Hello, I want to start with that i have verry limited experience and knowledge about Arduinos.
I just got the Arduino Plant Watering Kit, so I started assembling it and I finished it today, and now the Grove Relay that was in the kit just keeps ticking real fast, when I try to pump water. haven't gotten to the faze of actually putting the system to work I am just testing that everything works before putting it into work.
I have done everything exactly the same as it was on here: https://docs.arduino.cc/tutorials/plant-watering-kit/iot-smart-garden-setup-with-nanorp2040
The relay keeps ticking super fast and the pump does not pump.
And also used the template to minimize the amount of faults that could be produced by me.
I have checked with a multimeter that the pump is actually receiving power from the relay and USB wall charged(1A 5V). I have also checked the relay with a multimeter with Grove - Relay Schematic that I got from the Seeeds Studioe website. an everything seems fine with the relay as well.
I have gone over the schematics in the document above to check if I wired anything wrong a bunch of times at least, and checked for loose wires and bad connections.
the moisture sensor works and is sending signals. Struggled with that as well as getting a connection to the RP2040 Board, but I managed to update the firmware using IDE.
Hopefully I will figure this out, but I am verry much open to critic and possible solutions by the forum.
Update 04.02.2023
It was all because of the pump was broken
Bought a new one and now the setup works like charm.
