FastLED library problem with LQFP32 nano clone
When I
#include <FastLED.h>
I get the following compilation failure:-
In function showPixels' .... undefined reference to timer0_millis'
In the Arduino IDE I've selected LQFP32 board under Tools and have got the standard Blink to run but a LED strip program that runs on a genuine nano fail to compile as above.
FastLED issue is 3.4.
Does anyone know of a fix to this?
Are you using a LGT8F328P ? Why ?
Those chips are not officially supported by Arduino. Others on this forum have trouble uploading a sketch, and if a sketch can be uploaded, then many libraries will not work.
the fasted library is making direct access to the counter and if the board is unknown it's expecting timer0_millis to exist.
extern "C" {
#  if defined(CORE_TEENSY) || defined(TEENSYDUINO)
  extern volatile unsigned long timer0_millis_count;
  #define MS_COUNTER timer0_millis_count
#elif defined(ATTINY_CORE)
  extern volatile unsigned long millis_timer_millis;
  #define MS_COUNTER millis_timer_millis
#elif defined(__AVR_ATmega4809__)
  extern volatile unsigned long timer_millis;
  #define MS_COUNTER timer_millis
#else
  extern volatile unsigned long timer0_millis;  // <=== CATCH ALL OTHER BOARDS
#  endif
it does seem to exist in the core definition for that platform though. Did you add the package to the arduino Boards Manager Urls?
what's the exact full error message?
J-M-L - here's the full error message.
In file included from D:\Dropbox\ArduinoSketchbook2018\U3A_LED_demo\U3A_LED_demo.ino:4:0:
D:\Dropbox\ArduinoSketchbook2018\libraries\arduino_364790/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.003
 #    pragma message "FastLED version 3.003.003"
C:\Users\geowa\AppData\Local\Temp\cc7zh7Qg.ltrans0.ltrans.o: In function `showPixels':
D:\Dropbox\ArduinoSketchbook2018\libraries\arduino_364790/platforms/avr/clockless_trinket.h:144: undefined reference to `timer0_millis'
C:\Users\geowa\AppData\Local\Temp\cc7zh7Qg.ltrans0.ltrans.o:D:\Dropbox\ArduinoSketchbook2018\libraries\arduino_364790/platforms/avr/clockless_trinket.h:144: more undefined references to `timer0_millis' follow
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "FastLED.h"
 Used: D:\Dropbox\ArduinoSketchbook2018\libraries\arduino_364790
 Not used: D:\Dropbox\ArduinoSketchbook2018\libraries\arduino_744260
exit status 1
Error compiling for board LGT8F328P-LQFP32 MiniEVB.
I added the unzipped Larduino-HSP hardware directory to the Sketchbook folder (as per instruction on Github) and the board shows up in IDE Tools/Board so I've selected it.
did you do exactly this:
How to install
Add the package to the arduino Boards Manager Urls:
  • Go to Preferences
    • paste this url in Boards Manager URL: https://raw.githubusercontent.com/dbuezas/lgt8fx/master/package_lgt8fx_index.json
  • Go to Tools/Board/Boards manager
    • Type lgt8fx in the search box
    • install lgt8fx
Now the boards appear in the IDE and you can also select the clock speed.
Boards Manager
Variants
Clock
External Clock
@geo3geo Have you accidentally bought a LGT8F328P board ? Get rid of it right now ! Buy a Arduino board or even a clone.
If you bought the LGT8F328P on purpose because you wanted to see how much trouble you get into, well, then you got what you wished for.
J-M-L
I removed the Hardware Support package that I'd added to the IDE Sketchbook folder and did what you suggested and everything now works a treat!
Brilliant!
Many thanks for all this, much appreciated!
Why did I buy it?
Twice the speed, almost half the price, and it uses a standard micro USB connector. Thought it was worth a go.
It's been a lot of hassle but I've learnt quite a bit along the way, and it's raining today so a nice diversion!
