@retrolefty
#ifndef Pins_Arduino_h
#define Pins_Arduino_h
#include <avr/pgmspace.h>
// ATMEL ATMEGA1284P on Bobuino
// (D 4) PB0 1 | | 40 PA0 (D 21) AI 7
// (D 5) PB1 2 | | 39 PA1 (D 20) AI 6
// INT2 (D 6) PB2 3 | | 38 PA2 (D 19) AI 5
// PWM (D 7) PB3 4 | | 37 PA3 (D 18) AI 4
// PWM/SS (D 10) PB4 5 | | 36 PA4 (D 17) AI 3
// MOSI (D 11) PB5 6 | | 35 PA5 (D 16) AI 2
// PWM/MISO (D 12) PB6 7 | | 34 PA6 (D 15) AI 1
// PWM/SCK (D 13) PB7 8 | | 33 PA7 (D 14) AI 0
// RST 9 | | 32 AREF
// VCC 10 | | 31 GND
// GND 11 | | 30 AVCC
// XTAL2 12 | | 29 PC7 (D 29)
// XTAL1 13 | | 28 PC6 (D 28)
// RX0 (D 0) PD0 14 | | 27 PC5 (D 27) TDI
// TX0 (D 1) PD1 15 | | 26 PC4 (D 26) TDO
// INT0 RX1 (D 2) PD2 16 | | 25 PC3 (D 25) TMS
// INT1 TX1 (D 3) PD3 17 | | 24 PC2 (D 24) TCK
// PWM (D 30) PD4 18 | | 23 PC1 (D 23) SDA
// PWM (D 8) PD5 19 | | 22 PC0 (D 22) SCL
// PWM (D 9) PD6 20 | | 21 PD7 (D 31) PWM
#define NUM_DIGITAL_PINS 32
#define NUM_ANALOG_INPUTS 8
#define analogInputToDigitalPin(p) ((p < NUM_ANALOG_INPUTS) ? 21 - (p) : -1)
extern const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS];
extern const uint16_t __pcmsk[];
extern const uint8_t digital_pin_to_timer_PGM[NUM_DIGITAL_PINS];
#define ifpin(p,what,ifnot) (((p) >= 0 && (p) < NUM_DIGITAL_PINS) ? (what) : (ifnot))
#define digitalPinHasPWM(p) ifpin(p,pgm_read_byte(digital_pin_to_timer_PGM + (p)) != NOT_ON_TIMER,1==0)
#define digitalPinToAnalogPin(p) ( (p) >= 14 && (p) <= 21 ? (p) - 14 : -1 )
#define analogPinToChannel(p) ( (p) < NUM_ANALOG_INPUTS ? NUM_ANALOG_INPUTS - (p) : -1 )
static const uint8_t SS = 10;
static const uint8_t MOSI = 11;
static const uint8_t MISO = 12;
static const uint8_t SCK = 13;
static const uint8_t SDA = 23;
static const uint8_t SCL = 22;
static const uint8_t LED = 13;
static const uint8_t A0 = 14;
static const uint8_t A1 = 15;
static const uint8_t A2 = 16;
static const uint8_t A3 = 17;
static const uint8_t A4 = 18;
static const uint8_t A5 = 19;
static const uint8_t A6 = 20;
static const uint8_t A7 = 21;
#define digitalPinToPCICR(p) ifpin(p,&PCICR,(uint8_t *)0)
#define digitalPinToPCICRbit(p) ifpin(p,digital_pin_to_pcint[p] >> 3,(uint8_t *)0)
#define digitalPinToPCMSK(p) ifpin(p,__pcmsk[digital_pin_to_pcint[]],(uint8_t *)0)
#define digitalPinToPCMSKbit(p) ifpin(p,digital_pin_to_pcint[p] & 0x7,(uint8_t *)0)
#ifdef ARDUINO_MAIN
#define PA 1
#define PB 2
#define PC 3
#define PD 4
const uint8_t digital_pin_to_pcint[NUM_DIGITAL_PINS] =
24, // D0 PD0
25, // D1 PD1
26, // D2 PD2
27, // D3 PD3
8, // D4 PB0
9, // D5 PB1
10, // D6 PB2
11, // D7 PB3
29, // D8 PD5
30, // D9 PD6
12, // D10 PB4
13, // D11 PB5
14, // D12 PB6
15, // D13 PB7
7, // D14 PA7
6, // D15 PA6
5, // D16 PA5
4, // D17 PA4
3, // D18 PA3
