Flex sensor unstable
Hello, i’m currently working a new project, Arduino controlled flex sensor. at in idle value, others are in 300+ some are 400-500 or even 900. is it normal??? additionally, how to stabilize their output values for sign language/gesture(with mpu6050) project? coz for instance i bent it from 300, it will fluctuate to either 290-340 randomly even the bent is not moving. thanks
Are you aware that none of the volunteer helpers can see what you are doing. hand draw the wiring and post a picture of it labels on non-common parts, datasheets as well. Also post the code and any serial output both in code tags.
How is the flex sensor connected to the Arduino?
Are you certain the problem is the Flex Sensor and not the MPU as you move the system?
You should make a solid Flex Sensor configuration before trying to use the MPU.
Yes.
Also normal.
