I am quite new to this and I have a code which will run an MPU 6050 and a BMP 180 at the same time and display the data on an LCD display and on the serial monitor. However when I do run the code on an Arduino Uno, correct values from the BMP get displayed but the MPU data for the gyroscope gets messed up and just says FIFO overflow! If anyone could help me it would be greatly appreciated.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 7);
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
MPU6050 mpu;
#define OUTPUT_READABLE_YAWPITCHROLL
#define INTERRUPT_PIN 2
#define LED_PIN 13
bool blinkState = false;
bool dmpReady = false;
uint8_t mpuIntStatus;
uint8_t devStatus;
uint16_t packetSize;
uint16_t fifoCount;
uint8_t fifoBuffer[64];
Quaternion q;
VectorInt16 aa;
VectorInt16 aaReal;
VectorInt16 aaWorld;
VectorFloat gravity;
float euler[3];
float ypr[3];
uint8_t teapotPacket[14] = { '
, 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
volatile bool mpuInterrupt = false;
void dmpDataReady() {
mpuInterrupt = true;
lcd.begin(16,2);
if (!bmp.begin())
Serial.println("BMP180 sensor not found");
while (1) {}
Wire.begin();
Wire.setClock(400000);
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
Fastwire::setup(400, true);
#endif
while (!Serial);
Serial.println(F("Initializing I2C devices..."));
mpu.initialize();
pinMode(INTERRUPT_PIN, INPUT);
Serial.println(F("Testing device connections..."));
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
Serial.println(F("\nSend any character to begin DMP programming and demo: "));
while (Serial.available() && Serial.read());
while (!Serial.available());
Serial.println(F("Initializing DMP..."));
devStatus = mpu.dmpInitialize();
mpu.setXGyroOffset(50);
mpu.setYGyroOffset(-18);
mpu.setZGyroOffset(22);
if (devStatus == 0) {
Serial.println(F("Enabling DMP..."));
mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
Serial.println(F("DMP ready! Waiting for first interrupt..."));
dmpReady = true;
packetSize = mpu.dmpGetFIFOPacketSize();
Serial.print(F("DMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
pinMode(LED_PIN, OUTPUT);
if (!dmpReady) return;
while (!mpuInterrupt && fifoCount < packetSize) {
fifoCount = mpu.getFIFOCount();
if ((mpuIntStatus & 0x10) || fifoCount == 1024) {
mpu.resetFIFO();
Serial.println(F("FIFO overflow!"));
} else if (mpuIntStatus & 0x02)
while (fifoCount < packetSize) fifoCount = mpu.getFIFOCount();
mpu.getFIFOBytes(fifoBuffer, packetSize);
mpu.resetFIFO();
#ifdef OUTPUT_READABLE_YAWPITCHROLL
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
Serial.print("ypr\t");
Serial.print(ypr[0] * 180/M_PI);
Serial.print("\t");
Serial.print(ypr[1] * 180/M_PI);
Serial.print("\t");
Serial.println(ypr[2] * 180/M_PI);
#endif
Serial.print("Temperature = ");
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print("Altitude = ");
Serial.print(bmp.readAltitude());
Serial.println("M");
Serial.print("Pressure = ");
Serial.print(bmp.readPressure());
Serial.println("Pa");
lcd.setCursor(1,0);
lcd.print(bmp.readTemperature());
lcd.print("C ");
lcd.setCursor(8,0);
lcd.print(bmp.readAltitude());
lcd.print("M ");
lcd.setCursor(0,1);
lcd.print(bmp.readPressure());
lcd.print("Pa ");
lcd.setCursor(0,0);
lcd.print(ypr[0] * 180/M_PI);
lcd.setCursor(9,0);
lcd.print(ypr[1] * 180/M_PI);
lcd.setCursor(0,1);
lcd.print(ypr[2] * 180/M_PI);
