D:\Installed Programs\Arduino Offline\Arduino\arduino-builder -dump-prefs -logger=machine -hardware D:\Installed Programs\Arduino Offline\Arduino\hardware -hardware C:\Users\lauri\AppData\Local\Arduino15\packages -tools D:\Installed Programs\Arduino Offline\Arduino\tools-builder -tools D:\Installed Programs\Arduino Offline\Arduino\hardware\tools\avr -tools C:\Users\lauri\AppData\Local\Arduino15\packages -built-in-libraries D:\Installed Programs\Arduino Offline\Arduino\libraries -libraries C:\Users\lauri\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,FlashFreq=80 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\lauri\AppData\Local\Temp\arduino_build_839443 -warnings=all -build-cache C:\Users\lauri\AppData\Local\Temp\arduino_cache_844709 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\ESP32Basics.ino
D:\Installed Programs\Arduino Offline\Arduino\arduino-builder -compile -logger=machine -hardware D:\Installed Programs\Arduino Offline\Arduino\hardware -hardware C:\Users\lauri\AppData\Local\Arduino15\packages -tools D:\Installed Programs\Arduino Offline\Arduino\tools-builder -tools D:\Installed Programs\Arduino Offline\Arduino\hardware\tools\avr -tools C:\Users\lauri\AppData\Local\Arduino15\packages -built-in-libraries D:\Installed Programs\Arduino Offline\Arduino\libraries -libraries C:\Users\lauri\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32cam:CPUFreq=240,FlashMode=qio,FlashFreq=80 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\lauri\AppData\Local\Temp\arduino_build_839443 -warnings=all -build-cache C:\Users\lauri\AppData\Local\Temp\arduino_cache_844709 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -verbose C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\ESP32Basics.ino
Using board 'esp32cam' from platform in folder: C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
Using core 'esp32' from platform in folder: C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3
cmd /c if exist "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\partitions.csv" COPY /y "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\partitions.csv" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\partitions.csv"
cmd /c if not exist "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\partitions.csv" if exist "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\partitions.csv" COPY "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\partitions.csv" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\partitions.csv"
cmd /c if not exist "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\partitions.csv" COPY "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\partitions\huge_app.csv" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\partitions.csv"
1 file(s) copied.
cmd /c IF EXIST "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\bootloader.bin" ( COPY /y "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\bootloader.bin" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\ESP32Basics.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\bootloader.bin" ( COPY "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32\bootloader.bin" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\ESP32Basics.ino.bootloader.bin" ) ELSE ( COPY /y "C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\tools\sdk\esp32\bin\bootloader_qio_80m.bin" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\ESP32Basics.ino.bootloader.bin" ) )
1 file(s) copied.
cmd /c if exist "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\build_opt.h" COPY /y "C:\Users\lauri\Documents\Arduino\Projects\ESP32Basics\build_opt.h" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\build_opt.h"
cmd /c if not exist "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\build_opt.h" type nul > "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\build_opt.h"
Detecting libraries used...