2, // D19 PA2
1, // D20 PA1
0, // D21 PA0
16, // D22 PC0
17, // D23 PC1
18, // D24 PC2
19, // D25 PC3
20, // D26 PC4
21, // D27 PC5
22, // D28 PC6
23, // D29 PC7
28, // D30 PD4
31, // D31 PD7
const uint16_t __pcmsk[] =
(uint16_t)&PCMSK0,
(uint16_t)&PCMSK1,
(uint16_t)&PCMSK2,
(uint16_t)&PCMSK3
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
const uint16_t PROGMEM port_to_mode_PGM[] =
NOT_A_PORT,
(uint16_t) &DDRA,
(uint16_t) &DDRB,
(uint16_t) &DDRC,
(uint16_t) &DDRD,
const uint16_t PROGMEM port_to_output_PGM[] =
NOT_A_PORT,
(uint16_t) &PORTA,
(uint16_t) &PORTB,
(uint16_t) &PORTC,
(uint16_t) &PORTD,
const uint16_t PROGMEM port_to_input_PGM[] =
NOT_A_PORT,
(uint16_t) &PINA,
(uint16_t) &PINB,
(uint16_t) &PINC,
(uint16_t) &PIND,
const uint8_t PROGMEM digital_pin_to_port_PGM[NUM_DIGITAL_PINS] =
PD, // D0
PD, // D1
PD, // D2
PD, // D3
PB, // D4
PB, // D5
PB, // D6
PB, // D7
PD, // D8
PD, // D9
PB, // D10
PB, // D11
PB, // D12
PB, // D13
PA, // D14
PA, // D15
PA, // D16
PA, // D17
PA, // D18
PA, // D19
PA, // D20
PA, // D21
PC, // D22
PC, // D23
PC, // D24
PC, // D25
PC, // D26
PC, // D27
PC, // D28
PC, // D29
PD, // D30
PD, // D31
const uint8_t PROGMEM digital_pin_to_bit_mask_PGM[NUM_DIGITAL_PINS] =
_BV(0), // D0 PD0
_BV(1), // D1 PD1
_BV(2), // D2 PD2
_BV(3), // D3 PD3
_BV(0), // D4 PB0
_BV(1), // D5 PB1
_BV(2), // D6 PB2
_BV(3), // D7 PB3
_BV(5), // D8 PD5
_BV(6), // D9 PD6
_BV(4), // D10 PB4
_BV(5), // D11 PB5
_BV(6), // D12 PB6
_BV(7), // D13 PB7
_BV(7), // D14 PA7
_BV(6), // D15 PA6
_BV(5), // D16 PA5
_BV(4), // D17 PA4
_BV(3), // D18 PA3
_BV(2), // D19 PA2
_BV(1), // D20 PA1
_BV(0), // D21 PA0
_BV(0), // D22 PC0
_BV(1), // D23 PC1
_BV(2), // D24 PC2
_BV(3), // D25 PC3
_BV(4), // D26 PC4
_BV(5), // D27 PC5
_BV(6), // D28 PC6
_BV(7), // D29 PC7
_BV(4), // D30 PD4
_BV(7), // D31 PD7
const uint8_t PROGMEM digital_pin_to_timer_PGM[NUM_DIGITAL_PINS] =
NOT_ON_TIMER, // D0 PD0
NOT_ON_TIMER, // D1 PD1
NOT_ON_TIMER, // D2 PD2
NOT_ON_TIMER, // D3 PD3
NOT_ON_TIMER, // D4 PB0
NOT_ON_TIMER, // D5 PB1
NOT_ON_TIMER, // D6 PB2
TIMER0A, // D7 PB3
TIMER1A, // D8 PD5
TIMER2B, // D9 PD6
TIMER0B, // D10 PB4
NOT_ON_TIMER, // D11 PB5
TIMER3A, // D12 PB6
TIMER3B, // D13 PB7
NOT_ON_TIMER, // D14 PA0
NOT_ON_TIMER, // D15 PA1
NOT_ON_TIMER, // D16 PA2
NOT_ON_TIMER, // D17 PA3
NOT_ON_TIMER, // D18 PA4
NOT_ON_TIMER, // D19 PA5
NOT_ON_TIMER, // D20 PA6
NOT_ON_TIMER, // D21 PA7
NOT_ON_TIMER, // D22 PC0
NOT_ON_TIMER, // D23 PC1
NOT_ON_TIMER, // D24 PC2
NOT_ON_TIMER, // D25 PC3
NOT_ON_TIMER, // D26 PC4
NOT_ON_TIMER, // D27 PC5
NOT_ON_TIMER, // D28 PC6
NOT_ON_TIMER, // D29 PC7
TIMER1B, // D30 PD4
TIMER2A, // D31 PD7
#endif // ARDUINO_MAIN
#endif // Pins_Arduino_h
// vim:ai:cin:sts=2 sw=2 ft=cpp
