I'm trying to build an automated system which will execute a different set of commands depending on the barcode which has been scanned. Ideally I would like the barcode scanner to send the string it scans to the arduino where i can match that up to a defined case that will execute those specific commands. Also I would want to scan multiple barcodes at once and have the arduino work through them one at a time.
Right now I have a barcode scanner (USB), a Mega board, and a USB host shield.
I have been looking around and have seen some instructions on using a keyboard to control an arduino, but the ones that I was able to follow were using the serial monitor. I would like to not have a computer attached if possible. Also many barcode scanner instructions were using ps/2 instead of USB HID scanners.
So I imagine something like this:
Scan barcodes: 22223456, 33334567, 44445678
Arduino Reads 22223456
if String=="22223456"
Write Motor1 HIGH
Arduino Reads 33334567 ....
I'm not sure what libraries/ functions to use or if I need anything else to get this to work as I intend
