I'd like to transfer files (txt or csv, one at a time, less than 1kBytes each) from an Arduino based board via Bluetooth to a PC or a mobile device (Tablet, running Android).
Using terminal software like HyperTerm, PuTTY or whatever works but is not a practical solution with having to start the terminal software, opening a logfile, sending the file, closing the logfile etc.
I'm think more of the way it works whe I send files from my mobile device to a PC or vice versa. I start the transfer ("send to" or "share") on one device and on the other device, a little window pops up, informing my that a file is or has been transferred.
Would it be possible to do that on an Arduino board (with BT, of course) ? The Arduino initiating the transfer, Android device or PC receiving it (without logging via terminal program, as explained above) ?
Yes, I do know to set up a BT connection, that not the problem ![]()
There were a few post regarding similar problems but I could not find a real solution to this problem.
Maybe, by now someone has figured out how to do that with modules like HC-0x ?
Thanks already for the support !