"C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\lauri\AppData\Local\Temp\arduino_build_839443/build_opt.h" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\sketch\ESP32Basics.ino.cpp" -o nul
Alternatives for WiFi.h: [WiFiNINA@1.8.13 WiFi@1.2.7 WiFi@2.0.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFiNINA@1.8.13 WiFi@1.2.7 WiFi@2.0.0]
"C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\lauri\AppData\Local\Temp\arduino_build_839443/build_opt.h" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi\src" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\sketch\ESP32Basics.ino.cpp" -o nul
"C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER="v4.4.1-1-gb8050b365e"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/config" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/newlib/platform_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions/freertos" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/port/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freertos/include/esp_additions" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hw_support/port/esp32/private_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/heap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/log/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/include/apps/sntp" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/lwip/src/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/lwip/port/esp32/include/arch" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/soc/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/hal/platform_port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rom/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/soc" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_system/port/public_compat" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/xtensa/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/driver/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_pm/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ringbuf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/efuse/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/vfs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_wifi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_event/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_netif/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_eth/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcpip_adapter/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_phy/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_ipc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_trace/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_timer/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/mbedtls/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mbedtls/esp_crt_bundle/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/app_update/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spi_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bootloader_support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nvs_flash/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/pthread/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_gdbstub/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/espcoredump/include/port/xtensa" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wpa_supplicant/esp_supplicant/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ieee802154/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/console" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/asio/asio/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/asio/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/osi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/include/esp32/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/blufi/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/common/btc/profile/esp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/bt/host/bluedroid/api/include/api" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cbor/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/unity/unity/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/cmock/CMock/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/coap/libcoap/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/nghttp/nghttp2/lib/includes" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-tls/esp-tls-crypto" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_adc_cal/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_hid/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/tcp_transport/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_http_server/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_https_ota/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_lcd/interface" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protobuf-c/protobuf-c" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/common" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/security" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/protocomm/include/transports" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mdns/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_local_ctrl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/sdmmc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_serial_slave_link/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_websocket_client/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/expat/expat/lib" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/expat/port/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wear_levelling/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/diskio" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/vfs" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fatfs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/freemodbus/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/idf_test/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/jsmn/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json/cJSON" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/libsodium/src/libsodium/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/libsodium/port_include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/mqtt/esp-mqtt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/openssl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/perfmon/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/spiffs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ulp/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/wifi_provisioning/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/button/button/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/rmaker_common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_parser/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/json_generator/upstream" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_schedule/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_rainmaker/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/qrcode/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/ws2812_led" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dotprod/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/support/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/hann/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/nuttall/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/windows/flat_top/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/iir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fir/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/add/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sub/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mul/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/addc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/mulc/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/math/sqrt/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/matrix/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/fft/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/dct/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/conv/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/common/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/src" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp_littlefs/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/tool" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/typedef" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/image" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/math" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/nn" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/layer" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/detect" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-dl/include/model_zoo" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp-sr/include/esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/driver/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/esp32-camera/conversions/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/include/fb_gfx/include" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3/tools/sdk/esp32/qspi_qspi/include" -mlongcalls -Wno-frame-address -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DARDUINO_PARTITION_huge_app -DESP32 -DCORE_DEBUG_LEVEL=0 -DBOARD_HAS_PSRAM -mfix-esp32-psram-cache-issue -mfix-esp32-psram-cache-strategy=memw -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\Users\lauri\AppData\Local\Temp\arduino_build_839443/build_opt.h" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\cores\esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\variants\esp32" "-IC:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi\src" "C:\Users\lauri\AppData\Local\Temp\arduino_build_839443\sketch\app_httpd.cpp" -o nul
Alternatives for fd_forward.h: []
ResolveLibrary(fd_forward.h)rror: fd_forward.h: No such file or directory
-> candidates: []ted.
Multiple libraries were found for "WiFi.h"
Used: C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi
Not used: C:\Users\lauri\Documents\Arduino\libraries\WiFiNINA
Not used: D:\Installed Programs\Arduino Offline\Arduino\libraries\WiFi
Using library WiFi at version 2.0.0 in folder: C:\Users\lauri\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\WiFi
exit status 1
I am using a four tab example for the esp32 camera that is trying to find "fd_forward.h" and "fr_forward.h".
