IDE 1.8.12
Similar errors no matter what I select in processor or com (com1/com3).
I feel it's the usb cable? But the leds go on and blink.
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P"
E:\Arduino\arduino-builder -dump-prefs -logger=machine -hardware E:\Arduino\hardware -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -built-in-libraries E:\Arduino\libraries -libraries C:\Users\usr\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10812 -build-path C:\Users\usr\AppData\Local\Temp\arduino_build_348 -warnings=none -build-cache C:\Users\usr\AppData\Local\Temp\arduino_cache_476124 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=E:\Arduino\hardware\tools\avr -verbose E:\Arduino\examples\01.Basics\Blink\Blink.ino
E:\Arduino\arduino-builder -compile -logger=machine -hardware E:\Arduino\hardware -tools E:\Arduino\tools-builder -tools E:\Arduino\hardware\tools\avr -built-in-libraries E:\Arduino\libraries -libraries C:\Users\usr\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=0000_0000 -ide-version=10812 -build-path C:\Users\usr\AppData\Local\Temp\arduino_build_348 -warnings=none -build-cache C:\Users\usr\AppData\Local\Temp\arduino_cache_476124 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=E:\Arduino\hardware\tools\avr -verbose E:\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'nano' from platform in folder: E:\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: E:\Arduino\hardware\arduino\avr
Detecting libraries used...
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IE:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IE:\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\sketch\\Blink.ino.cpp" -o nul
Generating function prototypes...
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IE:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IE:\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\sketch\\Blink.ino.cpp" -o "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"E:\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IE:\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IE:\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\sketch\\Blink.ino.cpp" -o "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\usr\AppData\Local\Temp\arduino_cache_476124\core\core_arduino_avr_nano_cpu_atmega328_bec0e371aed0e79de25b363fa38c6895.a
Linking everything together...
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.elf" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348\\sketch\\Blink.ino.cpp.o" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/..\\arduino_cache_476124\\core\\core_arduino_avr_nano_cpu_atmega328_bec0e371aed0e79de25b363fa38c6895.a" "-LC:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348" -lm
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.elf" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.eep"
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.elf" "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.hex"
"E:\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\usr\\AppData\\Local\\Temp\\arduino_build_348/Blink.ino.elf"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
E:\Arduino\hardware\tools\avr/bin/avrdude -CE:\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\usr\AppData\Local\Temp\arduino_build_348/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM1
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x59
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
