Flex sensor problems
Hi. I'm in the process of making "a gesture vocalizer" project where I use 5 flex sensor as a input to the microcontroller arduino Mega where it will give around 10 output or more.
I managed to make it display on LCD when each flex sensor bend. However, when I want multiple flex sensor to bend, it does not work.
Below is the code that I did:
#include<LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);
const int ledPin=13;
#define FLEX_1 A0
#define FLEX_2 A1
#define FLEX_3 A2
const int sMin=950;
const int sMax=820;
pinMode(FLEX_1,INPUT);
pinMode(FLEX_2,INPUT);
pinMode(FLEX_3,INPUT);
pinMode(ledPin,OUTPUT);
int s1=analogRead(A0);
int s2=analogRead(A1);
int s3=analogRead(A2);
if (s1>s2)
int range1=map(s1,sMin,sMax,0,4);
Serial.print(s1);
switch(range1);
       case 0:
       Serial.println("no");
       case 1:
       lcd init();
       lcd.backlight();
       lcd.setCursor(0,0);
       lcd.print("HELLO");
       delay(3000);
       digitalWrite(13,HIGH);
       digitalWrite(13,LOW);
       default: Serial.println("Not found");
        delay(200);
if (s2>s1)
int range2=map(s2,sMin,sMax,0,4);
Serial.print(s2);
switch(range2);
       case 0:
       case 1:
       lcd init();
       lcd.backlight();
       lcd.setCursor(0,0);
       lcd.print("HELP ME");
       delay(3000);
        delay(200);
if ((s3>s1)&&(s3>s2))
int range3=map(s3,sMin,sMax,0,4);
Serial.print(s3);
switch(range3);
       case 0:
       case 1:
       lcd init();
       lcd.backlight();
       lcd.setCursor(0,0);
       lcd.print("MEDICINE");
       delay(3000);
        delay(200);
if (s1&&s2>s3)
int range1=map(s1&&s2,sMin,sMax,0,4);
Serial.print(S1&S2);
switch(range4);
       case 0:
       case 1:
       lcd init();
       lcd.backlight();
       lcd.setCursor(0,0);
       lcd.print("IM SICK");
       delay(3000);
        delay(200);
I know there is wrong with the last one, but i try to figure out for several times but it doesn't work.
First of all, please explain what you mean exactly with "it does not work".
It does not work = nothing happen and no display on the lcd