// Copyright 2015-2016 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
// http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#include "esp_http_server.h"
#include "esp_timer.h"
#include "esp_camera.h"
#include "img_converters.h"
#include "camera_index.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "fd_forward.h"
#include "fr_forward.h"
#define ENROLL_CONFIRM_TIMES 5
#define FACE_ID_SAVE_NUMBER 7
#define FACE_COLOR_WHITE 0x00FFFFFF
#define FACE_COLOR_BLACK 0x00000000
#define FACE_COLOR_RED 0x000000FF
#define FACE_COLOR_GREEN 0x0000FF00
#define FACE_COLOR_BLUE 0x00FF0000
#define FACE_COLOR_YELLOW (FACE_COLOR_RED | FACE_COLOR_GREEN)
#define FACE_COLOR_CYAN (FACE_COLOR_BLUE | FACE_COLOR_GREEN)
#define FACE_COLOR_PURPLE (FACE_COLOR_BLUE | FACE_COLOR_RED)
typedef struct {
size_t size; //number of values used for filtering
size_t index; //current value index
size_t count; //value count
int sum;
int * values; //array to be filled with values
} ra_filter_t;
typedef struct {
httpd_req_t *req;
size_t len;
} jpg_chunking_t;
#define PART_BOUNDARY "123456789000000000000987654321"
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
static ra_filter_t ra_filter;
httpd_handle_t stream_httpd = NULL;
httpd_handle_t camera_httpd = NULL;
static mtmn_config_t mtmn_config = {0};
static int8_t detection_enabled = 0;
static int8_t recognition_enabled = 0;
static int8_t is_enrolling = 0;
static face_id_list id_list = {0};
static ra_filter_t * ra_filter_init(ra_filter_t * filter, size_t sample_size){
memset(filter, 0, sizeof(ra_filter_t));
filter->values = (int *)malloc(sample_size * sizeof(int));
if(!filter->values){
return NULL;
memset(filter->values, 0, sample_size * sizeof(int));
filter->size = sample_size;
return filter;
static int ra_filter_run(ra_filter_t * filter, int value){
return value;
filter->sum -= filter->values[filter->index];
filter->values[filter->index] = value;
filter->sum += filter->values[filter->index];
filter->index++;
filter->index = filter->index % filter->size;
if (filter->count < filter->size) {
filter->count++;
return filter->sum / filter->count;
static void rgb_print(dl_matrix3du_t *image_matrix, uint32_t color, const char * str){
fb_data_t fb;
fb.width = image_matrix->w;
fb.height = image_matrix->h;
fb.data = image_matrix->item;
fb.bytes_per_pixel = 3;
fb.format = FB_BGR888;
fb_gfx_print(&fb, (fb.width - (strlen(str) * 14)) / 2, 10, color, str);
static int rgb_printf(dl_matrix3du_t *image_matrix, uint32_t color, const char *format, ...){
char loc_buf[64];
char * temp = loc_buf;
int len;
va_list arg;
va_list copy;
va_start(arg, format);
va_copy(copy, arg);
len = vsnprintf(loc_buf, sizeof(loc_buf), format, arg);
va_end(copy);
if(len >= sizeof(loc_buf)){
temp = (char*)malloc(len+1);
if(temp == NULL) {
return 0;
vsnprintf(temp, len+1, format, arg);
va_end(arg);
rgb_print(image_matrix, color, temp);
if(len > 64){
free(temp);
return len;
static void draw_face_boxes(dl_matrix3du_t *image_matrix, box_array_t *boxes, int face_id){
int x, y, w, h, i;
uint32_t color = FACE_COLOR_YELLOW;
if(face_id < 0){
color = FACE_COLOR_RED;
} else if(face_id > 0){
color = FACE_COLOR_GREEN;
fb_data_t fb;
for (i = 0; i < boxes->len; i++){
// rectangle box
