sarouje:
Check out this forum this was mentioned in Android Developer website, might be the official forum.
It must be their official forum like you said, but it seems so "dead". I posted on their forum before I posted here. On their forum, I got six reads and NO responses, while here I've gotten 60 reads and TWO responses in less time. It seems as though no other technical forum feels the depth of community and mutual support as is shared by Arduino people.
PaulMurrayCbr:
I wonder if someone on the playground has already done this? I cant see anything obvious.
I entered the word "Android" in the "Search the Arduino Forum" box above, and 495 articles came up about combining Arduino with Android. Some of them were about connecting the two with BlueTooth.
PaulMurrayCbr:
So far, I have ... successfully [built] a signed .apk and [installed] it on a cheap tablet
I believe "a cheap tablet" is the only way to go, if you want to include one with each product you sell and still make a profit. I use Android 5.0 (which has the system API level 21) because I can get them for less than $50. The biggest drawback I've found is that the standard Date/Time functions weren't added until API level 23! Gasp.
It took me two solid days of concentrated effort -- Google searches for bits and peices, and lots of experimentation -- to find ways to get Date and Time info into a string where my program can manipulate it. So I'll share that information here:
(1) Drag a "TextClock" widget into the preview pane. (2) In it's properties, set "Visibility" to "Gone" (unless you really want to see it). (3) In it's XML listing, add the two lines
android:format12Hour="MMMM dd ',' yyyy"
android:id="@+id/dateClock"
with whatever time/date codes you want; a list of codes can be found here. (4) Then in the .java file, the three lines you'll need to add -- each in it's appropriate location -- are:
(1) TextClock dateDate;
(2) dateClock = (TextClock) findViewById(R.id.dateClock);
(3) dateText.setText(dateClock.getText());
"dateText" being a TextView widget I added to my screen separately. It recieves the date/time info as a string. You could, of course define something else to recieve and hold the data, such as a string. Just now, I added this code, testing to be sure it works.
CharSequence dateStr;
dateStr = dateClock.getText();
dateText.setText(dateStr);
Here, dateStr gets the data from the clock, holds it, then passes it on to dateText.
PaulMurrayCbr:
Android apps are horrible big things, unfortunately.
True. In fact, I felt discouraged when I first saw what all was involved. But there are really good ways to learn to "master the beast". I started with the free Youtube lessons Android App Development for Beginners, duplicating what he demonstrates -- line by line -- on my laptop/tablet, until I was ready to leave the lessons behind and take off on my own.
