(Some back story if you do not want to read it skip to the next paragraph) I am making an electronic monopoly game with my brother with two Arduinos communicating with I2C. One has the controls and brains the other has NeoPixels for the houses and hotterls and buttons as commands for the houses. I have made almost all of the code but I haven't tested it yet with both Arduinos (fingers crossed it doesn't destroy my brain). Here is the issue the arduino with controls and brains (let's call it Brainduino) has also a DFplayer mini for sound effects (ex. when a player goes to a train station or does a transaction things like that.). When we first started the project I was in "charge" primarily of the electronics and the code. But now I have hit a wall. Mind you when I started my coding knowledge was pretty much toddler-like.
I have added to the dfplayer via a formatted to fat32 small SD card two songs. I am powering it via the 5v output of the arduino since I am still in the testing phase. The TX of the arduino is connected to the RX of the df player via a 1.2kΩ resistor (it was the only one I had lying around and I could make) and the Rx of the arduino is directly wired in. I can play the song by bringing the DF player but when I use the example sketch all I get is this
Unable to begin:
1.Please recheck the connection!
2.Please insert the SD card!
DFPlayer - A Mini MP3 Player For Arduino
<https://www.dfrobot.com/product-1121.html>
This example shows the basic function of library for DFPlayer.
Created 2016-12-07
By [Angelo qiao](Angelo.qiao@dfrobot.com)
GNU Lesser General Public License.
See <http://www.gnu.org/licenses/> for details.
All above must be included in any redistribution
/***********Notice and Trouble shooting***************
1.Connection and Diagram can be found here
<https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299#Connection_Diagram>
2.This code is tested on Arduino Uno, Leonardo, Mega boards.
#include "Arduino.h"
#include "DFRobotDFPlayerMini.h"
#if (defined(ARDUINO_AVR_UNO) || defined(ESP8266)) // Using a soft serial port
#include <SoftwareSerial.h>
SoftwareSerial softSerial(/*rx =*/17, /*tx =*/16);
#define FPSerial softSerial
#else
#define FPSerial Serial1
#endif
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
#if (defined ESP32)
FPSerial.begin(9600, SERIAL_8N1, /*rx =*/D3, /*tx =*/D2);
#else
FPSerial.begin(9600);
#endif
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(FPSerial, /*isACK = */true, /*doReset = */true)) { //Use serial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true){
delay(0); // Code to compatible with ESP8266 watch dog.
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.volume(10); //Set volume value. From 0 to 30
myDFPlayer.play(1); //Play the first mp3
static unsigned long timer = millis();
if (millis() - timer > 3000) {
timer = millis();
myDFPlayer.next(); //Play next mp3 every 3 second.
if (myDFPlayer.available()) {
printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerUSBInserted:
Serial.println("USB Inserted!");
case DFPlayerUSBRemoved:
Serial.println("USB Removed!");
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
Oh OK thanks I will try it. So I should remove software serial and instead of mySerial.begin(baudrate) I should have serial2.begin(baudrate)? Sorry for my lack of knowledge... I am just not sure what I should change... (sorry)
Unable to begin:
And my code is as follows
Created 2016-12-07
#define FPSerial Serial2
void setup(){
while(true){
myDFPlayer.volume(5); //Set volume value. From 0 to 30
timer = millis();
switch (type) {
case TimeOut:
case WrongStack:
case DFPlayerError:
switch (value) {
case Busy:
case Sleeping:
case FileIndexOut:
case FileMismatch:
case Advertise:
default:
default:
Created 2016-12-07
void setup(){
while(true){
myDFPlayer.play(001); // Ensure that your files have been renamed to 001, 002, etc.
switch (type) {
case TimeOut:
case WrongStack:
case DFPlayerError:
switch (value) {
case Busy:
case Sleeping:
case FileIndexOut:
case FileMismatch:
case Advertise:
default:
default:
Still
Unable to begin:
No unfortunatelly. About the photo, I can send some but it will be hard to depreciate things. I didn't have a 1KΩ resistor available, so I had to solder a bunch of 10K together in parallel to make a 1.2KΩ one. Also, my wires are all black...
