Feasibility of using ISFET pH sensor with arduino logger, underwater
Hi all,
It sounds like for logging ph that standard glass ph sensors drift too fast to be useful. Ion Sensitive Field Effect transistor (ISFET) sensors are now being used on the underwater pH loggers because they hold calibration a lot longer.
I know it's possible to use ISFET sensors for arduino units to hook up to them (example here and library here), but the question is how difficult it would be to actually build something.
I don't have a background in electronics. I can put together arduino stuff, and have become an okay solderer, and follow/adapt instructions well enough to not blow things up (much).
One of the difficult things seems to be actually getting ahold of an ISFET sensor, so actual guides on how to hook up an ISFET sensor to an arduino unit seem to be sparse (I can't find any), so I'm in the dark compared to what I've done so far. Assuming I can get one, how hard would it be to hook it up? For this sensor here they've got a "measurement circuit recommendation". I recognise the pieces in the circuit, but I don't know how an arduino would fit in there (there's 2 Op Amps?).
I'm not asking anyone to give me a step by step, more a vague guess as to how difficult this would be electronically and coding, ranging from "yeah, this would be pretty simple", "wow, I've been doing this for decades and would consider this a challenge!" or "you obviously have no idea, this is completely wrong for this application". If it's doable I'll dig deeper to look at costs and supplies.
Thanks for any guidance.
It can be done, I found some sensors for less then $20.00 from the popular china suppliers. Here is a paper that may help: http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.95.2321&rep=rep1&type=pdf They give circuits etc. These circuits are Analog in nature and are difficult if you do not have analog experience. Here is a Kit, much more then just the sensor but it may help you: This product is no longer available.. Have fun, you will learn a lot by the time you finish this.
Thanks for the reply, and the info. It looks like the alibaba link is gone, I'll have a look around there.
Would you be able to suggest some of the chinese sensor suppliers? I've only got experience with smaller local places, and digikey, mouser, rs components.
Thanks
