Dear forum, I was wondering if anybody here could give me some more ideas...
I'm trying to use a "Deek Rodot" USB to FTDI to program my sparkfun Arduino Pro Mini 5v, 16mhz
http://www.ebay.co.uk/itm/281737030948?euid=18093c31e6464387a24e140922c7c2ab&cp=1
Wiring is as follows:
FTDI Pro Mini
GND - BLK
CTS - GND
5v - Vcc
TXD - RXI
RXD - TXO
DTR - GRN
I'm trying to upload a blank sketch, but I get the following error during the upload:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x99
I've also seen 0x00, 0x04
I have selected the right port, and pro mini under boards, also selected ArduinoISP as the programmer and ATmega328 5v 16mhz as the chip.
Things I have tried or verified:
Correct port: COM6 appears when I plug in the USB cable and disappears when I remove it.
Pro mini works: successfully uploaded blink using my arduino uno as an "Arduino as ISP programmer"
Using only the FTDI chip with TXD and RXD jumpered together anything typed into the serial monitor is returned.
I have tried updating the driver for the FTDI through Computer Management on Windows 7, not sure if I have the right one though, how can I test this? I read something about a recent driver bricking FTDIs?
Swapping Tx-Rx & Rx-Tx to Tx-Tx & Rx-Rx
Removing the cable between CTS and GND
Programming my Uno through the ICP connector on the FTDI and ICSP connector on the UNO
Any more suggestions for how to trouble shoot this or things I can test would be greatly appreciated.
Many Thanks!
