Hi @TFTLCDCyg
I confirm, now I can compile the code and Helloworld is working fine. The calibration is only at first time, when EEPROM is clear, otherwise it seems that it keeps settings. So I think that's good.
I will now try to load some image from SD card for test.
BTW. Can I use library SD card functions to write/read the files, or it is only allowing to read images via function of the GSTx library?
Update
I tried some of the examples jpg_bench.ino and JPG_Load.ino.
I have sdcard inserted, system of the files is exFAT, i have copy of the file ToMicroSD all files are directly on card without catalogue.
First one (jpg_bench) is compiling but I am getting an error screen.
The second one (JPG_Load) i couldn't compile due to part of the code of Parametros.ino
if(SizeFT813==35){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@NHD-3.5-320240FT-CSXN-CTP");}
if(SizeFT813==43){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@NHD-4.3-480272FT-CSXN-CTP");}
if(SizeFT813==5){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@NHD-5.0-800480FT-CTXL-CTP");}
if(SizeFT813==7){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@NHD-7.0-800480FT-CSXN-CTP");}
if(SizeFT813==51){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@Riverdi RVT50UQFNWC000");}
if(SizeFT813==71){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: FT813@Riverdi RVT70UQFNWC000");}
if(SizeFT813==52){GD.cmd_text(2, GD.h-12, 20, 0, "EVE chip: BT815@Matrix Orbital EVE3-50G");}
When I commented those lines i could compile the program but I am still getting same error as above.
SD card is working when I use examples from SdFat library.
Any idea what could be wrong?
