A fatal error occurred: Failed to connect to ESP32: Download mode successfully detected, but getting no sync reply: The serial TX path seems to be down.
For troubleshooting steps visit: Troubleshooting - ESP32 - — esptool.py latest documentation
Failed uploading: uploading error: exit status 2
I a using an esp32 fire beetle with some sensors after doing trouble shouting and changing equipment I get this new error, I don't think its my codes or connection but my laptop having the issue but this is the program
#include <Arduino.h>
#include "DFRobot_LCD.h"
#include <Wire.h>
#include "WiFi.h"
// DO SENSOR-----------------------------------------------------------------/
#define DO_PIN A1
#define VREF 5000 // VREF(mv)
#define ADC_RES 1024 //ADC Resolution/
#define SINGLE_POINT_CALIBRATION 0
#define READ_TEMP (25)
#define CAL1_V (8354) //mv CHANGE AFTER CALIBRATION
#define CAL1_T (25) //℃
const uint16_t DO_Table[41] = {
14460, 14220, 13820, 13440, 13090, 12740, 12420, 12110, 11810, 11530,
11260, 11010, 10770, 10530, 10300, 10080, 9860, 9660, 9460, 9270,
9080, 8900, 8730, 8570, 8410, 8250, 8110, 7960, 7820, 7690,
7560, 7430, 7300, 7180, 7070, 6950, 6840, 6730, 6630, 6530, 6410
uint8_t Temperaturet;
uint16_t ADC_Raw;
uint16_t ADC_Voltage;
uint16_t DO;
int16_t readDO(uint32_t voltage_mv, uint8_t temperature_c) {
#if SINGLE_POINT_CALIBRATION == 00
uint16_t V_saturation = (uint32_t)CAL1_V + (uint32_t)35 * temperature_c - (uint32_t)CAL1_T * 35;
return (voltage_mv * DO_Table[temperature_c] / V_saturation);
#else
uint16_t V_saturation = (int16_t)((int8_t)temperature_c - CAL2_T) * ((uint16_t)CAL1_V - CAL2_V) / ((uint8_t)CAL1_T - CAL2_T) + CAL2_V;
#endif
// pH SENSOR---------------------------------------/
DFRobot_LCD lcd(16, 2); //16 characters and 2 lines of show
#define PH_PIN 25
float voltage, phvalue, temperature = 25;
float acidVoltage = 2000; //buffer solution at 4.o
float neutralVoltage = 1390; //buffer solution at 7.o
const int Sensor_MINvalue1 = 6.5; // +-0.5 from ph 4.0
const int Sensor_MAXvalue1 = 7.5;
// LCD Begin //
lcd.init();
lcd.setCursor(4, 0);
lcd.print("Welcome");
lcd.clear();
lcd.setCursor(3, 0);
lcd.print("Reading ");
lcd.setCursor(3, 1);
lcd.print("pH & DO");
lcd.clear();
lcd.print("Please Wait");
lcd.clear();
//pH SENSOR--------------------------------------//
static unsigned long timepoint = millis();
if (millis() - timepoint > 1000U) {
timepoint = millis(); // timepoint = read temperature **
voltage = analogRead(PH_PIN) / 4095.0 * 3300;
float slope = (7.0 - 4.0) / ((neutralVoltage - 1500) / 30 - (acidVoltage - 1500) / 3.0);
float intercept = 7.0 - slope * (neutralVoltage - 1500) / 3.0;
phvalue = slope * (voltage - 1500) / 3.0 + intercept; // y=k*x + b [formula]
if (phvalue < Sensor_MAXvalue1 && phvalue > Sensor_MINvalue1) {
Serial.print("Voltage:");
Serial.print(voltage, 1);
Serial.print("PH:");
Serial.println(phvalue, 2);
//LCD setting 16x2
lcd.setCursor(0, 0);
lcd.print("PH: ");
lcd.print(phvalue, 2);
lcd.setCursor(0, 1);
lcd.print("Volt: ");
lcd.print(voltage / 1000, 2);
lcd.init();
lcd.print("DOSING REQUIRED");
lcd.clear();
Temperaturet = (uint8_t)READ_TEMP;
ADC_Raw = analogRead(DO_PIN);
ADC_Voltage = uint32_t(VREF) * ADC_Raw / ADC_RES;
Serial.print("Temperaturet:\t" + String(Temperaturet) + "\t");
Serial.print("ADC RAW:\t" + String(ADC_Raw) + "\t");
Serial.print("ADC Voltage:\t" + String(ADC_Voltage) + "\t");
Serial.println("DO:\t" + String(readDO(ADC_Voltage, Temperaturet)) + "\t");
//LCD setting 16x2
lcd.setCursor(9, 0);
lcd.print((readDO(ADC_Voltage, Temperaturet)) / 1000);
lcd.print("mg/L");
delay(5000);
lcd.clear();
return;
