the sketch from:
got error: fd_forward.h: No such file or directory
I didn't see any where required to install this library in the vedio. and not easy to get one online to download. how to do? on my WIN7 LAPTOP.
!!! The same sketch done compiling in my WIN10 laptop, why this?
Thanks
Adam
#include <ESPAsyncWebServer.h>
#include "esp_camera.h"
#include "camera_index.h"
#include "Arduino.h"
#include "fd_forward.h"
#include <SPI.h>
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
#include <TFT_eFEX.h>
TFT_eFEX fex = TFT_eFEX(&tft);
AsyncWebServer webserver(80);
AsyncWebSocket ws("/ws");
const char* ssid = "NSA";
const char* password = "orange";
String filelist;
camera_fb_t * fb = NULL;
String incoming;
long current_millis;
long last_capture_millis = 0;
static esp_err_t cam_err;
static esp_err_t card_err;
char strftime_buf[64];
long file_number = 0;
// CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
static inline mtmn_config_t app_mtmn_config()
mtmn_config_t mtmn_config = {0};
mtmn_config.type = FAST;
mtmn_config.min_face = 60; // 80 default
mtmn_config.pyramid = 0.707;
mtmn_config.pyramid_times = 4;
mtmn_config.p_threshold.score = 0.6;
mtmn_config.p_threshold.nms = 0.7;
mtmn_config.p_threshold.candidate_number = 20;
mtmn_config.r_threshold.score = 0.7;
mtmn_config.r_threshold.nms = 0.7;
mtmn_config.r_threshold.candidate_number = 10;
mtmn_config.o_threshold.score = 0.7;
mtmn_config.o_threshold.nms = 0.7;
mtmn_config.o_threshold.candidate_number = 1;
return mtmn_config;
mtmn_config_t mtmn_config = app_mtmn_config();
pinMode(4, OUTPUT);// initialize io4 as an output for LED flash.
digitalWrite(4, LOW); // flash off/
init_wifi();
tft.begin();
tft.setRotation(3); // 0 & 2 Portrait. 1 & 3 landscape
tft.fillScreen(TFT_BLACK);
tft.setCursor(35,55);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(1);
tft.println(WiFi.localIP());
delay(5000);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
cam_err = esp_camera_init(&config);
if (cam_err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", cam_err);
return;
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_QQVGA);
s->set_vflip(s, 1);
ws.onEvent(onEvent);
webserver.addHandler(&ws);
webserver.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
Serial.print("Sending interface...");
AsyncWebServerResponse *response = request->beginResponse_P(200, "text/html", index_ov2640_html_gz, sizeof(index_ov2640_html_gz));
response->addHeader("Content-Encoding", "gzip");
request->send(response);
webserver.on("/image", HTTP_GET, [](AsyncWebServerRequest * request) {
Serial.println("requesting image from SPIFFS");
if (request->hasParam("id")) {
AsyncWebParameter* p = request->getParam("id");
Serial.printf("GET[%s]: %s\n", p->name().c_str(), p->value().c_str());
String imagefile = p->value();
imagefile = imagefile.substring(4); // remove img_
request->send(SPIFFS, "/" + imagefile);
webserver.begin();
if (!SPIFFS.begin()) {
Serial.println("SPIFFS initialisation failed!");
SPIFFS.begin(true);// Formats SPIFFS - could lose data https://github.com/espressif/arduino-esp32/issues/638
Serial.println("\r\nInitialisation done.");
fex.listSPIFFS(); // Lists the files so you can see what is in the SPIFFS
bool init_wifi()
WiFi.begin(ssid, password);
Serial.print(".");
Serial.print("Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
return true;
void onEvent(AsyncWebSocket * server, AsyncWebSocketClient * client, AwsEventType type, void * arg, uint8_t *data, size_t len)
// String incoming = String((char *)data); No idea why.. gave extra characters in data for short names.
