I just bought an FIO and was successfully working with it where in i changed a small thing in sense that i powered it from the USB that is there for charging only and then connected the rx and tx to the rx ant tx of the duemilanove which i always use to programme it successfully but soon after the red LED NEAR the reset switch started blinking really fastly. and no sketch upload can happen.
Did you manage to solve this issue? I'm facing the same problem now :sleeping:
Was programming my Fio wirelessly using xBee and after a out of sync happened, the fio's led keeps blinking away...
Even after turning off and on a number of times,
Would be grateful for a solution to this! thanks!
