Hello,
I wanted to post a picture of my first circuit, thanks to @dfraser 's project here.
This is the diagram I referenced, my circuit, and the sketch below.
#define icpPin 8 // ICP input pin on arduino
#define one_time_max 475 // these values are setup for NTSC video
#define one_time_min 300 // PAL would be around 1000 for 0 and 500 for 1
#define zero_time_max 875 // 80bits times 29.97 frames per sec
#define zero_time_min 700 // equals 833 (divide by 8 clock pulses)
#define end_data_position 63
#define end_sync_position 77
#define end_smpte_position 80
volatile unsigned int bit_time;
volatile boolean valid_tc_word;
volatile boolean ones_bit_count;
volatile boolean tc_sync;
volatile boolean write_tc_out;
volatile boolean drop_frame_flag;
volatile byte total_bits;
volatile byte current_bit;
volatile byte sync_count;
volatile byte tc[8];
volatile char timeCode[11];
/* ICR interrupt vector */
ISR(TIMER1_CAPT_vect)
//toggleCaptureEdge
TCCR1B ^= _BV(ICES1);
bit_time = ICR1;
//resetTimer1
TCNT1 = 0;
if ((bit_time < one_time_min) || (bit_time > zero_time_max)) // get rid of anything way outside the norm
//Serial.println(bit_time, DEC);
total_bits = 0;
if (ones_bit_count == true) // only count the second ones pluse
ones_bit_count = false;
if (bit_time > zero_time_min)
current_bit = 0;
sync_count = 0;
else //if (bit_time < one_time_max)
ones_bit_count = true;
current_bit = 1;
sync_count++;
if (sync_count == 12) // part of the last two bytes of a timecode word
sync_count = 0;
tc_sync = true;
total_bits = end_sync_position;
if (total_bits <= end_data_position) // timecode runs least to most so we need
{ // to shift things around
tc[0] = tc[0] >> 1;
for(int n=1;n<8;n++)
if(tc[n] & 1)
tc[n-1] |= 0x80;
tc[n] = tc[n] >> 1;
if(current_bit == 1)
tc[7] |= 0x80;
total_bits++;
if (total_bits == end_smpte_position) // we have the 80th bit
total_bits = 0;
if (tc_sync)
tc_sync = false;
valid_tc_word = true;
if (valid_tc_word)
valid_tc_word = false;
timeCode[10] = (tc[0]&0x0F)+0x30; // frames
timeCode[9] = (tc[1]&0x03)+0x30; // 10's of frames
timeCode[8] = '.';
timeCode[7] = (tc[2]&0x0F)+0x30; // seconds
timeCode[6] = (tc[3]&0x07)+0x30; // 10's of seconds
timeCode[5] = ':';
timeCode[4] = (tc[4]&0x0F)+0x30; // minutes
timeCode[3] = (tc[5]&0x07)+0x30; // 10's of minutes
timeCode[2] = ':';
timeCode[1] = (tc[6]&0x0F)+0x30; // hours
timeCode[0] = (tc[7]&0x03)+0x30; // 10's of hours
drop_frame_flag = (tc[1]&0x04)!=0;
write_tc_out = true;
pinMode(icpPin, INPUT); // ICP pin (digital pin 8 on arduino) as input
bit_time = 0;
tc_sync = false;
write_tc_out = false;
drop_frame_flag = false;
total_bits = 0;
current_bit = 0;
sync_count = 0;
//Serial.println("Finished setup ");
//delay (1000);
TCCR1A = B00000000; // clear all
TCCR1B = B11000010; // ICNC1 noise reduction + ICES1 start on rising edge + CS11 divide by 8
TCCR1C = B00000000; // clear all
TIMSK1 = B00100000; // ICIE1 enable the icp
TCNT1 = 0; // clear timer1
if (write_tc_out)
if (drop_frame_flag)
Serial.print("TC-[df] ");
Serial.print("TC-[nd] ");
Serial.print((char*)timeCode);
Serial.print("\r");
So far I have not been able to get anything to show up on Serial Monitor, and since I'm a total beginner, I'm not sure how to check whether it's a problem with my circuit, the code, or something else.
Any ideas? Thanks so much!
