMillis;
   previousMillis4 = currentMillis;
 else {
   gPal = CRGBPalette16( CRGB::Black);
// Fire2012 by Mark Kriegsman, July 2012
// as part of "Five Elements" shown here: http://youtu.be/knWiGsmgycY
// This basic one-dimensional 'fire' simulation works roughly as follows:
// There's a underlying array of 'heat' cells, that model the temperature
// at each point along the line.  Every cycle through the simulation,
// four steps are performed:
//  1) All cells cool down a little bit, losing heat to the air
//  2) The heat from each cell drifts 'up' and diffuses a little
//  3) Sometimes randomly new 'sparks' of heat are added at the bottom
//  4) The heat from each cell is rendered as a color into the leds array
//     The heat-to-color mapping uses a black-body radiation approximation.
// Temperature is in arbitrary units from 0 (cold black) to 255 (white hot).
// This simulation scales it self a bit depending on NUM_LEDS; it should look
// "OK" on anywhere from 20 to 100 LEDs without too much tweaking.
// I recommend running this simulation at anywhere from 30-100 frames per second,
// meaning an interframe delay of about 10-35 milliseconds.
// Looks best on a high-density LED setup (60+ pixels/meter).
// There are two main parameters you can play with to control the look and
// feel of your fire: COOLING (used in step 1 above), and SPARKING (used
// in step 3 above).
// COOLING: How much does the air cool as it rises?
// Less cooling = taller flames.  More cooling = shorter flames.
// Default 55, suggested range 20-100
#define COOLING  55
// SPARKING: What chance (out of 255) is there that a new spark will be lit?
// Higher chance = more roaring fire.  Lower chance = more flickery fire.
// Default 120, suggested range 50-200.
#define SPARKING 120
void Fire2012WithPalette()
 // Array of temperature readings at each simulation cell
 static uint8_t heat[NUM_LEDS];
 // Step 1.  Cool down every cell a little
 for ( int i = 0; i < NUM_LEDS; i++) {
   heat[i] = qsub8( heat[i],  random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
 // Step 2.  Heat from each cell drifts 'up' and diffuses a little
 for ( int k = NUM_LEDS - 1; k >= 2; k--) {
   heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
 // Step 3.  Randomly ignite new 'sparks' of heat near the bottom
 if ( random8() < SPARKING ) {
   int y = random8(7);
   heat[y] = qadd8( heat[y], random8(160, 255) );
 // Step 4.  Map from heat cells to LED colors
 for ( int j = 0; j < NUM_LEDS; j++) {
   // Scale the heat value from 0-255 down to 0-240
   // for best results with color palettes.
   uint8_t colorindex = scale8( heat[j], 240);
   CRGB color = ColorFromPalette( gPal, colorindex);
   int pixelnumber;
   if ( gReverseDirection ) {
     pixelnumber = (NUM_LEDS - 1) - j;
     pixelnumber = j;
   leds[pixelnumber] = color;
What is your code supposed to do and what does it actually do? “Non functional” is not an adequate description
Currently it does nothing, the initial power led comes on but after void(setup) it's like the code is locking up. It is supposed to run the fire pattern from fast led on a neopixel strip when a button is pressed. Then if a second button is pressed it will run fire but with a different color palette based on how many times the second button has been pressed. Unfortunately it is not doing anything noticeable after set up. Nothing reports on serial monitor either.
Have you tried any serial debugging. It is not normal for code to do “nothing”. Even if the microcontroller is resetting it will keep running setup.
Yes, tried adding some serial print commands in both void setup and loop. Neither ever displays. It's like the code locks up right after the power led is turned on.
So it turns out part of the issue was the commands for the df mini player. I hadn't wired that up yet so the code was hanging up waiting for a confirmation from the player. The code does run intermittently now but something is still causing it to hang up. what it should do is run the given color palette when the "safety" switch is pressed. then if the trigger switch is pressed while the safety is pressed the leds should flash white for a moment then resume the fire2012 pattern. the current palette should be based on a push counter associated with the trigger switch. If the trigger is pulled multiple times within 2 seconds the counter should increase by one. then decrease based on a cool down period. the code will light up the leds when the safety is pressed but doesn't change palettes. it will turn white but not resume the fire2012 pattern they also wont turn off when switch released. it does track the push counter correctly but doesn't seem to apply the changes needed for palettes. code will periodically "freeze" and require reset of nano