// so ....
for (size_t i = 0; i < len; i++) {
incoming += (char)(data[i]);
Serial.println(incoming);
if (incoming.substring(0, 7) == "delete:") {
String deletefile = incoming.substring(7);
incoming = "";
int fromUnderscore = deletefile.lastIndexOf('_') + 1;
int untilDot = deletefile.lastIndexOf('.');
String fileId = deletefile.substring(fromUnderscore, untilDot);
Serial.println(fileId);
Serial.println("image delete");
SPIFFS.remove("/selfie_t_" + fileId + ".jpg");
SPIFFS.remove("/selfie_f_" + fileId + ".jpg");
client->text("removed:" + deletefile); // file deleted. request browser update
Serial.println("sending list");
client->text(filelist_spiffs());
String filelist_spiffs()
filelist = "";
fs::File root = SPIFFS.open("/");
fs::File file = root.openNextFile();
while (file) {
String fileName = file.name();
// Serial.println(fileName);
filelist = filelist + fileName;
Serial.println(filelist);
return filelist;
void latestFileSPIFFS()
while (file) {
int fromUnderscore = fileName.lastIndexOf('_') + 1;
int untilDot = fileName.lastIndexOf('.');
String fileId = fileName.substring(fromUnderscore, untilDot);
file_number = max(file_number, fileId.toInt()); // replace filenumber if fileId is higher
bool face_detected()
fb = esp_camera_fb_get();
dl_matrix3du_t *image_matrix = NULL;
image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
fmt2rgb888(fb->buf, fb->len, fb->format, image_matrix->item);
box_array_t *net_boxes = NULL;
net_boxes = face_detect(image_matrix, &mtmn_config);
if (net_boxes) {
free(net_boxes->score);
free(net_boxes->box);
free(net_boxes->landmark);
free(net_boxes);
dl_matrix3du_free(image_matrix);
Serial.println("face detected");
esp_camera_fb_return(fb);
fb = NULL;
return true;
fb = NULL;
return false;
void smile_for_the_camera()
long timer_millis = millis();
while (millis() - timer_millis < 500) {
if (!face_detected()) { // if face disappears stop
Serial.println("face not detected");
return;
digitalWrite(4, HIGH); // flash on
fex.drawJpgFile(SPIFFS, "/_count3.jpg", 0, 0);
delay(400);
fex.drawJpgFile(SPIFFS, "/_count2.jpg", 0, 0);
delay(400);
fex.drawJpgFile(SPIFFS, "/_count1.jpg", 0, 0);
delay(400);
take_photo();
static esp_err_t take_photo()
latestFileSPIFFS(); // next file number
file_number++;
Serial.println(file_number);
Serial.println("Starting thumb capture: ");
fex.drawJpg((const uint8_t*)fb->buf, fb->len, 0, 6);
//save thumb
char *thumb_filename = (char*)malloc(23 + sizeof(file_number));
sprintf(thumb_filename, "/spiffs/selfie_t_%d.jpg", file_number);
Serial.println("Opening file: ");
FILE *thumbnail = fopen(thumb_filename, "w");
if (thumbnail != NULL) {
size_t err = fwrite(fb->buf, 1, fb->len, thumbnail);
Serial.printf("File saved: %s\n", thumb_filename);
Serial.println("Could not open file");
fclose(thumbnail);
fb = NULL;
free(thumb_filename);
Serial.println("Starting main capture: ");
s->set_framesize(s, FRAMESIZE_SVGA);
char *full_filename = (char*)malloc(23 + sizeof(file_number));
sprintf(full_filename, "/spiffs/selfie_f_%d.jpg", file_number);
FILE *fullres = fopen(full_filename, "w");
if (fullres != NULL) {
size_t err = fwrite(fb->buf, 1, fb->len, fullres);
Serial.printf("File saved: %s\n", full_filename);
fclose(fullres);
fb = NULL;
free(full_filename);
char *addtobrowser = (char*)malloc(24 + sizeof(file_number));
sprintf(addtobrowser, "added:selfie_t_%d.jpg", file_number);
ws.textAll((char*)addtobrowser);// file added. request browser update
if (face_detected()) {
smile_for_the_camera();
fb = NULL;
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, Huge APP (3MB No OTA/1MB SPIFFS), 80MHz, None"
SelfieCam:16:11: fatal error: fd_forward.h: No such file or directory
Multiple libraries were found for "WiFi.h"
Used: C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi
Not used: E:\ENGINEERING\DIY\Electronic\ARDUINO\software\arduino-1.8.19-windows\arduino-1.8.19\libraries\WiFi
compilation terminated.
exit status 1
option enabled in File -> Preferences.