x = (int)boxes->box[i].box_p[0];
y = (int)boxes->box[i].box_p[1];
w = (int)boxes->box[i].box_p[2] - x + 1;
h = (int)boxes->box[i].box_p[3] - y + 1;
fb_gfx_drawFastHLine(&fb, x, y, w, color);
fb_gfx_drawFastHLine(&fb, x, y+h-1, w, color);
fb_gfx_drawFastVLine(&fb, x, y, h, color);
fb_gfx_drawFastVLine(&fb, x+w-1, y, h, color);
#if 0
// landmark
int x0, y0, j;
for (j = 0; j < 10; j+=2) {
x0 = (int)boxes->landmark[i].landmark_p[j];
y0 = (int)boxes->landmark[i].landmark_p[j+1];
fb_gfx_fillRect(&fb, x0, y0, 3, 3, color);
#endif
static int run_face_recognition(dl_matrix3du_t *image_matrix, box_array_t *net_boxes){
dl_matrix3du_t *aligned_face = NULL;
int matched_id = 0;
aligned_face = dl_matrix3du_alloc(1, FACE_WIDTH, FACE_HEIGHT, 3);
if(!aligned_face){
Serial.println("Could not allocate face recognition buffer");
return matched_id;
if (align_face(net_boxes, image_matrix, aligned_face) == ESP_OK){
if (is_enrolling == 1){
int8_t left_sample_face = enroll_face(&id_list, aligned_face);
if(left_sample_face == (ENROLL_CONFIRM_TIMES - 1)){
Serial.printf("Enrolling Face ID: %d\n", id_list.tail);
Serial.printf("Enrolling Face ID: %d sample %d\n", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
rgb_printf(image_matrix, FACE_COLOR_CYAN, "ID[%u] Sample[%u]", id_list.tail, ENROLL_CONFIRM_TIMES - left_sample_face);
if (left_sample_face == 0){
is_enrolling = 0;
Serial.printf("Enrolled Face ID: %d\n", id_list.tail);
matched_id = recognize_face(&id_list, aligned_face);
if (matched_id >= 0) {
Serial.printf("Match Face ID: %u\n", matched_id);
rgb_printf(image_matrix, FACE_COLOR_GREEN, "Hello Subject %u", matched_id);
Serial.println("No Match Found");
rgb_print(image_matrix, FACE_COLOR_RED, "Intruder Alert!");
matched_id = -1;
Serial.println("Face Not Aligned");
//rgb_print(image_matrix, FACE_COLOR_YELLOW, "Human Detected");
dl_matrix3du_free(aligned_face);
return matched_id;
static size_t jpg_encode_stream(void * arg, size_t index, const void* data, size_t len){
jpg_chunking_t *j = (jpg_chunking_t *)arg;
if(!index){
j->len = 0;
if(httpd_resp_send_chunk(j->req, (const char *)data, len) != ESP_OK){
return 0;
j->len += len;
return len;
static esp_err_t capture_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
int64_t fr_start = esp_timer_get_time();
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
httpd_resp_send_500(req);
return ESP_FAIL;
httpd_resp_set_type(req, "image/jpeg");
httpd_resp_set_hdr(req, "Content-Disposition", "inline; filename=capture.jpg");
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
size_t out_len, out_width, out_height;
uint8_t * out_buf;
bool s;
bool detected = false;
int face_id = 0;
if(!detection_enabled || fb->width > 400){
size_t fb_len = 0;
if(fb->format == PIXFORMAT_JPEG){
fb_len = fb->len;
res = httpd_resp_send(req, (const char *)fb->buf, fb->len);
jpg_chunking_t jchunk = {req, 0};
res = frame2jpg_cb(fb, 80, jpg_encode_stream, &jchunk)?ESP_OK:ESP_FAIL;
httpd_resp_send_chunk(req, NULL, 0);
fb_len = jchunk.len;
esp_camera_fb_return(fb);
int64_t fr_end = esp_timer_get_time();
Serial.printf("JPG: %uB %ums\n", (uint32_t)(fb_len), (uint32_t)((fr_end - fr_start)/1000));
return res;
dl_matrix3du_t *image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
