I have a Arduino Nano clone with old bootloader with CH340 chip. I am able to program it with arduino ide on windows pc selecting processor Atmega328p(old bootloader). There is a program availble for Android, ArduinoDroid. When I try to upload a program to the Nano via my android mobile it gives an error "stk500_recv() programmer is not responding". I borrowed an Arduino Uno from a friend and I can upload the program, indicating the hardware,software connection are working fine. I thought the only difference is the bootloader between Uno and Nano. So I updated the bootloader of Nano. It still doesnt work with a new problem.
With the new bootloader on the nano I get "avrdude: stk500_recv(): programmer is not responding" when I try to upload from PC using arduino ide. When on old bootloader this error was not there. Please help.
Posting the two compilation messages.
Nano with old Bootloader
FQBN: arduino:avr:nano:cpu=atmega328old
Using board 'nano' from platform in folder: C:\Users\ADMIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\ADMIN\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\ADMIN\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\ADMIN\AppData\Local\Temp\arduino\sketches\0FD7F435FD9B262A10C15B6DB4642CBE/COULOMETER.ino.hex"
avrdude: writing flash (13948 bytes):
Writing | ################################################## | 100% 4.36s
avrdude: 13948 bytes of flash written
avrdude: verifying flash memory against C:\Users\ADMIN\AppData\Local\Temp\arduino\sketches\0FD7F435FD9B262A10C15B6DB4642CBE/COULOMETER.ino.hex:
avrdude: load data flash data from input file C:\Users\ADMIN\AppData\Local\Temp\arduino\sketches\0FD7F435FD9B262A10C15B6DB4642CBE/COULOMETER.ino.hex:
avrdude: input file C:\Users\ADMIN\AppData\Local\Temp\arduino\sketches\0FD7F435FD9B262A10C15B6DB4642CBE/COULOMETER.ino.hex contains 13948 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.37s
avrdude: verifying ...
avrdude: 13948 bytes of flash verified
avrdude done. Thank you.
Nano with New Bootloader
Using Port : COM4
Overriding Baud Rate : 115200
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
Reading | ################################################## | 100% -0.00s
Writing | ################avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x10
################################## | 100% 2.50s
Reading | avrdude: stk500_recv(): programmer is not responding
#avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
Failed uploading: uploading error: exit status 1
