The forum is appallingly slow, lately the (echo) when typing is noticeably delayed. This is very noticeable and prone to mistook when entering information. This problem appears only on the forum.arduino.cc
I checked the hops and found this:
Local Comcast area:
1-5: clean, mostly under 15 ms
Comcast/Cogent handoff and backbone:
some hops show high loss/latency, but later hops recover
Destination:
0.0% loss, about 108 ms average
~$ sudo mtr -rwbzc 50 -T -P 443 forum.arduino.cc
[sudo] password for xxx:
Start: 2026-05-03T14:30:51-0400
HOST: gil Loss% Snt Last Avg Best Wrst StDev
haven't noticed anything myself either..
does look like their may be some latency issues..
output of tracert forum.arduino.cc
Tracing route to arduino.hosted-by-discourse.com [184.104.178.51]
7 13 ms 15 ms 12 ms be-2111-pe11.nota.fl.ibone.comcast.net [68.86.85.50]
8 16 ms 15 ms 14 ms port-channel3.core1.mia1.he.net [209.51.189.69]
9 * * * Request timed out.
10 * * * Request timed out.
11 * 127 ms * 100ge0-32.core2.dub1.he.net [184.105.65.246]
12 113 ms 110 ms 114 ms router01.dub.discourse.cloud [184.104.178.254]
13 110 ms 110 ms 108 ms 184.104.178.51
Trace complete.
I am running Linux mint and from the terminal ran this command" "$ sudo mtr -rwbzc 50 -T -P 443 forum.arduino.cc" where forum.arduino.cc is the URL and works on most anything. Have fun.
I tested this on four different machines and saw the same problem on all of them.
The speed test showed a little over 900 Mbps, and the connection appears solid based on the data I posted. Currently it is averaging about 506.9 Mbps.
I ran several speed tests and visited multiple forums. This is the only site where my typing appears much slower on the screen than what I am actually entering. The text is accurate, but it shows up letter by letter, which is frustrating to watch.
As a comparison, I just downloaded Linux Mint (about 2.5 GB) in under 2 minutes. There was also streaming activity on the network during that time.
At this point, everything I can measure indicates that the issue is not on my end.
Ok, this is the result, not sure what it means in terms of slowdown
26-05-03 22:11 ~ ping -c 10 forum.arduino.cc
PING arduino.hosted-by-discourse.com (184.104.178.51): 56 data bytes
64 bytes from 184.104.178.51: icmp_seq=0 ttl=50 time=125.791 ms
64 bytes from 184.104.178.51: icmp_seq=1 ttl=50 time=123.819 ms
64 bytes from 184.104.178.51: icmp_seq=2 ttl=50 time=121.969 ms
64 bytes from 184.104.178.51: icmp_seq=3 ttl=50 time=123.068 ms
64 bytes from 184.104.178.51: icmp_seq=4 ttl=50 time=118.770 ms
64 bytes from 184.104.178.51: icmp_seq=5 ttl=50 time=124.289 ms
64 bytes from 184.104.178.51: icmp_seq=6 ttl=50 time=123.243 ms
64 bytes from 184.104.178.51: icmp_seq=7 ttl=50 time=125.090 ms
64 bytes from 184.104.178.51: icmp_seq=8 ttl=50 time=124.987 ms
64 bytes from 184.104.178.51: icmp_seq=9 ttl=50 time=123.569 ms
--- arduino.hosted-by-discourse.com ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 118.770/123.460/125.791/1.889 ms
26-05-03 22:11 ~
26-05-03 22:11 ~ traceroute forum.arduino.cc
traceroute to arduino.hosted-by-discourse.com (184.104.178.51), 64 hops max, 40 byte packets
1 192.168.4.1 (192.168.4.1) 8.862 ms 9.642 ms 6.545 ms
2 10.136.64.1 (10.136.64.1) 29.920 ms 18.904 ms 16.092 ms
3 on-bdrv-ar002.on.eastlink.ca (24.139.17.25) 19.443 ms 19.655 ms 18.341 ms
4 on-toro-dr001.on.eastlink.ca (24.139.16.177) 26.658 ms 29.621 ms 27.414 ms
5 on-toro-br001.on.eastlink.ca (24.139.20.217) 25.863 ms
host-24-235-32-253.public.eastlink.ca (24.235.32.253) 24.928 ms 25.767 ms
6 host-24-235-52-125.public.eastlink.ca (24.235.52.125) 27.432 ms 26.322 ms
on-bari-br001.on.eastlink.ca (24.139.7.233) 25.596 ms
7 * 10gigabitethernet1-2.core1.nyc6.he.net (198.32.160.61) 53.555 ms 44.012 ms
8 100ge0-32.core2.dub1.he.net (184.105.65.246) 98.782 ms 101.826 ms *
9 100ge0-32.core2.dub1.he.net (184.105.65.246) 102.408 ms
router01.dub.discourse.cloud (184.104.178.254) 103.345 ms
router02.dub.discourse.cloud (184.104.178.255) 124.033 ms
10 router01.dub.discourse.cloud (184.104.178.254) 101.109 ms
router02.dub.discourse.cloud (184.104.178.255) 126.415 ms 124.731 ms
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
Your traffic goes:local router -> Eastlink Ontario -> Toronto/Barrie area -> HE.net NYC -> HE.net Dublin -> Discourse Dublin
Latency jumps at hop 7/8 because the path crosses the Atlantic:NYC6 HE.net about 44-53 ms DUB1 HE.net about 99-126 ms
That is expected.
The * * * after hop 10 does not necessarily mean failure. It likely means the final host or firewall is not replying to traceroute probes. Since you reached:
The odd part is that this trace is from Eastlink in Ontario, not your Comcast/Michigan path. So if this is from another connection, it is not testing the same network problem as your earlier Comcast traces.
No, I am the Michigan and the trace route posted if from Canada not the US so it goes a different path. This will allow one to work properly and the other not, they are only related at the destination. Traffic loads will also change the response of each route differently.