if (!image_matrix) {
Serial.println("dl_matrix3du_alloc failed");
return ESP_FAIL;
out_buf = image_matrix->item;
out_len = fb->width * fb->height * 3;
out_width = fb->width;
out_height = fb->height;
s = fmt2rgb888(fb->buf, fb->len, fb->format, out_buf);
if(!s){
dl_matrix3du_free(image_matrix);
Serial.println("to rgb888 failed");
return ESP_FAIL;
box_array_t *net_boxes = face_detect(image_matrix, &mtmn_config);
if (net_boxes){
detected = true;
if(recognition_enabled){
face_id = run_face_recognition(image_matrix, net_boxes);
draw_face_boxes(image_matrix, net_boxes, face_id);
free(net_boxes->score);
free(net_boxes->box);
free(net_boxes->landmark);
free(net_boxes);
s = fmt2jpg_cb(out_buf, out_len, out_width, out_height, PIXFORMAT_RGB888, 90, jpg_encode_stream, &jchunk);
if(!s){
Serial.println("JPEG compression failed");
return ESP_FAIL;
Serial.printf("FACE: %uB %ums %s%d\n", (uint32_t)(jchunk.len), (uint32_t)((fr_end - fr_start)/1000), detected?"DETECTED ":"", face_id);
return res;
static esp_err_t stream_handler(httpd_req_t *req){
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
dl_matrix3du_t *image_matrix = NULL;
int face_id = 0;
int64_t fr_start = 0;
int64_t fr_ready = 0;
int64_t fr_face = 0;
int64_t fr_recognize = 0;
int64_t fr_encode = 0;
static int64_t last_frame = 0;
if(!last_frame) {
last_frame = esp_timer_get_time();
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
detected = false;
face_id = 0;
if (!fb) {
res = ESP_FAIL;
fr_ready = fr_start;
fr_face = fr_start;
fr_encode = fr_start;
fr_recognize = fr_start;
if(fb->format != PIXFORMAT_JPEG){
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
fb = NULL;
if(!jpeg_converted){
res = ESP_FAIL;
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
res = ESP_FAIL;
if(!fmt2rgb888(fb->buf, fb->len, fb->format, image_matrix->item)){
Serial.println("fmt2rgb888 failed");
res = ESP_FAIL;
fr_ready = esp_timer_get_time();
box_array_t *net_boxes = NULL;
if(detection_enabled){
fr_face = esp_timer_get_time();
fr_recognize = fr_face;
if (net_boxes || fb->format != PIXFORMAT_JPEG){
if(net_boxes){
detected = true;
fr_recognize = esp_timer_get_time();
free(net_boxes);
if(!fmt2jpg(image_matrix->item, fb->width*fb->height*3, fb->width, fb->height, PIXFORMAT_RGB888, 90, &_jpg_buf, &_jpg_buf_len)){
Serial.println("fmt2jpg failed");
res = ESP_FAIL;
fb = NULL;
_jpg_buf = fb->buf;
fr_encode = esp_timer_get_time();
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(fb){
fb = NULL;
_jpg_buf = NULL;
} else if(_jpg_buf){
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
int64_t ready_time = (fr_ready - fr_start)/1000;
int64_t face_time = (fr_face - fr_ready)/1000;
int64_t recognize_time = (fr_recognize - fr_face)/1000;
int64_t encode_time = (fr_encode - fr_recognize)/1000;
int64_t process_time = (fr_encode - fr_start)/1000;
int64_t frame_time = fr_end - last_frame;
last_frame = fr_end;
frame_time /= 1000;
uint32_t avg_frame_time = ra_filter_run(&ra_filter, frame_time);
Serial.printf("MJPG: %uB %ums (%.1ffps), AVG: %ums (%.1ffps), %u+%u+%u+%u=%u %s%d\n",
(uint32_t)(_jpg_buf_len),
(uint32_t)frame_time, 1000.0 / (uint32_t)frame_time,
avg_frame_time, 1000.0 / avg_frame_time,
