So ive been working on getting a file transferred from an sd card to an ftp server, and i having some issues. As stated above im getting a 425 error on the the FTP server side. I have opened the ports up on my router for the data connection. But still no luck
hardware:
uC Teensy 3.2
Wifi ATWINC1500 from adafruit
SD card + Module
I am aware the the Arduino wifi shield is not capable of handling two sockets at a time.
Here is the link for the data sheet for the chip im using ATWINC1500 Datasheet
so if anyone has come across this issue or know a work around/ fix and could pass it on to me that would be greatly appreciated
#include <FreeStack.h>
#include <MinimumSerial.h>
#include <SdFat.h>
#include <SdFatConfig.h>
#include <SdFatUtil.h>
#include <SystemInclude.h>
#include <SPI.h>
#include <WiFi101.h>
#define FTPWRITE
SdFat SD;
SdFile file;
char ssid[] = "Run Faster Forest"; // your network SSID (name)
char pass[] = "********"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
const uint8_t SD_chipSelect = 9;
// change to your server
IPAddress server( 192, 168, 1, 127 );
WiFiClient client;
WiFiClient dclient;
char outBuf[128];
char outCount;
// change fileName to your file (8.3 format!)
char fileName[13] = "Data_25.txt";
WiFi.setPins(10,6,2);
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
//Initialize SD card
if (!SD.begin(SD_chipSelect, SPI_HALF_SPEED)) {
SD.initErrorHalt();
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
printWifiData()
// wait 10 seconds for connection:
delay(5000);
delay(5000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
//digitalWrite(10,HIGH);
delay(2000);
Serial.println(F("Ready. Press f or r"));
byte inChar;
inChar = Serial.read();
if(inChar == 'f')
if(doFTP()) Serial.println(F("FTP OK"));
else Serial.println(F("FTP FAIL"));
if(inChar == 'r')
readSD();
File fh;
byte doFTP(){
#ifdef FTPWRITE
fh = SD.open(fileName,FILE_READ);
#else
SD.remove(fileName);
fh = SD.open(fileName,FILE_WRITE);
#endif
if(!fh)
Serial.println(F("SD open fail"));
return 0;
#ifndef FTPWRITE
if(!fh.seek(0))
Serial.println(F("Rewind fail"));
fh.close();
return 0;
#endif
Serial.println(F("SD opened"));
if (client.connect(server,22)) {
Serial.println(F("Command connected"));
else {
fh.close();
Serial.println(F("Command connection failed"));
return 0;
if(!eRcv()) return 0;
client.println(F("USER Test"));
client.println(F("PASS 1988"));
client.println(F("SYST"));
client.println(F("Type I"));
client.println(F("PASV"));
char *tStr = strtok(outBuf,"(,");
int array_pasv[6];
for ( int i = 0; i < 6; i++) {
tStr = strtok(NULL,"(,");
array_pasv[i] = atoi(tStr);
if(tStr == NULL)
Serial.println(F("Bad PASV Answer"));
// unsigned int hiPort,loPort;
// hiPort = array_pasv[6] << 5000;
// loPort = array_pasv[6] & 0;
// Serial.print(F("Data port: "));
// hiPort = hiPort | loPort;
// Serial.println(hiPort);
// if (dclient.connect(server,hiPort)) {
// Serial.println(F("Data connected"));
// else {
// Serial.println(F("Data connection failed"));
// client.stop();
// fh.close();
// return 0;
#ifdef FTPWRITE
client.print(F("STOR /"));
client.println(fileName);
#else
client.print(F("RETR "));
#endif
if(!eRcv())
dclient.stop();
return 0;
#ifdef FTPWRITE
Serial.println(F("Writing"));
byte clientBuf[64];
int clientCount = 0;
while(fh.available())
clientBuf[clientCount] = fh.read();
clientCount++;
if(clientCount > 63)
dclient.write(clientBuf,64);
clientCount = 0;
if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
while(dclient.connected())
while(dclient.available())
char c = dclient.read();
fh.write(c);
Serial.write(c);
#endif
dclient.stop();
Serial.println(F("Data disconnected"));
client.println(F("QUIT"));
client.stop();
Serial.println(F("Command disconnected"));
fh.close();
Serial.println(F("SD closed"));
return 1;
byte eRcv(){
byte respCode;
byte thisByte;
while(!client.available()) delay(1);
respCode = client.peek();
outCount = 0;
while(client.available())
thisByte = client.read();
Serial.write(thisByte);
if(outCount < 127)
outBuf[outCount] = thisByte;
outCount++;
outBuf[outCount] = 0;
if(respCode >= '4')
efail();
return 0;
return 1;
void efail(){
byte thisByte = 0;
client.stop();
fh.close();
void readSD(){
if(!fh)
return;
Serial.write(fh.read());
fh.close();
void printWifiData() {
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
Serial.print(mac[5], HEX);
Serial.print(":");
Serial.print(mac[4], HEX);
Serial.print(":");
Serial.print(mac[3], HEX);
Serial.print(":");
Serial.print(mac[2], HEX);
Serial.print(":");
Serial.print(mac[1], HEX);
Serial.print(":");
Serial.println(mac[0], HEX);
// print your subnet mask:
IPAddress subnet = WiFi.subnetMask();
Serial.print("NetMask: ");
Serial.println(subnet);
// print your gateway address:
IPAddress gateway = WiFi.gatewayIP();
Serial.print("Gateway: ");
Serial.println(gateway);
