I am relatively new to Arduino, but I want to improve the resolution on the analog pins on my Arduino Uno. As I am connecting a device that has a resolution of 12 bits, I want to be able to fully utilize this resolution. As the Uno provides only 10 bit resolution, I was wondering if anyone could refer some type of extra device that I can connect to my Uno in order to reach the desired resolution of 12 bits.
I see online that the Zero supports 12 bits, but Im not sure if I want order a new Arduino for this.
1. You have an ADC device which provides 12-bit data; you want to acquire this data using Arduino UNO. If so, you can always do it.
OR
2. You have a sample of analog signal which you want to digitize into 12-bit parallel format using Arduino UNO. If so, you can't do it. You need Arduino whose internal ADC has 12-bit resolution.
OR
Because, I could not understand the underlying message of your original post; I have wanted the clarification through two queries of my Post#1. In response, you have referred me to a link; is it the right thing that you have done?
GolamMostafa:
Sorry about that, I didnt quite catch what you meant.
But no, the UNO's integrated ADC is only 10 bits (Case 2). But I've read it is possible to get around this by installing a seperate ADC.
Smajdalf:
What sensor are you using? IIRC the linked ADC uses fixed internal reference. If the sensor is ratiometric it would be better to use another ADC.
Quite limited information for such expensive device. But it looks like it is very precise potentiometer and it has a ratiometric output. If it is true (I did not find a datasheet on the linked page, only some vague description) with fixed angle the output changes with varying voltage. Unless you have well stabilized supply voltage for the sensor it is better to use an ADC which uses supply voltage as reference - not an internal reference as ADS1015 do.