(uint32_t)ready_time, (uint32_t)face_time, (uint32_t)recognize_time, (uint32_t)encode_time, (uint32_t)process_time,
(detected)?"DETECTED ":"", face_id
last_frame = 0;
return res;
static esp_err_t cmd_handler(httpd_req_t *req){
char* buf;
size_t buf_len;
char variable[32] = {0,};
char value[32] = {0,};
buf_len = httpd_req_get_url_query_len(req) + 1;
if (buf_len > 1) {
buf = (char*)malloc(buf_len);
if(!buf){
return ESP_FAIL;
if (httpd_req_get_url_query_str(req, buf, buf_len) == ESP_OK) {
if (httpd_query_key_value(buf, "var", variable, sizeof(variable)) == ESP_OK &&
httpd_query_key_value(buf, "val", value, sizeof(value)) == ESP_OK) {
free(buf);
httpd_resp_send_404(req);
return ESP_FAIL;
free(buf);
return ESP_FAIL;
free(buf);
return ESP_FAIL;
int val = atoi(value);
sensor_t * s = esp_camera_sensor_get();
int res = 0;
if(!strcmp(variable, "framesize")) {
if(s->pixformat == PIXFORMAT_JPEG) res = s->set_framesize(s, (framesize_t)val);
else if(!strcmp(variable, "quality")) res = s->set_quality(s, val);
else if(!strcmp(variable, "contrast")) res = s->set_contrast(s, val);
else if(!strcmp(variable, "brightness")) res = s->set_brightness(s, val);
else if(!strcmp(variable, "saturation")) res = s->set_saturation(s, val);
else if(!strcmp(variable, "gainceiling")) res = s->set_gainceiling(s, (gainceiling_t)val);
else if(!strcmp(variable, "colorbar")) res = s->set_colorbar(s, val);
else if(!strcmp(variable, "awb")) res = s->set_whitebal(s, val);
else if(!strcmp(variable, "agc")) res = s->set_gain_ctrl(s, val);
else if(!strcmp(variable, "aec")) res = s->set_exposure_ctrl(s, val);
else if(!strcmp(variable, "hmirror")) res = s->set_hmirror(s, val);
else if(!strcmp(variable, "vflip")) res = s->set_vflip(s, val);
else if(!strcmp(variable, "awb_gain")) res = s->set_awb_gain(s, val);
else if(!strcmp(variable, "agc_gain")) res = s->set_agc_gain(s, val);
else if(!strcmp(variable, "aec_value")) res = s->set_aec_value(s, val);
else if(!strcmp(variable, "aec2")) res = s->set_aec2(s, val);
else if(!strcmp(variable, "dcw")) res = s->set_dcw(s, val);
else if(!strcmp(variable, "bpc")) res = s->set_bpc(s, val);
else if(!strcmp(variable, "wpc")) res = s->set_wpc(s, val);
else if(!strcmp(variable, "raw_gma")) res = s->set_raw_gma(s, val);
else if(!strcmp(variable, "lenc")) res = s->set_lenc(s, val);
else if(!strcmp(variable, "special_effect")) res = s->set_special_effect(s, val);
else if(!strcmp(variable, "wb_mode")) res = s->set_wb_mode(s, val);
else if(!strcmp(variable, "ae_level")) res = s->set_ae_level(s, val);
else if(!strcmp(variable, "face_detect")) {
detection_enabled = val;
if(!detection_enabled) {
else if(!strcmp(variable, "face_enroll")) is_enrolling = val;
else if(!strcmp(variable, "face_recognize")) {
recognition_enabled = val;
else {
res = -1;
if(res){
return httpd_resp_send_500(req);
return httpd_resp_send(req, NULL, 0);
static esp_err_t status_handler(httpd_req_t *req){
static char json_response[1024];
char * p = json_response;
*p++ = '{';
p+=sprintf(p, "\"framesize\":%u,", s->status.framesize);
p+=sprintf(p, "\"quality\":%u,", s->status.quality);
p+=sprintf(p, "\"brightness\":%d,", s->status.brightness);
p+=sprintf(p, "\"contrast\":%d,", s->status.contrast);
p+=sprintf(p, "\"saturation\":%d,", s->status.saturation);
p+=sprintf(p, "\"sharpness\":%d,", s->status.sharpness);
p+=sprintf(p, "\"special_effect\":%u,", s->status.special_effect);
p+=sprintf(p, "\"wb_mode\":%u,", s->status.wb_mode);
p+=sprintf(p, "\"awb\":%u,", s->status.awb);
p+=sprintf(p, "\"awb_gain\":%u,", s->status.awb_gain);
p+=sprintf(p, "\"aec\":%u,", s->status.aec);
p+=sprintf(p, "\"aec2\":%u,", s->status.aec2);
p+=sprintf(p, "\"ae_level\":%d,", s->status.ae_level);
p+=sprintf(p, "\"aec_value\":%u,", s->status.aec_value);
p+=sprintf(p, "\"agc\":%u,", s->status.agc);
p+=sprintf(p, "\"agc_gain\":%u,", s->status.agc_gain);
p+=sprintf(p, "\"gainceiling\":%u,", s->status.gainceiling);
p+=sprintf(p, "\"bpc\":%u,", s->status.bpc);
p+=sprintf(p, "\"wpc\":%u,", s->status.wpc);
p+=sprintf(p, "\"raw_gma\":%u,", s->status.raw_gma);
p+=sprintf(p, "\"lenc\":%u,", s->status.lenc);
p+=sprintf(p, "\"vflip\":%u,", s->status.vflip);
p+=sprintf(p, "\"hmirror\":%u,", s->status.hmirror);
p+=sprintf(p, "\"dcw\":%u,", s->status.dcw);
p+=sprintf(p, "\"colorbar\":%u,", s->status.colorbar);
p+=sprintf(p, "\"face_detect\":%u,", detection_enabled);
p+=sprintf(p, "\"face_enroll\":%u,", is_enrolling);
p+=sprintf(p, "\"face_recognize\":%u", recognition_enabled);
*p++ = '}';
*p++ = 0;
httpd_resp_set_type(req, "application/json");
return httpd_resp_send(req, json_response, strlen(json_response));
static esp_err_t index_handler(httpd_req_t *req){
httpd_resp_set_type(req, "text/html");
httpd_resp_set_hdr(req, "Content-Encoding", "gzip");
if (s->id.PID == OV3660_PID) {
return httpd_resp_send(req, (const char *)index_ov3660_html_gz, index_ov3660_html_gz_len);
return httpd_resp_send(req, (const char *)index_ov2640_html_gz, index_ov2640_html_gz_len);
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = index_handler,
.user_ctx = NULL
httpd_uri_t status_uri = {
.uri = "/status",
.method = HTTP_GET,
.handler = status_handler,
.user_ctx = NULL
httpd_uri_t cmd_uri = {
.uri = "/control",
.method = HTTP_GET,
.handler = cmd_handler,
.user_ctx = NULL
httpd_uri_t capture_uri = {
.uri = "/capture",
.method = HTTP_GET,
.handler = capture_handler,
.user_ctx = NULL
httpd_uri_t stream_uri = {
.uri = "/stream",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
ra_filter_init(&ra_filter, 20);
mtmn_config.type = FAST;
mtmn_config.min_face = 80;
mtmn_config.pyramid = 0.707;
mtmn_config.pyramid_times = 4;
mtmn_config.p_threshold.score = 0.6;
mtmn_config.p_threshold.nms = 0.7;
mtmn_config.p_threshold.candidate_number = 20;
mtmn_config.r_threshold.score = 0.7;
mtmn_config.r_threshold.nms = 0.7;
mtmn_config.r_threshold.candidate_number = 10;
mtmn_config.o_threshold.score = 0.7;
mtmn_config.o_threshold.nms = 0.7;
mtmn_config.o_threshold.candidate_number = 1;
face_id_init(&id_list, FACE_ID_SAVE_NUMBER, ENROLL_CONFIRM_TIMES);
Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&camera_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(camera_httpd, &index_uri);
httpd_register_uri_handler(camera_httpd, &cmd_uri);
httpd_register_uri_handler(camera_httpd, &status_uri);
httpd_register_uri_handler(camera_httpd, &capture_uri);
config.server_port += 1;
config.ctrl_port += 1;
Serial.printf("Starting stream server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &stream_uri);
